Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Closed Thread
Old 09-08-2012, 10:59 AM   #51
scoops04wrx
Member#: 150966
04 WRX
Sub'd....
scoops04wrx is offline
Old 09-08-2012, 01:39 PM   #52
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by KillerBMotorsport View Post
I hear what you're saying. I think I have thicker skin than most so it doesn't really bother me like it does some. Being an engineer for so long it's just a fact of life that you will sit in meetings, with people that have never done a single engineering calulation, that want it faster, more robust, more versatile, maintenance free, that can be operated by an untrained chimpanzee, and of course costs less. In the end, if even one of the many criticisms brings about an idea that may improve the product, it's all for the better.
Worse are those people in the meetings who tell you it should be this way or that way because it seems like this super basic physics factoid would be best that way... after you've done the experiments, collected data, and presented information that shows exactly why you're doing it the way you're showing just a few minutes ago when this guy had his nose buried in his laptop instead of listening.
Concillian is offline
Old 09-08-2012, 02:15 PM   #53
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ yep, been there!
KillerBMotorsport is offline
Old 09-08-2012, 09:51 PM   #54
reid-o
Member#: 103631
2004 STI
Gray
I'm working on that stacked radiator intercooler setup I showed you earlier.
After doing some measuring I wonder if a custom radiator support will give a bit more room if the hoop were tied to your crash beam and open up the sheet metal a tad more. But I understand the added costs.
I'm also running the 63 gtx3071 now too. I love it!! It really feels like stock but falls a tad flat at redline. This is on a custom rotated setup. I can only imagine what it feels like with the low mount.
It feels like stock to me.
One other thing I'd like to see is egbp measured. I'm just curious if the reduced header volume lowers the required exhaust pressure by significant amounts. I'm sure theres a difference but it would be cool to see how much.
reid-o is offline
Old 09-08-2012, 09:51 PM   #55
FatTurbos74
Member#: 331602
Nice looking kit. Is that big of an intercooler really needed?
On a site note you might want to try something like this for heat-shielding instead of that wrap; http://www.turbosource.com/product-p/ts3-03-40501.htm
FatTurbos74 is offline
Old 09-08-2012, 09:55 PM   #56
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
...all at prices that make Swaintech look like a dimestore alternative... $550 for just the turbine housing? So it would cost more to heat shield the header than the header cost in the first place... brilliant!
Old 09-09-2012, 01:31 AM   #57
FatTurbos74
Member#: 331602
I guess thats what happens when you pay a welder employee $10 an hour @ mass production rate on a jig....
You really have no clue, and if those price tags scare you, you have no business owning a " fast car".....
Old 09-09-2012, 04:56 AM   #58
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I guess we might as well close down the forums, because 99% of us apparently have no business being here or owning our cars...
You signed up just to stir the pot, then? Or to flaunt that you have more money than brains? I mean really, inconel shielding on a stainless header? That's a little backwards. The ACL HR140 shielding should perform equally well and not cost $2k+ to shield a header.
Old 09-09-2012, 06:11 AM   #59
iana
Member#: 252934
Nice work.
Low mount stuff been an off the shelf item in australia from AM Auto for years now. Googling Tino's impreza, Kaiser's ej235, or Nick's H6 impreza.
But cad models make it look super pretty.
iana is offline
Old 09-09-2012, 08:19 AM   #60
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
With over 26" removed from the pressure side, plus our already low volume header design...
Compared to many that have the bigger is better mentality, it's not that big.
Originally Posted by iana View Post
Nice work.
Thanks for the kind words.
I've seen those projects, long ago, but there's a big difference between a custom fabricated setup, and one that's designed, engineered and made to just bolts on. Don't get me wrong, those are cool projects, just different.
Old 09-09-2012, 11:47 AM   #61
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
I'm puzzled by the fact a " fast car " would need heat sheilding. I'm doing 9.5's @ 146 still drive the car on the street and have no heat shielding.
Dipp is offline
Old 09-09-2012, 01:25 PM   #62
jvsoundwave
Member#: 66060
2007 STI Limited#534
Jet Stream Blue
KillerB Is killin it with this awesome set-up! Lovin the work guys.
Id Like to see it with a Twin Scroll setup as well. I could see myself going with this setup later next year, if you guys have it all done by then
jvsoundwave is offline
Old 09-09-2012, 03:54 PM   #63
reid-o
Member#: 103631
2004 STI
Gray
Well the idea is that egbp data can help one choose a/r and turbine selection a tad better other than just the dyno plots. I'd think that a/r selection should be a tad different than a traditional up pipe version.
For example evos can get away with .63 housings in combinations that would choke a suby. It would be nice to look at another data set.
Theoretically this setup should allow a tad more top end with the smaller turbine or better spool with the larger turbine, but the dyno plot will only show the tuners tuning strategy. We can only guess the reason for a torque fall off for example. Anyways just a thought.
It would be good data since you have different housing and are switching turbos.
reid-o is offline
Old 09-09-2012, 07:14 PM   #64
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the kind words! The Tial housing is the only way to fit the turbo in that location. This setup should produce better numbers than traditionally located TS turbos though
I agree that the data would be useful to some, but I think the majority are going to choose the A/R based on the plot and the results they are looking for. Maybe I'm wrong.
The really nice part is how easy it is to change the turbine out. Drop the subframe support, remove 3 v-bands and you're there. The turbo itself doesn't even have to come out or get disconnected. Half a day with a tuner and you can swap them out for different events, daily driving etc. Much easier than changing an oil pickup
Old 09-10-2012, 03:16 PM   #65
Electioneer
Member#: 284866
1998 Full RSTi Swap
Metallic Grey
Any ideas on price point of this kit?
Electioneer is offline
Old 09-10-2012, 04:40 PM   #66
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
~ $5,000
Includes:
-Killer B LMK Header made from 321 Stainless Steel
-Killer B LMK Up-Pipe
-Killer B LMK Down-Pipe
-Killer B LMK Waste Gate Dump Tube, Recirculated after the cat
-Killer B LMK Intercooler
-Killer B LMK Radiator
-Killer B LMK Bumper Beam
-Killer B LMK Brackets
and probably some other stuff I am forgeting :/
Old 09-10-2012, 05:28 PM   #67
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Not a bad price at all!! Great material, solid engineering and being one of the first people to own it, I'd have thrown that down in a heartbeat. Pretty impressive for right out of the gate from R&D.
Does that include the IC piping also?
Layvon
Layvon is offline
Old 09-10-2012, 05:29 PM   #68
bmw325ix
Member#: 204652
Nice to see something new in the market place
bmw325ix is offline
Old 09-10-2012, 07:55 PM   #69
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Layvon
That price does not include I/C piping for a couple reasons. First it was pretty cheap and quick to order some aluminum tubing and put it all together. I hate charging people more for what they could do fairly easily themselves. Second, I've been playing with different I/C tubing materials to cut down on heat being transfered into the tube. IMO a product that cuts the temps and possibly made from a single piece of tube would be worth paying for
Thanks. Not quite to market yet. Still lots of testing to do and we haven't broken anything yet
Old 09-10-2012, 09:54 PM   #70
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Does price cover scavenge pump and I would say turbo would not be included.
creative wrx is offline
Old 09-10-2012, 10:06 PM   #71
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Does not cover scavenge pump. The mounting bracket does work with a few different Mocal scavenge pumps though, and likely others. I happened to go with the super duty big mamma of scavenge pumps because I take this car on 800+ mile road trips and never want to have to explain to bubba the fix-it guy (since I'll likely break down in the sticks with no tools) what a scavenge pump is. A track car that has a regular teardown schedule could certainly do just fine with a less than magnificent pump.
Turbo is not included as well.
Old 09-10-2012, 10:15 PM   #72
Drewbie
Member#: 309709
99 Rs coupe
Do you wanna dick around with pre-orders or a group buy?
Drewbie is offline
Old 09-10-2012, 11:44 PM   #73
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No. WAY too soon for that.
Old 09-11-2012, 06:05 AM   #74
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
While I agree with this, and anyone who is willing to tear apart their car to use this, will probably have the knowledge to do it, might be worth putting a little note or something in the kit / or on the purchasing page what pieces / bends you need for it to be functional. Just a thought - I'm currently building my FMIC pipes right now, and just wish I had a cheat sheet haha. Kinda fun, but disappointing I paid almost 200 for FMIC pipes that were supposed to fit, but didn't.
/End OT FMIC Pipe rant
Layvon is offline
Old 09-11-2012, 08:01 AM   #75
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There will be lots of info/notes available as we get ready to go production. I will basically be spelling out everything we use and/or know that fits/works.
Closed Thread
