09-05-2012, 09:06 PM | #2776 |
Member#: 324386
Vehicle:02 Impreza RS Black |
09-05-2012, 09:12 PM | #2777 | |
Member#: 275056
Vehicle:07 civic ugm |
09-05-2012, 09:18 PM | #2778 |
Member#: 324386
thanks guys, colin im getting a radio is it just like unpluggin one deck and putting wires in same slots in new deck?
09-05-2012, 09:44 PM | #2779 | |
Member#: 164714
Vehicle:2007 WRX TR Satin White Pearl |
09-05-2012, 09:50 PM | #2780 |
Member#: 312107
Vehicle:1998 LowFoz Glacier White |
Best buy has the subaru harness in stock. Like 15-20 bucks.
Im off tomoro if you want me to do it for you. Won't take me long at all |
09-05-2012, 11:19 PM | #2781 |
Member#: 300342
Vehicle:2002 WRX PSM |
Who wants to play Name the gasket?
On the top of the valve cover and it's leaking a little oil |
09-05-2012, 11:22 PM | #2782 |
Member#: 312107
Is it from where the hose clamps?
09-05-2012, 11:36 PM | #2783 |
Member#: 300342
the leak? I don't think so but i guess i can take a closer tomorrow or friday, i've had work every day since last friday and have it tomorrow too so i cant go to the meet but anyway all i know is it looks like it's leaking from the gasket and it started after i changed my valve cover gasket.
09-06-2012, 07:06 AM | #2784 |
Member#: 108258
Vehicle:2002 WRX/99ForesterS PSM |
Great way to start my day......... Driving on route 2 and a huge paving truck in front of me hits a bump and a HUGE glob of tar or something came off of it and was bouncing all over the highway. I swerved to avoid it and it hit my bumper/foglight directly and cracked it in half and scratched my paint.... FML! Oh and my clutch feels like it is going and it squeaks whenever I push the clutch in. Does that mean I need to tighten my clutch cable or spray it or anything? Never really had many clutch problems so I am fairly unfamiliar with them. Any help would be appreciated. Going to put my winter car search into overdrive now. I got too many problems with the bugeye so the second I get my winter/commuter car on the road I am putting the bugeye into storage. Sucks but I can't afford to fix the damn thing right now and its one thing after another lately with it. Car hits 10 years old and just wants to **** with me now I guess. |
09-06-2012, 08:07 AM | #2785 | |
Member#: 294620
Vehicle:2000 Impreza RS Grey |
For the squeak it could be as simple as the joint where the pedal and the push rod meet, or could just be any other joints like the slave cylinder pushing on the fork, or the fork pivoting on the tranny or the bearing moving up and down on the shaft. A squeak doesn't necessarily tell you that your clutch is bad, a bad clutch is when your springs stiffen, start to loose grip especially on high revs, or worse case you can't shift when you depress the clutch. I wouldn't sweat it. Just try lubing the slave to fork joint you might have to remove the slave to actually get between them use bearing grease or white lithium would work decently as bearing grease. And for the pedal use white lithium or silicone spray. Hope this helps :O |
09-06-2012, 08:18 AM | #2786 |
Member#: 214240
Vehicle:2011 WRX Limited Satin White Pearl |
Yesterday morning when I left for work I noticed that my oil light was faintly on... I checked the oil and it seemed fine. ( I am concerned because I got in an accident about 2 weeks ago and i dont know if it could be from that although the only things that got replaced were the front bumper, hood, headlights and radiator support) Started driving and it went off. Is this an indication that I need a sensor or that my oil pump is going or something? Is there a way to test it or just wait until it goes?
09-06-2012, 08:37 AM | #2787 | |
Member#: 139955
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
It could be that your sensor (under the alternator) is making a faulty connection. The factory oil pressure light is set to come on at 2-3psi. Generally, by the time you see the light, the damage is already done. I call it the new motor needed light. |
09-06-2012, 08:41 AM | #2788 |
Member#: 134331
Vehicle:2011 WRX STi SWP |
Where's the meet tonight?
09-06-2012, 08:56 AM | #2789 | |
Member#: 190479
Vehicle:2015 XV Crosstrek 2012 Impreza- Deep Cherry |
Squeek when the clutch is in is usually the throwout bearing. Does necessarily mean that its bad as I have seen practically brand new throwout bearings squeek a bit. My 2009 would squeek before it was was 100% warmed up in the morning. |
09-06-2012, 09:10 AM | #2790 |
Member#: 108258
Applebees I think.
09-06-2012, 09:17 AM | #2791 | |
Member#: 108258
09-06-2012, 09:23 AM | #2792 |
Member#: 312107
Yup applebees tonight. Sterling fair tomorrow night
09-06-2012, 09:31 AM | #2793 |
Member#: 277967
Vehicle:2004 WRX wgn PSM |
My pedal is squeaking as well, fairly certain it just needs lube tho. Makes u look silly when first starting tho, its soo loud
09-06-2012, 09:31 AM | #2794 |
Member#: 312107
Jay, you still want those steelies for winter?
09-06-2012, 09:47 AM | #2795 | |
Member#: 214240
Thanks, So should I see about getting a new sensor first? the light hasn't come back on and like i said it was faintly on for a few minutes. seemed to be running fine and has been since. |
09-06-2012, 09:51 AM | #2796 | |
Member#: 312107
Im off today but will be at the dealership tomorrow and Saturday. If you need something let me know |
09-06-2012, 09:55 AM | #2797 | |
Member#: 139955
IMO every Subaru should have an aftermarket oil pressure gauge added. |
09-06-2012, 09:57 AM | #2798 | |
Member#: 214240
What dealership do you work at? |
09-06-2012, 10:01 AM | #2799 |
Member#: 312107
North End
09-06-2012, 10:03 AM | #2800 | |
Member#: 214240
Since moving I either need to find a new place to bring her or just drive far to bring it to the dealership I have been going to. Thanks again! |
Similar Threads | ||||
HR: Peninsula Meet 11/3 Buffalo Wild Wings 7PM | tux2122 | Mid Atlantic Impreza Club -- MAIC | 46 | 11-04-2009 05:56 PM |
NOVA MEET: Thursday 6/4/09 - Buffalo Wild Wings | blubaru703 | Mid Atlantic Impreza Club -- MAIC | 61 | 06-20-2009 06:58 AM |
Chi: Thursday Borders Meet, 6/26/08 | speelnik | Mid West Subaru Owners Club Forum -- MWSOC | 149 | 06-30-2008 12:04 PM |
SE/Clear Lake Meet - Wednesday 2/2/05 or Thursday 2/3/05 - Buffalo Wild Wings 7:30pm | Hotrodguru | Texas Impreza Club Forum -- TXIC | 11 | 02-03-2005 04:07 AM |
Rochester, NY meet 5pm friday(today) buffalo wild wings | joel(PA) | Tri-State Area Forum | 17 | 04-25-2004 12:35 PM |
