Old 09-03-2012, 08:51 PM   #1351
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Thx for all the kind words. here's the finished mock up with my accusump. just need to paint the trunk and she's done.
They also did a few custom parts in the bay, made the IC pipes and designed the fuel system!
waynoSTI is offline   Reply With Quote
Old 09-03-2012, 09:05 PM   #1352
Tmangt650
Member#: 277258
2008 Hatch 2.5i
Drooooooollll
Tmangt650 is offline   Reply With Quote
Old 09-03-2012, 09:08 PM   #1353
Pearly_Whites
Member#: 164714
2007 WRX TR
Whoa!
Pearly_Whites is offline   Reply With Quote
Old 09-03-2012, 09:40 PM   #1354
garudatwo
Member#: 322385
That is absolutely insane! If I saw that cruising down the street I'd flag you down and ask to have my picture taken with it.
garudatwo is offline   Reply With Quote
Old 09-03-2012, 10:42 PM   #1355
Chasewrx
Member#: 290616
Originally Posted by Celtric
Something similar as i did?
I discontinued though
Need more spare time, my cluster is quite clean anyway atm.
Like that blue shift boot. Did you do it tour self? Have a write up?
Chasewrx is offline   Reply With Quote
Old 09-03-2012, 10:45 PM   #1356
garudatwo
Member#: 322385
Also, what are those gauges that you've mounted in front of your gauge cluster?
Old 09-04-2012, 12:04 AM   #1357
gregroot198521
Member#: 280844
2006 STi
This. That setup looks pretty clean.
gregroot198521 is offline   Reply With Quote
Old 09-04-2012, 01:11 AM   #1358
ppayer38
Member#: 234407
04 Self-tooned
STi
So here is the hood vent I made a while back when I switched to a FMIC...
Well I don't think a Subaru looks right without a hood scoop on it so I'm making a few changes to keep the hood scoop but use it as a vent
Here's a sneak peak...
Here's the vent I had before just incase anybody is curious...
ppayer38 is offline   Reply With Quote
Old 09-04-2012, 12:20 PM   #1359
Serkan
Member#: 180514
2004 Sti
I don't think that setup will work. The front opening of the hood scoop needs to be blocked off and you should make a vent behind the hood scoop (facing windshield). Just my opinion to make it functional.
Serkan is offline   Reply With Quote
Old 09-04-2012, 01:12 PM   #1360
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
+2, but I don't think you need to block off the front of it, just open up the rear of it.
BeBop86 is offline   Reply With Quote
Old 09-04-2012, 01:15 PM   #1361
ppayer38
Member#: 234407
04 Self-tooned
STi
And now you get to see the finished product
[quote=ppayer38;37967950]So here is the hood vent I made a while back when I switched to a FMIC...
Here is the finished prodict to utilize the front opening to keep the stock look of the hood scoop but with the Vent I made under it and the homemade vent in the back of it to let the air flow through and out.
With the way the vent is shaped it in theory cant go in the hood in any way, shape, or form, and will continute to flow out. this also protects against water going into the vent which everybody alwasy is concerned about...
Will add photos in a bit when photobucket stops acting up!
Old 09-04-2012, 01:16 PM   #1362
garudatwo
Member#: 322385
Neg on the photos! Very interested in them though!
Old 09-04-2012, 08:48 PM   #1363
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Originally Posted by Tmangt650 View Post
Drooooooollll
Originally Posted by Pearly_Whites View Post
Whoa!
thx guys. i would gladly stop and take pics.
Also the vent is something i was planning on doing with my track hood. it's a great idea, but i've read that blocking it off completely works best and ducting the sides of the rad so all the air goes into it and not around it....
Old 09-04-2012, 08:57 PM   #1364
theoutbackdream
Member#: 301179
2013 WRX Limited
now im curios how efficient the TMIC is with that mod.. should be interesting
theoutbackdream is offline   Reply With Quote
Old 09-04-2012, 09:19 PM   #1365
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
He did the mod because he switched to a FMIC
Old 09-04-2012, 09:33 PM   #1366
theoutbackdream
Member#: 301179
2013 WRX Limited
ah sorry i didnt read the post. I thought he quoted someone else.
Old 09-04-2012, 09:50 PM   #1367
ppayer38
Member#: 234407
04 Self-tooned
STi
Yeah a TMIC wouldnt work well at all haha...
So far the vent without the scoop worked best and I did see a decrease in temp all around. String tested the Hood sccop/Vent and it works as it should just havent gotten any #'s on a log yet...
Also Im working on an idea to seal the FMIC to the Radiator and the Radiator to the car to maximize the airflow throught them
Old 09-04-2012, 09:50 PM   #1368
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Originally Posted by ppayer38 View Post
Looks good!! Try taping some pieces of yarn at the bottom and top of the opening and drive around to see if airflow is actually coming out of it.
Like this article: http://autospeed.com/cms/title_Ultim...0/article.html
Old 09-04-2012, 10:21 PM   #1369
ppayer38
Member#: 234407
04 Self-tooned
STi
Already done and it works as it should with venting the air out of the engine bay...
Old 09-05-2012, 10:54 AM   #1370
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
A little project I'm working on. Custom plate delete for the front of my car. Didn't really want to pay ~$50 for a little piece of metal. Currently it is designed as 10 GA steel. This is a prototype for fitment purposes. Just sent it down to the laser, hopefully have it some time this week.
Final design will most likely be 6063 or 5052 Aluminum, not sure on thickness yet. Whichever we have on hand.
Edit: Aluminum for sure, as the steel part will weigh over a half a pound.
I'd say it's unique, as it's my name (in the Subaru font). Custom, hell I designed the thing
JSchell1309 is offline   Reply With Quote
Old 09-05-2012, 11:07 AM   #1371
PurpleDoors
Member#: 225582
2002 VF39'd EJ205
BRP RS Sedan
Looks neat. Yay, SolidWorks!
PurpleDoors is offline   Reply With Quote
Old 09-06-2012, 03:59 PM   #1372
JSchell1309
Member#: 321321
Tuxedo Black
Just got it back from the laser. Just have to file off the burrs, primer, and spray it. Haven't got to test fit it yet.
Old 09-06-2012, 04:08 PM   #1373
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Powder coat it...
cianuro is offline   Reply With Quote
Old 09-06-2012, 04:14 PM   #1374
JSchell1309
Member#: 321321
Tuxedo Black
Originally Posted by cianuro
Powder coat it...
I could, we have a powder line here that we run black on every now and then. This is just a prototype, as it's out of steel and weighs a half a pound. If I like the way it looks I'll make it out of aluminum and powder it black.
Old 09-06-2012, 04:34 PM   #1375
Devon
Member#: 321595
2005 Legacy GT
I would buy one!
Devon is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
