Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Closed Thread
Old 09-05-2012, 09:06 PM   #2776
midnightflo
Member#: 324386
02 Impreza RS
yup like half can per tire
midnightflo is offline
Old 09-05-2012, 09:12 PM   #2777
burton8913
Member#: 275056
07 civic
ugm
Originally Posted by midnightflo
all done
that looks sick
burton8913 is offline
Old 09-05-2012, 09:18 PM   #2778
midnightflo
Member#: 324386
02 Impreza RS
thanks guys, colin im getting a radio is it just like unpluggin one deck and putting wires in same slots in new deck?
Old 09-05-2012, 09:44 PM   #2779
Pearly_Whites
Member#: 164714
2007 WRX TR
Crutchfield and get the specific harness adaptor. Then wire cap everything together. Plug it in and go
Pearly_Whites is offline
Old 09-05-2012, 09:50 PM   #2780
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Best buy has the subaru harness in stock. Like 15-20 bucks.
Im off tomoro if you want me to do it for you. Won't take me long at all
J.Gibbs is offline
Old 09-05-2012, 11:19 PM   #2781
castper
Member#: 300342
Who wants to play Name the gasket?
On the top of the valve cover and it's leaking a little oil
castper is offline
Old 09-05-2012, 11:22 PM   #2782
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Is it from where the hose clamps?
J.Gibbs is offline
Old 09-05-2012, 11:36 PM   #2783
castper
Member#: 300342
the leak? I don't think so but i guess i can take a closer tomorrow or friday, i've had work every day since last friday and have it tomorrow too so i cant go to the meet but anyway all i know is it looks like it's leaking from the gasket and it started after i changed my valve cover gasket.
castper is offline
Old 09-06-2012, 07:06 AM   #2784
MaddSubieLove
Member#: 108258
Great way to start my day.........
Driving on route 2 and a huge paving truck in front of me hits a bump and a HUGE glob of tar or something came off of it and was bouncing all over the highway. I swerved to avoid it and it hit my bumper/foglight directly and cracked it in half and scratched my paint.... FML!
Oh and my clutch feels like it is going and it squeaks whenever I push the clutch in. Does that mean I need to tighten my clutch cable or spray it or anything? Never really had many clutch problems so I am fairly unfamiliar with them. Any help would be appreciated.
Going to put my winter car search into overdrive now. I got too many problems with the bugeye so the second I get my winter/commuter car on the road I am putting the bugeye into storage. Sucks but I can't afford to fix the damn thing right now and its one thing after another lately with it. Car hits 10 years old and just wants to **** with me now I guess.
MaddSubieLove is offline
Old 09-06-2012, 08:07 AM   #2785
SillyGarageToys
Member#: 294620
2000 Impreza RS
Grey
Sue the government! Lol
For the squeak it could be as simple as the joint where the pedal and the push rod meet, or could just be any other joints like the slave cylinder pushing on the fork, or the fork pivoting on the tranny or the bearing moving up and down on the shaft. A squeak doesn't necessarily tell you that your clutch is bad, a bad clutch is when your springs stiffen, start to loose grip especially on high revs, or worse case you can't shift when you depress the clutch. I wouldn't sweat it. Just try lubing the slave to fork joint you might have to remove the slave to actually get between them use bearing grease or white lithium would work decently as bearing grease. And for the pedal use white lithium or silicone spray. Hope this helps :O
SillyGarageToys is offline
Old 09-06-2012, 08:18 AM   #2786
skullygurl11
Member#: 214240
2005 WRX
Yesterday morning when I left for work I noticed that my oil light was faintly on... I checked the oil and it seemed fine. ( I am concerned because I got in an accident about 2 weeks ago and i dont know if it could be from that although the only things that got replaced were the front bumper, hood, headlights and radiator support) Started driving and it went off. Is this an indication that I need a sensor or that my oil pump is going or something? Is there a way to test it or just wait until it goes?
skullygurl11 is offline
Old 09-06-2012, 08:37 AM   #2787
vision.dynamix
Member#: 139955
# OneBoston
Usually this means a failed pickup tube, but if that were the case your motor would already be toast.
It could be that your sensor (under the alternator) is making a faulty connection.
The factory oil pressure light is set to come on at 2-3psi. Generally, by the time you see the light, the damage is already done. I call it the new motor needed light.
vision.dynamix is offline
Old 09-06-2012, 08:41 AM   #2788
tunertony
Member#: 134331
2011 WRX STi
Where's the meet tonight?
tunertony is offline
Old 09-06-2012, 08:56 AM   #2789
sport6
Member#: 190479
2012 WRX - Blurple
2012 Impreza- Deep Cherry
Originally Posted by MaddSubieLove View Post
[IMG]http://i105.photobucket.com/albums/m209/MaddSubieLove/foglight.jpg[/ IMG]
Squeek when the clutch is in is usually the throwout bearing. Does necessarily mean that its bad as I have seen practically brand new throwout bearings squeek a bit. My 2009 would squeek before it was was 100% warmed up in the morning.
sport6 is offline
Old 09-06-2012, 09:10 AM   #2790
MaddSubieLove
Member#: 108258
Applebees I think.
Old 09-06-2012, 09:17 AM   #2791
MaddSubieLove
Member#: 108258
Thanks man, I will check that out. It just started feeling this way yesterday.
Old 09-06-2012, 09:23 AM   #2792
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Yup applebees tonight. Sterling fair tomorrow night
J.Gibbs is offline
Old 09-06-2012, 09:31 AM   #2793
space0monkey
Member#: 277967
2004 WRX wgn
My pedal is squeaking as well, fairly certain it just needs lube tho. Makes u look silly when first starting tho, its soo loud
space0monkey is offline
Old 09-06-2012, 09:31 AM   #2794
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Jay, you still want those steelies for winter?
J.Gibbs is offline
Old 09-06-2012, 09:47 AM   #2795
skullygurl11
Member#: 214240
2005 WRX
Thanks, So should I see about getting a new sensor first? the light hasn't come back on and like i said it was faintly on for a few minutes. seemed to be running fine and has been since.
Old 09-06-2012, 09:51 AM   #2796
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Definitely check the sensor first... and your oil level.
Im off today but will be at the dealership tomorrow and Saturday. If you need something let me know
J.Gibbs is offline
Old 09-06-2012, 09:55 AM   #2797
vision.dynamix
Member#: 139955
# OneBoston
I would check the connection and wiring. It's a ground switch, meaning if that wire sees ground the light comes on.
IMO every Subaru should have an aftermarket oil pressure gauge added.
Old 09-06-2012, 09:57 AM   #2798
skullygurl11
Member#: 214240
2005 WRX
Thanks! I got the oil checked yesterday on my lunch break and they said that it was full... I will continue to keep an eye on it. I wont be in the area again until this weekend since I moved this past weekend.
What dealership do you work at?
Old 09-06-2012, 10:01 AM   #2799
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
North End
J.Gibbs is offline
Old 09-06-2012, 10:03 AM   #2800
skullygurl11
Member#: 214240
2005 WRX
That makes sense since everything got a little pushed after the accident. I will get it checked out... and look into an oil pressure gauge and replacing the sensor.
Since moving I either need to find a new place to bring her or just drive far to bring it to the dealership I have been going to.
Thanks again!
Closed Thread
HR: Peninsula Meet 11/3 Buffalo Wild Wings 7PM tux2122 Mid Atlantic Impreza Club -- MAIC 46 11-04-2009 05:56 PM
NOVA MEET: Thursday 6/4/09 - Buffalo Wild Wings blubaru703 Mid Atlantic Impreza Club -- MAIC 61 06-20-2009 06:58 AM
Chi: Thursday Borders Meet, 6/26/08 speelnik Mid West Subaru Owners Club Forum -- MWSOC 149 06-30-2008 12:04 PM
SE/Clear Lake Meet - Wednesday 2/2/05 or Thursday 2/3/05 - Buffalo Wild Wings 7:30pm Hotrodguru Texas Impreza Club Forum -- TXIC 11 02-03-2005 04:07 AM
Rochester, NY meet 5pm friday(today) buffalo wild wings joel(PA) Tri-State Area Forum 17 04-25-2004 12:35 PM
Message Board Statistics All times are GMT -4. The time now is 01:11 PM.
