Old 07-31-2012, 09:00 AM   #1
busyychild
Member#: 270571
Default DIY: GR - Alternate/Oldschool Horn Install Location w/ SickSpeed Horns
My most recent project was to install some hella horns in my GR Sedan. I initially bought Hella Panther horns, I personally did not like the tone and color. Decided to give the SickSpeed horns a shot. When I installed the Hella's I used a home made bracket that bolted in the center support in the grill. It didnt seem all that stable, was hard to hide the wires, so I decided to go the oldschool route of mounting them on the radiator support beam using the preexisting holes.
I used 12awg wires throughout the entire setup w/ a 20amp mini fuse on the hot wire to the relay.
I used the center bolt on the center support for the ground. I will eventually move it to the horn mounts for a complete no wire seen install.
You have to pop out the plastic mount for the hood release cable on the drivers side where you will mount the horn. So far I have not found any problem with leaving the cable free/hanging at that location. The cable is pretty taught on its own.
Overall I like the tone better on the SickSpeed horns. Much deeper and seem to be louder. I haven't been on the receiving end of the horns so I cannot tell for sure. I will eventually remove the secondary OEM horn as it sounds funny in concert with the new horns.
(Pro tip: Pin 86 on the relay is for the horn signal wire. The instructions from SickSpeed are wrong.)
(Pro tip 2: Click the images to make them larger.)
  • Hella Panther vs. Sickspeed (you can see the size difference)
  • Parts needed for mounting, if I recall 8mm or 10mm self locking nut/bolt with rubber and metal washers.
    (Order of install: bolt/metal washer/rubber washer/radiator support/rubber washer/horn/metal washer/nut)
  • Mounted
(poor bumper :crying
  • Horn ground
  • All buttoned up
  • Mean smile
  • Wiring (tucked+ran between the radiator foam and the radiator support)
busyychild is offline   Reply With Quote
Old 07-31-2012, 09:00 AM   #2
busyychild
Member#: 270571
  • Relay mount location (used a metal and rubber washer to seal moisture from getting through that hole I bolted it through)
  • Horn signal wire
  • The rest of the photos can be found here:
SickSpeed pictures by busyychild - Photobucket
Old 09-04-2012, 10:21 PM   #3
sars101
Member#: 280420
2005 2.5 rs
silver ish
i like the grill look on the horns
hellas are to much just for the look
any sound clip from a subaru
sars101 is offline   Reply With Quote
Old 09-04-2012, 11:25 PM   #4
busyychild
Member#: 270571
The sickspeeds are $34 shipped on ebay. Hard to beat that. I will try and take a sound clip/video this week.
Old 09-05-2012, 02:04 AM   #5
DONx3
Member#: 214050
2007 WRX
What's the difference between the panther and supertones?
DONx3 is offline   Reply With Quote
Old 09-05-2012, 07:34 AM   #6
busyychild
Member#: 270571
Color, size, tone, and loudness.
Supertone:
http://www.hella.co.in/Product.aspx?Id=113
Panther:
http://www.hella.co.in/Product.aspx?Id=114
