Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 08-19-2012, 11:43 PM   #176
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Yes fun and interesting builds out there for sure, subscribed to all mentioned, your's is one of them. PTE looks to use a smaller hot to cold side differential than BW and even Garret so that is why I am looking at the 5862. I'm not sure that they are slower to spool though, look at the P&L proto turbo kit with a PTE, http://forums.nasioc.com/forums/show....php?t=2371591, it's not slow!
Bariga's did turn out and it's not turned up yet either, it took so long but the sharp edge is slower most times. Kelly's should be dialed from what I see him post up very practical and very thorough approach! Binjoa's turned out great and it looks like he will do the 6 speed and then turn it up some also. He's running the high comp D25 heads with Dom's custom LR build, 9.2/ 1 so his boost is going to be a bit lower but it must be a rocket!
Old 08-20-2012, 12:19 PM   #177
Layvon
Member#: 195711
STi 04/05/06/07
I've looked at that P&L Thread before, but coudln't find the turbo information. If that is the 5862... I bought the wrong turbo haha. I don't need the top end that the 6262 offers, but I want some quick spool. We'll see. I got the small hotside .84, twin scroll and dual wastegates that I'll use as close to running pressure as possible so that they seal tight till close to target boost to aid in spool. The thing I did wrong was buy my cams, they are a little too aggressive I think.
Old 08-20-2012, 02:49 PM   #178
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Im not going to push my setup more! My tune/build is finial i'm totally happy with 520 whp at 25 psi and full spool at 4200 rpm.
This turbo flows **** loads of air and i'm at 90% duty cycle at 19 psi with ID 1000cc injectors.
Bariga is offline   Reply With Quote
Old 08-20-2012, 05:19 PM   #179
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Binjou has b25 heads
He bought new heads for his build
NW2TONE is offline   Reply With Quote
Old 08-20-2012, 06:38 PM   #180
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Which heads are better the B25s or D25? I'll be running S20s up until I get my LR motor from Dom.
Old 08-20-2012, 11:49 PM   #181
manitou
Member#: 193757
2006 XTI Limited
Sorry my mistake, so his comp ratio is what 8.8/1 (B25) instead of 9.2/1 (D25)?
Old 08-21-2012, 12:03 AM   #182
manitou
Member#: 193757
2006 XTI Limited
I thought you were waiting for Dom to get a Vipec knock amp to tune you with a bit more timing? I'd be completely happy with your power for sure! It's nice to see these builds and all the innovation going on! It's good for all of us.
Old 08-21-2012, 12:22 AM   #183
manitou
Member#: 193757
2006 XTI Limited
They haven't released the turbo info yet, only that it's a PTE. Who knows maybe a 5862, 6262 or 6266. The tune was on E85 so aggressive timing for sure, that's partly why it comes on so quick. I think the 5862 is rated at 640 CHP at around 28 psi on pump gas. You're probably good with the 6262 and twin scroll. You're running AVCS right? CW S2 cams are a bit more aggressive duration wise but you'll need those extra gasses to fill all those tubes and you have a smaller HS AR than Anton's EFR so I'll bet you'll be just fine. Are you going to do an E85 tune?
Old 08-21-2012, 12:47 AM   #184
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
engine gets very loud with meth map we want to fine tune knock system, to make sure its not knocking. I'm just driving on pump map with 19 psi and its ****ing quick, spools same as friends 20G XT
Old 08-21-2012, 06:16 AM   #185
Layvon
Member#: 195711
STi 04/05/06/07
Yeah, I'll be doing E85 and AVCS.
One of the last mods for my car is a bulk tank in my truck haha. Traverse City / Big Rapids are the closest E stations near me, so I think a little 50 gallon will sit nicely in the bed of my truck Might help me in a pinch too as I drive appx 3500 miles a month work related. 56k miles on my truck and it's 14 months old
Thats fun Anton, I'm happy for you brotha. Great results once you got them.
Old 08-21-2012, 10:05 PM   #186
manitou
Member#: 193757
2006 XTI Limited
LOL, the truck can be the mother ship! That thing will be crazy on E85. You going to use the ID2000's? Amazed that there is no E85 in Cadillac. Is there a Meijers there? With no E85? Wow, I thought I drove a lot of miles. I average around 35k a year as a sales rep covering IN and OH from Northern MI. Mostly in my truck towing a trailer but I use the Foz for more rapid transit events without all the samples for line showings.
Old 08-21-2012, 10:48 PM   #187
Layvon
Member#: 195711
STi 04/05/06/07
Yeah I'm hoping it'll be fun! No E85 here, but we do have a meijer's maybe when they redo the gas station I'll get lucky. I work near big rapids so it shouldn't be an issue. I don't figure more than a tank and a half a weekend, so a 50 gallon should suffice.
Funny you.mention that, I put on 35,860 last year work related ... 56000 on my 2011 truck already.
Old 08-25-2012, 07:42 AM   #188
manitou
Member#: 193757
2006 XTI Limited
50 gallons should suffice. Yeah, I fricking drive for a living like you and I split it between my Tundra w/ trailer and my XTI.
Old 08-28-2012, 07:00 PM   #189
Layvon
Member#: 195711
STi 04/05/06/07
The only thing I was concerned about was still going bad, does anybody have any data on how long E85 will last without jeopardizing quality. I know Google is not too far away but just curious if any Subaru owners have experience with this.
T minus 36 hours and my exhaust will be here. I am very excited.
Old 08-28-2012, 08:00 PM   #190
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
I completely missed this thread because of the title being of uninteresting value. A Fobia TS kit with a rotated manifold and smart hotside choice running E makes me a lot more interested though! Looking forward to your results!
Old 08-28-2012, 09:26 PM   #191
Layvon
Member#: 195711
STi 04/05/06/07
Ha thanks I think.
I've been meaning to change it, but there's some things that are hard to do from a phone.
I'm excited too. Pictures of exhaust will be posted Thursday night. Hoping to hear back from some people soon about tuning...
Old 08-28-2012, 10:42 PM   #192
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Ha thanks I think.
I mean it in the best way possible; too many subaru's with rotated kits end up with tiny hotsides trying to get spool back and end up running horribly because of it insane back pressue numbers.
Old 08-29-2012, 04:18 AM   #193
Layvon
Member#: 195711
STi 04/05/06/07
Do you foresee this being an issue on my car?
Old 08-29-2012, 08:52 AM   #194
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
You're in uncharted waters, so I have no idea what to really expect besides a whole lot of topend because of your cam selection.
Old 09-03-2012, 09:31 PM   #195
Layvon
Member#: 195711
STi 04/05/06/07
Since I changed the clutch line, I obviously have had no pressure due to air in the system. Today I went to bleed it out with a buddy, and we were cracking the valve, pump pump ... pump and hold pedal down most of way, then crack the valve, and bleed it till nearly to the floor, then I'd close the valve and repeat.
Watching the slave cylinder work, it appears that it is working, but I would have thought with a 6 puck ACT / and a Heavy duty pressure plate, it'd be a bit firmer. I did engage the throw out bearing by pushing the fork back.
Does it make sense that it would be easy to depress the pedal with such an aggressive plate in there? The pedal does come all the way back up to be inline with the others.
Old 09-09-2012, 10:18 PM   #196
Layvon
Member#: 195711
STi 04/05/06/07
Bump for boredom.
Fuel system is all set to go, just need some E85 to test things out and pressure check.
What's the longest you want e85 sitting in a tank for? I'm hoping to be running base map by end of the month.
We'll see though.
Old 09-09-2012, 11:43 PM   #197
monkiboy
Member#: 202958
2008 wrx
this is good news, sir. i'm excited to see this hit the streets and dyno!
monkiboy is offline   Reply With Quote
Old 09-10-2012, 07:38 PM   #198
Layvon
Member#: 195711
STi 04/05/06/07
Me too!
Hoping Oct 1st or so... We'll see how far off I am.
Old 09-12-2012, 06:49 PM   #199
Layvon
Member#: 195711
STi 04/05/06/07
Looks like I might be close to October 1st for the base map.
Link plus knock box, FMIC piping, and V8 seats all ordered today!
Old 09-17-2012, 01:23 PM   #200
DannyD303
Member#: 271150
2004 Impreza WRX
Sounds like a trip up state is in order to check this beast out
DannyD303 is offline   Reply With Quote
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
