#26 |
Member#: 330433
This will be an amazing build... Talk about a sleeper!
#27 |
Member#: 29879
TXIC
Vehicle:2002 WRX Wagon Silver |
Subscribed.
#28 |
Member#: 31997
MAIC
Vehicle:08 QSM Spec Bizzle 96 XJ Beater |
THIS = Awesome. RWD Legacy is exactly what the world needs.
#29 | |
Member#: 206851
MWSOC
Vehicle:99 V4 EJ20K RS |
the wiring is cake. the starter will engage without the ecu with a simple wiring change. |
#30 |
Member#: 328178
MAIC
Vehicle:2005 Forester XT PSM |
Oh man. This may be worth keeping an eye out for.
#31 |
Member#: 223143
MWSOC
Vehicle:2002 WRX Wagon SRP |
Subscribed for awesomeness.
#32 |
Member#: 140073
South East
Vehicle:2005 LGT Red |
The LGT ECU is being removed. I am using the GM ECU and most of its harness. We are still working on the cluster but it may end up being the guts of a GTO cluster behind the Legacy faces
#33 |
Member#: 140073
South East
I bought a whole Express van for $1600 dollars and I am going to part it out to basically be at $0 for all the parts I am using out of it (Engine, ECU, Harness, Sensors, Starter, Alternator, etc.) plus once I decide to mod the engine (bore out, or add boost) I have a bigger safety margin
#34 |
Member#: 140073
South East
Thanks, we like to use most of our time to actually make progress on this but will post updates when we can. We are also working on a V8 Miata at the same time using an aluminum 5.3L and a CTS-V T56
#35 | |
Member#: 140073
South East
#36 |
Member#: 140073
South East
#37 | |
Member#: 140073
South East
To keep things simple we are going to most likely make a GM/Subaru hybrid cluster
#38 |
Member#: 140073
South East
Some pics of the van that gave its life and a few of the motor being broken down:
#39 |
Member#: 140073
South East
Picked up some L92/LS3 heads
#40 |
Member#: 140073
South East
Cleaned up the block a bit
#41 |
Member#: 140073
South East
We notched the subframe further so the engine would move back toward the firewall and test a 3/4 in. shim in between the subframe and body to drop it lower
#42 |
Member#: 283815
TXIC
Vehicle:2003 psm wrx wagon Built Fuji Tough |
clicked to see a v.8 build, found a v8 build.
Can't wait to see it in motion.You one of those people who answers the question 'why?' with 'why not?', aren't you? |
#43 |
Member#: 79643
NESIC
Vehicle:04 EJ207 Swapped Mikey tuned 271whp/287wtq |
Fits better than a turbo subaru motor
#44 |
Member#: 140073
South East
It fits pretty well. We are still doing some work on the subframe for good clearance while keeping it sturdy
#45 |
Member#: 223237
South East
I apoligize if I missed it but will this retain AC and other creature comforts?
#46 | |
Member#: 33782
MAIC
Vehicle:96 bastard child search FIRST, then PM!!! |
![]() I know a group of guys that are kicking around the idea of building a $50 93 Impreza chassis for Chump car with a 6.0L (L96) engine. It's either that or the freebie EG33 sitting around. The Marine V8 will be easier was easier on electrical. ....so I'm taking notes ![]() |
#47 |
Member#: 140073
South East
#48 | |
Member#: 140073
South East
If it is the GEN IV L96 6.0L the you have basically the same motor I do as it comes factory with the heads I bought as an upgrade. You can mill the heads a bit, throw a cam in there and upgrade the springs and be around 450 hp. If you decide to go that route, let me know as I am sure I will have some leftover parts to share
#49 | |
Member#: 33174
RMIC
Vehicle:We are Open Late! 888-457-2559 Every day! |
![]() Rick |
#50 |
Member#: 140073
South East
Sure thing. Here is where the parts collection stands now:
LQ4 6.0L Block L92 Rectangle Port Heads (will be milled down to get compression around 10.5:1) Billet Timing Chain Kit GTO Front Sump Oil Pan and Pickup Comp XR273HR Camshaft (220/224 .530/.534 112LSA) L76 Intake Manifold LS7 Fuel Rail LS3 Corvette Water Pump The front sump oil pan is required for the way our subframe is set up and I am going to run LS3 accessories as they are approximately 3/4in. closer to the block than their F-Body counterparts Next parts on the list to pickup are: LS3 Injectors Springs and Retainers |
