Old 09-06-2012, 07:26 PM   #1
sc00ter
Member#: 117767
2015 WRX
CWP
Default Adding 1-2 gallons of e85 when filling up on 91oct tune. Downsides?
I apologize if this is in the wrong section. I was planning on putting it in the engine management/tuning section but it didn't really fit there.
I am dyno tuned for 19psi on 91 octane, which is the highest octane rating I have readily available near me (aside from e85).
I have been juggling around the idea of occasionally throwing in 1-2 gallons of e85 when filling up with 91 for a little extra punch. I am planning on doing this when going on mountain cruises once every month or two. However, I'm curious as to what the downsides would be. I know in the long run e85 causes corrosion but would this cause issues with my drive ability since I'm not tuned for it?
I've sent an email to my tuner regarding this but haven't heard back in a few days so I figured I'd ask here as well since the cruise I'm planning on doing this for is in 2 days.
Thanks for any feedback.
sc00ter is offline   Reply With Quote
Old 09-06-2012, 08:34 PM   #2
LBell05STI
Member#: 305890
2005 STI
This will do bad things. It will not be a performance gain due to the fact you are tuned for 91. Also considering E85 uses on average 30% more fuel to run it would lean out your AFR if I'm not mistaken. In short, don't do it unless you want a reason to build a new block.
LBell05STI is offline   Reply With Quote
Old 09-06-2012, 08:38 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You'd be MUCH better off (safer) to find a station that has race gas then doing E85.
Old 09-06-2012, 09:11 PM   #4
LBell05STI
Member#: 305890
2005 STI
Regardless of what he does he isn't tuned for it. You will see very MINIMAL gains if any.
Old 09-07-2012, 01:14 AM   #5
Strider327
Member#: 131280
2004 Impreza WRX
You'll run lean basically. That's all, no benefits.
Strider327 is offline   Reply With Quote
Old 09-07-2012, 01:41 AM   #6
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Just go get tuned for E85 and be done lol!
07wrx84 is offline   Reply With Quote
Old 09-07-2012, 01:56 AM   #7
Strider327
Member#: 131280
2004 Impreza WRX
^ This! You might not even want to go back to gas once your on E85! I wish there were more stations around though seriously.
Old 09-07-2012, 02:34 AM   #8
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
E-85 has less energy than normal fuel, which is why on an E-85 tune you have to run huge injectors and tons of fuel, but it does have an extremely high resistance to detonation/knock so you can run more boost, more timing as long as you dump in enough fuel. Running E-85 with normal fuel would actually be a downgrade, yes your "octane" would go up, but you are getting less energy out of the mix. It would be more ideal to run a water/meth kit, that way you are adding more chemicals in addition to your normal fuel. But in short, don't add E-85 to your fuel
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-07-2012, 02:51 AM   #9
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I'll never go back to pump unless I have to!
Old 09-07-2012, 01:44 PM   #10
StealthTL
Member#: 206912
2006 Forester XT
The more E85, the less energy per c.c. - you are dangerously lean right now, and you got away with it.
Don't push your luck further.....
StealthTL is offline   Reply With Quote
Old 09-07-2012, 02:16 PM   #11
Paidfor
Member#: 267815
Be in awe
dont hate .)
The fuel we get here in the south is already "10 % max ethanol"....or thats what all the pumps are marked with anyways. If thats right then that would mean 1 whole gallon of ethanol per 10 gallons purchased ? Thats seems like alot but must be safe to some sort of a degree or it would screw up whatever you put it in...right? Hell i dont know, i wouldnt add 2 or 3 gallons per fill up tho thats for sure. Like they all said above, its take so damn much of it in comp to gasoline. It would be ridiculous to use 100% eth unless you got access to a sheetload of it. I couldnt tell you where to get some around here, never seem a station that offered it.
Old 09-07-2012, 04:43 PM   #12
sc00ter
Member#: 117767
2015 WRX
CWP
Thanks for all the feedback guys. I'm definitely going to avoid it. My tuner responded back saying essentially the same thing you guys did. Not at all worth the risks.
I considered this when getting tuned after the turbo upgrade but the general consensus was that e85 isn't that readily available around me and it doesn't run well in the winter here where it can get to 20 degrees or lower consistently.
What are you talking about? I haven't done it yet.
Anyway, thanks for the replies everyone.
Old 09-07-2012, 06:59 PM   #13
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
my buddy though it was a good idea to try some e85 in his yamaha yz 426 dirt bike. it didnt go well. it wouldnt run and he had to drain out the tank and lines. if it were available more i maybe would run it in my car. there is only one station that sells it in the whole county.
424wrx is online now   Reply With Quote
Old 09-07-2012, 11:33 PM   #14
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Lol duh!
Old 09-08-2012, 01:19 AM   #15
StealthTL
Member#: 206912
2006 Forester XT
My bad, mis-read the original, thought you were doing it regular.
Old 09-08-2012, 03:34 AM   #16
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Read the E85 FAQ here: http://forums.nasioc.com/forums/showthread.php?t=803341
The guy who wrote that ran E85 blend on the stock ECU for years before converting to E85 and re-tuning. There is significant benefit to be had from mixing E85 on a stock ROM due to leaning out the stock richness in the open loop fuel map.
If you're tuned for 91, however, it's obviously not a good idea, as that has already tuned out the stock richness. It depends how they did the tuning how bad it would be. If they moved the ariflow ranges of the trims so OL fuel map isn't affected by the trims it would be worse than if they left the trim ranges alone.
