Old 12-20-2011, 07:29 PM   #1
Batlground
Member#: 84451
Default Batlground Porsche 914 Build
Here at Batlground Motorsports, we have taken on a huge project. It started life as a Porsche 914, but when it rolled into our shop it was obvious that the vehicle had seen better days. The luck of the little 914 is changing. The owner wants a track ready ej20 swapped car when finished. Every inch of the 914 is getting overhauled, starting with removing rust from the chassis.
We will update this thread as we get more work completed on this project. Sorry, but I could not find a true "before" pic.
Parts of the factory floor were cut out so that the rust could be completely removed. The floor then got coated with POR-15, and then welded back up.
Before
Rust
Cleaned
Batlground is offline   Reply With Quote
Old 12-20-2011, 07:29 PM   #2
Batlground
Member#: 84451
This is continuing from the first post.
Removed parts
POR-15
Reinstall
Paint
Old 12-21-2011, 09:20 AM   #3
stragen
Member#: 218682
2006 WRX Stage 9001
DrunkMann'd @ GCM
Bumping for what could be an epic return to greatness build.
stragen is offline   Reply With Quote
Old 12-21-2011, 11:41 AM   #4
Batlground
Member#: 84451
We started cutting vents in the front end for cooling the radiator. Also we are mocking up how we will be mounting the fuel cell and radiator. We cut out a section across the front bay section and added a strut bar to add stiffness to the chassis that lacks much needed structural support. Fuel cell and radiator mounts will be next.
Old 12-21-2011, 10:03 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
looking good.
So what is the game plan for an intercooler?
Old 12-23-2011, 12:48 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
So....air cooled ej20 turbo? Usually people convert these to liquid cooled when they do this swap. I hope the temps are able to stay down and am interested to see the results.
edit: The second time I read your comment I concluded you probably meant liquid cooled. Correct me if I'm wrong.
My dream is to someday convert a 914 to ee20 power. Maybe I'll give you guys a call in a few years when I can get the money together.
geronimo81 is offline   Reply With Quote
Old 12-23-2011, 02:12 PM   #7
emsalex
Member#: 296665
97 leg OB wagon
black/purp
^ i was scratching my head too, but im guess he meant convert from air cooled not to air cooled as he goes on to talk about mounting a rad. and there is a templet where a rad. would go.
emsalex is offline   Reply With Quote
Old 12-27-2011, 03:36 PM   #8
Batlground
Member#: 84451
Yes this one will have a radiator mounted up front and so far in the plans the intercooler will be a standard top mount location.
Old 12-28-2011, 01:18 PM   #9
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Can't see pics at work haha.
OP will there be any ducting to bring air to the top mount?
Old 12-29-2011, 12:38 PM   #10
Batlground
Member#: 84451
Yes there will be ducting to the top mount. There is still ducting to be done for the front mounted radiator and a/c condenser. Also a hole has to be cut in the hood to for the air to go out of the radiator. Cosmetic stuff is later. You read correct, this car is getting a full heat and A/C system. Here are the pictures of the radiator and fuel cell mounts that we made. They are both rubber mounted with isolators from MSC. We are trying to use as much aluminum as possible to keep the weight down.
Old 12-30-2011, 10:34 PM   #11
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed
wtyree is offline   Reply With Quote
Old 01-03-2012, 11:46 PM   #12
Slow Steve
Member#: 304346
Nice!! I can't wait to see this build.
Slow Steve is offline   Reply With Quote
Old 01-11-2012, 12:42 PM   #13
Batlground
Member#: 84451
Roll cage has been started. Here are pictures of the main hoop with halo bar. We went with the halo bar option so that the oem targa top can be installed easily. The cage is being built to NASA as well as SCCA specifications. I will post more pictures as we get more done.
Old 01-13-2012, 01:21 PM   #14
Batlground
Member#: 84451
More roll cage pics. I will let the pictures speak for themselves.
Old 01-18-2012, 03:21 PM   #15
Batlground
Member#: 84451
More roll cage pics
Old 01-22-2012, 12:36 PM   #16
ssantoro01
Member#: 307658
Do Work!. looks good
ssantoro01 is offline   Reply With Quote
Old 01-22-2012, 02:50 PM   #17
kunzer51
Member#: 300371
not too rough for a 914 those are known for their rot engine bay esp!! lookin good tho
kunzer51 is offline   Reply With Quote
Old 03-06-2012, 02:18 AM   #18
Volksygolf1.8t
Member#: 312636
One unique project! Gl with your build
Volksygolf1.8t is offline   Reply With Quote
Old 03-07-2012, 12:38 AM   #19
alwaysboostin4life
Member#: 289265
I love builds like this. Make me jealous
alwaysboostin4life is offline   Reply With Quote
Old 05-08-2012, 06:11 PM   #20
1of1500
Member#: 319517
Very cool that it's getting a second life!
1of1500 is offline   Reply With Quote
Old 05-10-2012, 05:00 AM   #21
561wrx
Member#: 166427
03 wrx
nice.
561wrx is offline   Reply With Quote
Old 05-21-2012, 04:24 AM   #22
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Subscribed just bought a 914 today....lol
dasnowman is offline   Reply With Quote
Old 09-02-2012, 01:28 PM   #23
su-version
Member#: 330666
Bump. Any updates?? I'm right behind you, as in a couple of years. I'm currently in the "educate myself" phase and am perusing this site for ideas. I too want A/C so will watch with interest. I'm flirting with the 6 but it appears the EJ20 T will provide the same power with less weight and less space. What route are you taking on the engine coolant lines? Under, through the cabin, longs or exterior, behind the rocker panels? Are you adapting to the 901 tranny or using the Suby tranny?
su-version is offline   Reply With Quote
Old 10-26-2012, 06:47 AM   #24
lsb
Member#: 336180
Very interesting
lsb is offline   Reply With Quote
Old 10-31-2012, 02:58 AM   #25
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
I'm buming this too for more info!
I'm in the process of doing a build still not sure if doing a Type 4 build up to a 2.5 have been just working on body and haven't even had a look at the engine was a $1500 garage find with almost no rust. Will do a Suby swap if the engine is toast.
There is a lot of info at 914World.com and a few guys are building swap kits for Suby conversions. This is by far my favorite build over there!
http://www.914world.com/bbs2/index.p...topic=84842&hl=
Buying a Porsche 914 sperry Off-Topic 12 12-10-2003 02:05 PM
My Porsche 914 Track Car soloracer Member's Car Gallery 19 06-25-2003 11:01 PM
EJ25 into Porsche 914!!! :) Clegg Mid West Subaru Owners Club Forum -- MWSOC 4 02-10-2002 01:39 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 14 06-19-2001 03:58 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 2 05-29-2001 08:42 PM
