Old 07-28-2012, 11:15 PM   #2501
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by vicious_fishes View Post
no ****?
not sure what you're trying to say here?
(though iirc the 5 speeds are virtually unchanged since like 87 or something...)
I'm saying the 09 tranny is not the same as the 02 tranny. Is that clear enough for you?
Originally Posted by Uncle Scotty View Post
what is good for the 07+ may not be good fot the others
Bingo.
Superorb is offline   Reply With Quote
Old 07-29-2012, 02:20 AM   #2502
vicious_fishes
Member#: 158864
2003 SOHC destroker
the gear 300 is DIFFERENT
and lets NOT mix up our metaphores here....or our products
ok but the gear 300 is full synth... hence my confusion.
Old 08-23-2012, 07:02 AM   #2503
fahr_side
Member#: 255190
'08 WRX. Temps here run 15*C~35*C. I've been running Redline 75W90 MT-90 for 50,000km and just started to get grinding going into second. I just changed the tranny fluid 10,000km ago.
I can get Redline shockproof and Shell Spirax 80W90 which it seems is an acceptable alternate to the Castrol.
Castrol Hypoy C, 80W90 and Pennzoil 75W90 Synchromesh are are unavailable to me. I can get Agip, Repsol, Pennzoil, Torco or Valvoline 75W90 synthetics but I'm guessing they're only as good or bad as the Redline.
If it's the synthetic nature of these fluids that's the issue I can however get non-synthetic Torco MTF, or some off-brand 75W90 or 80W90 dino gear oils.
Suggestions as to which would be better to finish off a cocktail? I still have 2qts of Redline 75W90 left over.
Spirax HD
Redline Shockproof
Profit
fahr_side is offline   Reply With Quote
Old 08-23-2012, 11:38 PM   #2504
TropicalReefer
Member#: 321634
2005 Wrx 2.0
I've been to about a half dozen stores looking for the Castrol 80w90, I can't seem to find it anywhere. I found Castol Hypoy C 80w90 and got excited and bought it, but I took it back because it had limited slip written on the front. Should I fork out the extra cash for shipping and buy it online? Or does anybody know a retailer that carries this elusive oil?
TropicalReefer is offline   Reply With Quote
Old 08-24-2012, 12:14 AM   #2505
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Spirax HD
Redline Shockproof
Profit
just do the spirax and shockproof...the HEAVYWEIGHT SHOCKPROOF.....NOT THE LIGHTWEIGHT
and the synchromesh has NO 'weight'....it is JUST 'synchromesh'
Old 08-24-2012, 12:18 AM   #2506
Uncle Scotty
OK buy Nates beans
apparently....they do not make the 'hypoy c' anymore
you found the 'new' product i guess
Old 08-24-2012, 12:54 AM   #2507
fahr_side
Member#: 255190
Thanks Scotty. What ratio would you use if it's Spirax and HDSP, 2:1?
Old 08-24-2012, 12:57 AM   #2508
TropicalReefer
Member#: 321634
2005 Wrx 2.0
Is this new stuff safe considering it has a limited slip additive? I heard to steer clear of anything with 'limited slip' written on it.
Old 08-24-2012, 02:10 AM   #2509
Uncle Scotty
OK buy Nates beans
a litre of the shockproof should do....spirax to fill
Old 08-24-2012, 02:11 AM   #2510
Uncle Scotty
OK buy Nates beans
i have no data on that
Old 08-24-2012, 02:16 AM   #2511
TropicalReefer
Member#: 321634
2005 Wrx 2.0
Ok thanks, any suggestions on what I could use in place of the Castrol? I already have the synchromesh and and redline shockproof.
Old 08-24-2012, 02:35 AM   #2512
fahr_side
Member#: 255190
Thanks!
Old 08-25-2012, 08:59 AM   #2513
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Ran the original Cocktail years ago and loved it despite the limited service life (started feeling "tired" after ~12K miles).
Did two fills of the Extra-S since then and liked it, but was interested in the "new" formula.
Just under 2K miles on the RL HW Cocktail, and it's niiiiiiice.
Thanks, Scotty!
Spenk is offline   Reply With Quote
Old 08-25-2012, 03:41 PM   #2514
Uncle Scotty
OK buy Nates beans
Thanks, Scotty!
yet another happy camper....and the HW is much better than the LW, no doubt
Old 09-02-2012, 10:57 PM   #2515
subynube
Member#: 63442
Thanks, Scotty!
What is the "new formula?" Is it just the heavy weight instead of the light weight?
I live in Vermont, and it often gets to -20F, and occasionally -30F in the winter. Just want to make sure that this heavy weight would not bee "too" heavy or viscous.
I'm interested in this cocktail. I had a recent unknown fluid replacement, and now have a 4th gear grind. Hoping this cocktail takes care of it.
Thanks all, looking forward to trying this stuff!
subynube is offline   Reply With Quote
Old 09-03-2012, 03:30 AM   #2516
Uncle Scotty
OK buy Nates beans
i know the v2 cocktail works well down to the 20'sF....it IS a bit stiffer than it is when it is 80*F but cold mechanical devices are just gonna not be the same as warm ones
so dont expect them to be
go red the specs on the shockproof and figure it out...
Old 09-03-2012, 10:39 AM   #2517
subynube
Member#: 63442
Thank you for the reply! The specs for the lightweight specifically suggest that it has a unique ability to be used in vehicles in very cold weather. It does not say that about the heavy stuff. So I probably would go with the lightweight.
Is the only difference between version 1 and version 2 cocktail the weight of the shockproof? Thanks.
Old 09-04-2012, 11:44 PM   #2518
Uncle Scotty
OK buy Nates beans
thought the v2 with the heavyweight was BETTER when cold...than the v1 was
Old 09-05-2012, 05:57 PM   #2519
Wavespy
Member#: 280552
2004 WRX wagon
Thumbs up Wouldn't have believed it!
Just tried it in my '04 WRX wagon. At about 72,000 mi. my 4th gear synchro was crunching like a bag of Doritos. I was sure I would have to just live with it or delve into a huge PITA tranny repair. I would never have believed a gear oil change would quiet things down in there, but I was wrong. Had to go to 5 stores around west Denver to find it all, but well worth it!
I was a bit freaked out when the Shockproof came out of the bottle Valium BLUE!
Wavespy is offline   Reply With Quote
Old 09-05-2012, 06:15 PM   #2520
subynube
Member#: 63442
Well I'm happy to take your word for it. I'm just quoting the lightweight specs:
"A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures."
The most it says about the heavy specs:
"High viscosity-index (VI) to provide relatively constant viscosity and film thickness with varying temperature change."
The heavyweight may be more viscous, and therefore worse for extreme cold? Remember, Vermont gets to -20 to -30 (Below zero).
Old 09-05-2012, 06:36 PM   #2521
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Where did you find each item around Denver?
Old 09-05-2012, 09:29 PM   #2522
Uncle Scotty
OK buy Nates beans
i dont think id even consider the lightweight shockproof after having used the heavyweight for 2 changes, now
Old 09-05-2012, 09:39 PM   #2523
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
How often do you replace your tranny fluid?
Old 09-09-2012, 02:49 AM   #2524
jhayesvw
Member#: 326502
2003 WRX Wagon
my head is spinning.
for my 03 wrx 5 speed it looks like
1qt redline heavyweight shockproof
1qt pennzoil syncromesh
about 2 qt castrol dino oil 80w90 (NOT for limited slips)
I have no shifting issues at all and 72k miles on my car.
what do you all think?
jhayesvw is offline   Reply With Quote
Old 09-09-2012, 03:06 AM   #2525
Uncle Scotty
OK buy Nates beans
depeneds on what im feelin like....and if i wanna try something new
since i had my 02 wrx???
mmmmmm....ive probably tried at least 15 'cocktails'
the 06???
this will be the 4th or 5th change here at 100k this month...a couple only lasted a few k miles before i knew they didnt work
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 05:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 11:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 05:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 09:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 09:36 AM
