Old 08-11-2012, 12:15 AM   #1
ppayer38
Member#: 234407
04 Self-tooned
STi
Default FP 71HTA turbo discussion
Have noticed that FP is changing round there turbos again and getting rid of a few choices and adding new
Looking to see if anybody has checked it out or what they have to say about it....
ppayer38 is offline   Reply With Quote
Old 09-03-2012, 11:38 PM   #2
8thWonder
Member#: 230366
2005 STi
Cobb Pro-Tuned
bump for interest
8thWonder is offline   Reply With Quote
Old 09-03-2012, 11:49 PM   #3
ppayer38
Member#: 234407
04 Self-tooned
STi
I called FP about it and found out the real deal with this turbo...
The old 68HTA had a 68/68 compressor wheel and the new 71HTA has a 71/68 wheel.
Basically the compressor wheel is bigger now and matches the DSM style 68/71HTA. The only difference is the DSM style is a bigger compressor housing. Not sure of they will offer the bigger housing on the Subaru platform or not.
Old 09-03-2012, 11:50 PM   #4
WhatTurboLag?
Member#: 243992
2006 WRX TR
Damn I want to see how it does especially with the flow advancement port cover. I want to hear it!!!!
Old 09-03-2012, 11:53 PM   #5
WhatTurboLag?
Member#: 243992
2006 WRX TR
And no 10 cm hot side
Old 09-05-2012, 03:44 PM   #6
Kastley85891
Member#: 127704
2013 Leggy
Scooby no4 - huntin for 5
Id like to run it, but I'm too tight to buy
Old 09-05-2012, 05:02 PM   #7
WhatTurboLag?
Member#: 243992
2006 WRX TR
I would but I want the tdo6 anti surge housing and a 10cm hot side.
Old 09-05-2012, 08:20 PM   #8
wrxhard
Member#: 108091
Let's take a 51 lb/min compressor wheel and pair it with a turbine wheel that isn't suited to much more than 40. Then let's saddle it with a small housing too!!!! This thing gonna sell like hot cakes and perform like... Well who cares what it performs like, we're gonna make a killing!!!!!
wrxhard is offline   Reply With Quote
Old 09-05-2012, 08:25 PM   #9
ppayer38
Member#: 234407
04 Self-tooned
STi
I bet it performs better than the old 68HTA and if you could get the bigger compressor housing it would help a great deal. 8cm hotside is plenty for out cars...
Old 09-05-2012, 08:36 PM   #10
wrxhard
Member#: 108091
With a Properly sized wheel? You bet it is. Doesn't matter how much the compressor will flow if the hot side can't let it get back out.
Edit: remember how the td05 fp greens performed? No? Cuz there where none. Why? Cuz it would have been a mistake. And now this wheel flows MORE air than a green and it's ok because it'll fit in the compressor housing? Sorry, I don't buy it for a second.
Old 09-05-2012, 10:01 PM   #11
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Here's one:
Originally Posted by Squidz View Post
Old 09-05-2012, 10:06 PM   #12
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Decent turbo, tuned a couple of them. I would recommend staying away from FP as their customer service has burned a couple of my customers. Their turbos are decent, just terrible customer service.
Full boost at 4500 feet 3600rpms (2.5l 3rd 5speed) 91oct, 340hp mustang
Full boost at 4500 feet 3450rpms (2.5l 3rd 5speed) E85, 410hp mustang
turbo is similar to a dom1.5
907Bum is offline   Reply With Quote
Old 09-05-2012, 10:18 PM   #13
xluben
Member#: 261612
2011 WRX 5 Door
What do you consider "full boost"?
Old 09-06-2012, 07:36 AM   #14
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
........+1
Dr. octagon is online now   Reply With Quote
Old 09-06-2012, 08:35 AM   #15
Kastley85891
Member#: 127704
2013 Leggy
Here's one:
Thats decent
Old 09-06-2012, 11:49 AM   #16
WhatTurboLag?
Member#: 243992
2006 WRX TR
For a 2.5 it wouldn't be. It seems to be a 2.0 turbo :/
Old 09-06-2012, 03:23 PM   #17
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Seems to work fine on my 2.5 (my car is no longer a 2.0L)...check out my dyno graph above. This was the first one of these turbos out of the gate for the Subies (they have been doing this for evos for a while). I will have the build thread up hopefully tonight or tomorrow...sorry it's taken so long.
The car makes a full bar of boost by 3400-3500 rpm and full boost at 3900-4000...on top of that, it made 426 HP at only 22 psi. We ran out of fuel. This turbo is designed to be run at 26-27 PSI, on E85 and Calvin (at Cobb Plano) said that it easily has 470-475 with a bigger injector.
You can doubt it all you want, but the proof is in the dyno graph.
Squidz is offline   Reply With Quote
Old 09-06-2012, 03:30 PM   #18
xluben
Member#: 261612
2011 WRX 5 Door
I would say that it looks to perform very similarly to a Blouch 20G XTR or Dom1.5 XTR.
Old 09-06-2012, 03:39 PM   #19
Squidz
Member#: 142608
2003 Sonic Yellow
Seems to be a bit closer to the 1.5XTR. I think this thing will ultimately make more power than the 20g will. Wish i hadn't run out of injector so we could have really pushed it.
By the way, if anyone is interested mine does have the flow advancement port.
Old 09-06-2012, 05:37 PM   #20
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Here's one:
That actually looks pretty good on a 2 liter. Much better than I would have expected from big compressor / small turbine.
Old 09-06-2012, 05:46 PM   #21
Squidz
Member#: 142608
2003 Sonic Yellow
*sigh*
It's not a 2 liter engine.
Old 09-06-2012, 06:07 PM   #22
WhatTurboLag?
Member#: 243992
2006 WRX TR
The dam/evo ones have a bigger compressor housing. And a bigger hot side.
Squids did yours have the flow advancement port cover???
Old 09-06-2012, 06:55 PM   #23
Squidz
Member#: 142608
2003 Sonic Yellow
Yeah, it does.
Old 09-06-2012, 06:56 PM   #24
ppayer38
Member#: 234407
04 Self-tooned
STi
Yes his did so you can get that but your stuck on an 8cm housing
Old 09-06-2012, 07:01 PM   #25
WhatTurboLag?
Member#: 243992
2006 WRX TR
Can you make a video of how it sounds by any chance??? I'm really interested in hearing it
Message Board Statistics All times are GMT -4. The time now is 05:19 PM.
