#6226 | |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
#6227 | |
Member#: 165104
SCIC
Vehicle:E85 bug-i sti swap Phatron tuned |
#6228 |
Member#: 183480
South East
Vehicle:2011 Audi A3 Quattro 2009 Forester XT |
welcome to the club Squidz...what are the details on your setup?
#6229 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
Trying to get the build thread together...here's the cliff notes:
EJ25 forged pistons/rods (9.2:1 compression) USDM EJ20 heads/ CNC combustion chambers/Supertech springs/STi cams Brand new 8cm FP HTA71 turbocharger (first one ever built...car was a test mule) Internal WG 84mm FP Inlet ETS Top-mount intercooler IDE 1000 cc DW 300 LPH fuel pump GT Spec UEL Header Cobb Tuned |
#6230 |
Member#: 183480
South East
very nice!
are you planning to upgrade the fuel system or are you going to let it ride as is for now? |
#6231 |
Member#: 252195
RMIC
Vehicle:07 WFC #900 @ 451awhp-404awtq |
Way nice bro!
#6232 | |
Member#: 149262
MWSOC
Vehicle:2003 03WRXw6sp/05FXT PSM |
Plan on Doing similar build |
#6233 |
Member#: 292343
SCIC
do i have to completely drain my gas tank if im going to get tuned for e85? or would 1/8 tank (near empty) be alright?
#6234 | |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
#6235 |
Member#: 239945
MWSOC
Vehicle:06 STi GTX3576R CGM |
To be on the safe side you can drain the tank. But you can just run it down past the empty line and you will be fine. Make sure to test the ethenal content of the E85 when you fill up.
#6236 | |
Member#: 48377
MWSOC
Vehicle:1996 Gutted, built XP class Impreza L |
If you want a safe tune, 1/8 tank of gas +7/8 tank of E85 would make it pretty safe for a tune as long as your tuner knows what they are doing. In the winter some areas get E70 blend to help cars start in the cold, so 1/8th tank of gas may represent your "worst case" winter blend. |
#6237 | |
Member#: 142608
TXIC
http://www.cobbtuning.com/Dyno-Database-s/70119.htm It's under Cobb Plano, 2003 WRX, owner is Shawn Rizzo |
#6238 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
#6239 |
Member#: 142608
TXIC
^^ Thanks! How did you do that? I kept trying to use the image link and it wouldn't work.
#6240 |
Member#: 261612
#6241 |
Member#: 270482
Vehicle:2011 forester xt corn fed td06 20g 8cm |
So i thought i would post in here befor i start a thread asking were i can get e85 near englishtown nj. I am planning to go to englishtown for the sti vs evo day but i live in albany ny and it is about 180 miles each way. I see there are no e85 station in nj and i cant find any stops along the way there so i was wondering if they sell e85 at englishtown raceway? If not what would be my option filling up multiple 5 gal jugs full for the drive lol?
#6242 |
Member#: 252195
RMIC
Sounds too much outta the way!
#6243 |
Member#: 273440
Vehicle:2011 WRX Silver |
Can anyone tell me if I should be running colder plugs....I have a 2011 wrx, stock turbo running 17 psi, 1000 cc dw injectors, and a dw65c fuel pump. I've been running E85 for a couple weeks and made good power for having a stock turbo and inter cooler (306/359). I get a little hard starting when the car is already warm but runs good otherwise....any advise will help!
#6244 | |
Member#: 172698
MWSOC
Vehicle:11 STi Stg2 E85 02 v8 Spec C E85 |
The rough hot starts have to do with hot start enrichment. For whatever reason, the stock tuning targets rich AFRs during hot starts, probably to help with evaporation or something. Gasoline doesn't mind running really rich like that but E85 will run rough and misfire. It should normally clear up after 15 seconds or so. If you are Cobb tuned, your tuner should be able to disable this enrichment, if you are Open Source tuned then it should be possible very soon as the definitions for these tables are being defined. I've been testing them on my own car. |
#6245 | |
Member#: 107554
Tri-State
Vehicle:03 03/07 yellow |
#6246 | |
Member#: 129833
Tri-State
Vehicle:2005 Forester XT Obsidian Black Pearl |
#6247 | |
Member#: 252195
RMIC
#6248 |
Member#: 273440
Thanks everyone, I appreciate the info
#6249 |
Member#: 142608
TXIC
Hrmm...i'm running colder plugs in mine. Anyone had any issues with idle using colder plugs? Wonder if that could be the issue.
Makes sense though that E85 burns so much cooler you don't really need the colder plugs... |
#6250 |
Member#: 284835
Vehicle:2010 450+whp DGM STI DOM2.5/e85/Phatron tuned |
I've been on stock iridiums for over a year, and no prob...
| Thread Tools | |
| Display Modes | |
| Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
| jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
| The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
| Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
| Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
