Old 09-05-2012, 07:00 PM   #1
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default 526 wheel HP at 21 psi, playing with a stock shortblock
Dyno: Innovative Tuning's Mustang AWD 500 SE
Tuner: Mike McGinnis at Innovative Tuning
Wheel HP: 526
Wheel TQ: 457
Ambient Temp: 90 F
Elevation: ~700
Highest baseline wheel HP when stock: 230 whp for 08 STI stock (2012+ dyno settings)
Highest baseline wheel TQ when stock: 240 whp for 08 STI stock (2012+ dyno settings)
Car Info
Year: 96
Engine Management: ViPec
Turbo: 6765
Intercooler: Innovative Tuning custom water/air
Meth Kit: none
Injectors: 2200cc
Intake/Inlet: 4" air filter on turbo for now
Headers: Innovative Tuning custom
Uppipe: Innovative Tuning custom
Downpipe: Innovative Tuning custom
CBE: Innovative Tuning custom aluminum
Other Power Mods: OEM Subaru 2.5L shortblock straight out of the box from Subaru, never taken apart. The rest of the car isn't stock.
I'm just having a little fun with my time attack build. I saw the Subaru stock shortblock drag record wasn't flattering and I figured I'd make some power on a stock shortblock and see what my time attack car can do at the strip while we're slowly making progress on aero and other road racing related parts.
I stopped at 21 psi and pretty conservative timing for E85 because I don't want to push the stock shortblock to the breaking point.
When I'm done horsing around with the stock shortblock we'll put one of our built shortblocks in and I'm expecting 650-700 wheel HP at ~30 psi.
Innovative Tuning is offline   Reply With Quote
Old 09-05-2012, 07:31 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Wow!!
Nice curves!
Old 09-05-2012, 08:07 PM   #3
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Nice, I'd like to see that turbo turned up and see what it can really do. How is the spool on the 67? I'm putting the 6466 on my hybrid build.
Btw what is the highest stock block hp anyone know?
spoolinred is offline   Reply With Quote
Old 09-05-2012, 08:11 PM   #4
wagonator
Member#: 207425
05 wrx wagon : )
wrb
Awesome results! Can't wait to see what you can get out of it with the built block
wagonator is offline   Reply With Quote
Old 09-05-2012, 08:16 PM   #5
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Thanks folks.
Spoolinred the pink line and scale on the right of the graph is boost. It would spool sooner with aggressive boost control settings, but I just set a flat duty cycle for now.
I'd rather not know what the stock block HP record is because I'll probably do something silly and try to break it.
wagonator I'm expecting 650-700 wheel HP at 30 psi based two similar setups I've tuned before.
Old 09-05-2012, 09:50 PM   #6
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Originally Posted by Innovative Tuning View Post
Thanks folks.
Very nice Mike!!
I have my 6766 in my backpack as we speak traveling home from P&L. I see we have the same basic idea, I have a stock block with some headgames heads going in my GC. Trying to see how far it can go in a lite weight. The XT went 108 1/8th with the stock block @ 3500lbs. So I can imagine trapping in the 140s will happen.
Good luck!
Old 09-06-2012, 12:05 AM   #7
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
double post
Old 09-06-2012, 12:08 AM   #8
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Sounds good. I think I'd be faster with a 6262 especially since I'm not revving it out or flat shifting, but the 6765 is what I run and I'm not swapping it for this. When the built shortblock goes in the 6765 will be loving life.
Old 09-06-2012, 08:53 AM   #9
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Nice job! It's the Torque mainly that kills the Liners, etc. if you keep Torque below the danger level (+/- 450-500lb/ft) you can make plenty of power without the cylinder pressures becoming too large.
We have also gotten some high power figures out of stock blocks and to do so we have used a tapered boost (low to high) profile. I think you can ramp the boost up from 6000 rpm going to redline to lift the torque there and power figures accordingly.
Anyways... it's a good result you have there already. More boost at redline would just be icing on the cake
Jasper.
jkopinga is offline   Reply With Quote
Old 09-06-2012, 09:13 AM   #10
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
We've run a lot more power than this on stock liners so I'm not worried about them.
I won't rev it out and I'm not loading the rods heavily at low RPMs so I think they'll hang in there, but I don't know if the hardware will.
My chief concern is the tight ring end gaps Subaru uses and my second biggest concern is the tight piston piston to wall clearance. I've done what I can to reduce cylinder heat within reason, but at more than double stock power, heat will be well beyond what Subaru intended.
Old 09-07-2012, 03:13 PM   #11
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
mustang dyno numbers to impressive mike.
spoolinsti05 is offline   Reply With Quote
Old 09-07-2012, 03:56 PM   #12
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
^^Yes I agree!! This is impressive power for a stock block Mustang plot!!
Old 09-07-2012, 05:14 PM   #13
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
well **** me! thats just great, all in for experimentals
Old 09-07-2012, 11:08 PM   #14
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I took it to the track today. Unfortunately I blew an axle the first time I powered out of a corner on my first lap. It whipped around and hammered the rear subframe so we have some repairs to make. We'll get it on track soon.
Old 09-07-2012, 11:16 PM   #15
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
That's crazy im pushing 450 wheel @22psi on my stock block lol.
07wrx84 is offline   Reply With Quote
Old 09-08-2012, 03:40 AM   #16
jesseber
Member#: 293509
2004 WRX STI
I feel so much better about beating on my 350wheel built motor lol.
jesseber is offline   Reply With Quote
Old 09-08-2012, 10:04 AM   #17
snake32
Member#: 167338
02 Silver dollar
07wrx84, what's your mods?
snake32 is offline   Reply With Quote
Old 09-08-2012, 12:49 PM   #18
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
All bolt on imaginable! Running E85 with 20gxt turbo. Way aggressive timing object my tune, and running speed density with gasoline afr 12.0ish! Tuned the tq down it was killing my clutch! Took out some avcs and lil boost pound or so!
Old 09-09-2012, 01:39 AM   #19
FatTurbos74
Member#: 331602
Thumbs up!
FatTurbos74 is offline   Reply With Quote
Old 09-10-2012, 04:13 PM   #20
GT35RHybrid
Member#: 223237
Topspeed did a stock block up to 590hp a while back....it was a beast.
http://forums.nasioc.com/forums/show...hlight=burnin4
GT35RHybrid is offline   Reply With Quote
Old 09-10-2012, 05:24 PM   #21
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
That's crazy!
Old 09-10-2012, 07:17 PM   #22
soobwagJJC
Member#: 288218
2007 Imp Wag WRX
black
wow i need this
soobwagJJC is offline   Reply With Quote
Old 09-10-2012, 10:09 PM   #23
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
what clutch is this car running?
Old 09-10-2012, 10:59 PM   #24
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I want to know what fuel pump, idc, and base pressure?
Too much to ask? Sorry = (
wrxsubiemod is offline   Reply With Quote
Old 09-10-2012, 11:05 PM   #25
teesutt
Member#: 127940
Evil shenanigans
thats awesome. my pseudo stock block (drop in pistons, stock rods) broke a rod at 520whp on e85. shredded the cases.
teesutt is offline   Reply With Quote
