Old 07-01-2012, 05:21 PM   #1751
prezwag93
Member#: 290071
Originally Posted by acanadianreject
BOOM! update!
after 2 coats of metallic
ended up doing one more and then stored them, waiting for it to get a little nicer out before i co clear coat, i have had problems in the past with clearing when its cool with moisture in the air, fogging and such. not good. so im waiting
Wow!! That metallic is gorgeous. What brand and color specifically?
prezwag93 is offline   Reply With Quote
Old 07-01-2012, 06:25 PM   #1752
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
here are the cans, the color and the clear i used for those wheels, i LOVE this color, i have used it for both of my last 2 winter wheel sets and a friend of mine's wheels. its amazing.
acanadianreject is offline   Reply With Quote
Old 07-04-2012, 09:08 PM   #1753
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by swede978 View Post
Nice job and write up, Thanks.
Looks great! Thanks for the great write up and I will definitely have to copy your paint scheme. 2012 impreza will look much better now!
gregorz4 is offline   Reply With Quote
Old 07-04-2012, 09:14 PM   #1754
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by geezersmk View Post
I just picked up my 2009 WRX two months ago and after reading through this thread decided I wanted to paint my rims. Here's what I used:
One 2.5 Ton Jack $55
Four 2 Ton Jack stands $55
Dupli-Color Primer Sealer (2 cans) $14
Dupli-Color High Performance Graphite (4 cans) $28
Dupli-Color High Performance Clear (2 cans) $14
400 grade Sand paper $10
Simple Green $6
3x5 Index Cards
Total Price = $173
1) Took all four wheels off
2) Washed with auto soap and water
3) Sprayed with Simple Green & scrubbed with a wheel brush & dish green pads
4) Washed with Soap and water again
5) Dried tires
6) 400 Grit Sandpaper rub down, probably spent 30 minutes per wheel
7) Washed with water
8) 400 Grit Sandpaper round 2, spent another 30 minutes per wheel, really got it scuffed up good.
9) Cleaned with rubbing alcohol
10) 2 Coats primer with 10 minutes in between coats, then 1 hour to dry
11) 4 Coats graphite, 10 minutes in between coats, 40 minutes to dry
12) 3 Coats clear, 15 minutes in between coats
Before Shot
All four tires cleaned, sanded & ready to paint
1st coat of Primer
1st coat of Graphite Paint
3rd coat of Graphite Paint
1st coat of clear, we over sprayed the first tire, let it sit in sun for 20 minutes, then did light coats on the rest.
All four tires freshly finished, ready to dry. I put back on my car 6 hours later.
After Shots
Looks great! Will definitely have to do this on my 2012 impreza. Thanks for the great write up and pics.
Old 07-08-2012, 03:26 AM   #1755
Acuna989
Member#: 323493
2003 WRX Hybrid 6sp
Decided to paint my stock bbs gunmetal. I picked the color out at a local auto paint store and had them mix it up in spray cans. The materials are in the pic below. I'll update this post with the base coat number soon. Processs for the wheels included.
1.had tires dismounted
2.clean/degreaseing
3.sand 180g
4.bondo curb rash
5.sand 320g
6.clean/degreaser
7.primer filler
8.sand 320g
9.clean/degreaser
10.primer
11.sand 1500g
12.clean/degreaser
13.two heavy coats of base
14.two heavy coats of clear
15.baked in the 100F California sun for 8hrs the next day.
The whole process took about eight hours.
Acuna989 is offline   Reply With Quote
Old 07-08-2012, 07:11 PM   #1756
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
^lots of time put into those but they look great
here is one of mine. three more to go
1) sand old paint smooth with 800 grit
2) 2-3 coats of rustoleum self etching primer
3) 2-3 coats of rustoleum semi gloss black
4)2-3 coats of rustoleum galaxy blue color shift
5)2-3 coats of rustoleum clear
mrxr250rider is offline   Reply With Quote
Old 07-08-2012, 11:32 PM   #1757
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
so sick, wish i could rock those, just would match for me...
and those bbs's are beautiful!
Old 07-21-2012, 10:20 AM   #1758
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Can anyone find pics of an 11-12 STI SEDAN w/ the stock wheels painted graphite gray or black? (Enkei)
I am considering going that route using Plastikote. Thanks
Phil_Dunphy is offline   Reply With Quote
Old 07-21-2012, 04:05 PM   #1759
scooby1326
Member#: 286827
3 coats of plastidip
3 coats of valspar island orange
scooby1326 is offline   Reply With Quote
Old 07-21-2012, 05:21 PM   #1760
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Neat with the plastidip underneath it should just peel off?
Old 07-22-2012, 01:02 PM   #1761
scooby1326
Member#: 286827
That was the thought and it does kind of peel off but it's harder than just regular plastidip. Probably easier to heat them up or something.
Old 07-22-2012, 05:16 PM   #1762
theoutbackdream
Member#: 301179
2013 WRX Limited
im 75% sure i read that someone did the same exact thing and just pealed off like normal plastidip.
Old 07-22-2012, 11:05 PM   #1763
Microsoftie
Member#: 326944
2006 Legacy
Looked through every page and didn't see a specific name for blue spray paint product. Anyone?
Also, I didnt see any legacy 2.5i wheels, I'm going to be painting mine this weekend, here are some quick shops. Any thoughts on the color? Leaning towards blue, hence my previous question.
Microsoftie is offline   Reply With Quote
Old 07-23-2012, 03:36 PM   #1764
scooby1326
Member#: 286827
I haven't decided if i want to repaint them yet but if I do I'll let you know lol.
Old 07-24-2012, 02:59 PM   #1765
datbacker59
Member#: 250117
2012 STi
Plasma Blue Pearl
nobody painted the non-limited 2011-2012 STi?!
datbacker59 is offline   Reply With Quote
Old 07-25-2012, 01:33 AM   #1766
chichiko
Member#: 162590
Is there any way to remove the center cap of the OEM '11 wrx wheels and replace it with a custom one that has the red wrx logo on it?
chichiko is offline   Reply With Quote
Old 07-25-2012, 01:38 AM   #1767
theoutbackdream
Member#: 301179
2013 WRX Limited
you should be able to as i believe they are just plastic clips with the metal cap on it that hold in.
Old 07-25-2012, 01:55 AM   #1768
chichiko
Member#: 162590
I've seen on here some sti and wrx logo'd ones you can purchase. Would those fit? What tool would I use to remove the caps?
Old 07-25-2012, 02:04 AM   #1769
theoutbackdream
Member#: 301179
2013 WRX Limited
I cannot answer that as im not sure at all. But when i had to replace my cap since it got stolen or just came off, I believe a Xacto knife could squeeze in and pop it out, although i would be really careful. Other option would be remove the whole wheel and pop it out.. lol
Found this through google.
http://forums.nasioc.com/forums/show....php?t=2115888
Old 07-30-2012, 11:57 PM   #1770
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
NOPE! Absolutely DOES NOT work. DO NOT DO THIS and expect it to be a quick job...I couldn't even 0% pressure wash half of the paint off. I used about 5-6 layers or plastidip too.
awdorgtfo is offline   Reply With Quote
Old 07-31-2012, 09:22 PM   #1771
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Ver7 STi wheels painted Volvo 451 gold. We tried several different gold paints including Susuki gold. My paint guy did have to add tint to soften the yellow associated with the 451. The wheels had some deep gouges and curb rash but he was able to buff these out. Total cost was $275. DuPont paint and clear coat.
beaviscih is offline   Reply With Quote
Old 08-05-2012, 11:08 AM   #1772
Vonsa
Member#: 318364
I would love to see a wrb with black rims and a pink pinstripe.
Like the matalic car i saw a couple pages back, but wrb instead.
Vonsa is offline   Reply With Quote
Old 08-25-2012, 04:45 PM   #1773
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
stock 06-07 wrx wheels painted rustoleum galaxy blue color shift and 20mm wheel spacers
Old 08-29-2012, 10:36 PM   #1774
Dpalmer
Member#: 322860
2002 Impreza WRX
4 Cans of Duplicolor engine enamel (I don't know the color name, but it looked like a gun metal grey when I bought it. But it didn't by the time I got finished.)
2 Cans of Duplicolor engine clearcoat
2 Cans of rustoleum primer
Per Wheel:
2 or 3 coats of primer, sand down with 350 grit, 2 coats of engine enamel, 2 coats of clear.
The wheels looks like a dark grey in the shade or indirect sunlight, but when the sun hits them they look like this. I'm pretty impressed with the outcome!
http://s1267.photobucket.com/albums/...t=383579f4.jpg
Total cost :$55
Dpalmer is offline   Reply With Quote
Old 09-01-2012, 08:12 AM   #1775
browsing
Member#: 233683
2012 STI Hatch
Working on a set of 2008 STi 5-spokes, from this:
After a two stage powder coat and a couple layers of clear:
browsing is offline   Reply With Quote
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 08:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 07:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 12:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 02:35 PM
