Old 09-10-2012, 02:36 PM   #1
bako
Member#: 226211
2002 impreza WRX JDM
blue
Default ignition base timing A vs B
hello everybody!
I was working on my ecu ignition table to get rid of some flkc and fbkc. everything is clear, I have done it. I almost do not see knock correction in log files. but one qqestion is diging my mind: what is difference between A and B tables? I know what base A timing does, but for what reason is there second B table? for low octane fuel? if it's for low octane fuel, I should retard values there even more to be safe... (I always use RON98)
bako is offline   Reply With Quote
Old 09-11-2012, 09:37 AM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
The map switches to "B" with the flash block connected, other than that.....idk maybe it goes to B map when knock is detected, not sure about that though.
Old 09-11-2012, 12:44 PM   #3
bako
Member#: 226211
blue
anyone can confirm about flashblock? interesting way to choose between maps without reflash
Old 09-16-2012, 04:55 PM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
When's the last time you updated your ECU definition file?
I thought that they were renamed to "cruise" and "non-cruise" now, but I'll admit that I'm not sure.
My LGT has A and B boost tables (target and initial WGDC) but it only uses one of each, and the other is completely unused. Some cars have a cruise/non-cruise parameter that transitions from one set of tables to the other.
Map switching would require changes to the ECU code. There is a custom ROM for some 16-bit ECUs, perhaps including yours... I have a 32-bit ECU so I haven't followed it closely, but you can learn about it here:
http://www.romraider.com/forum/viewforum.php?f=36
Old 09-30-2012, 10:45 PM   #5
t5r
Member#: 173959
04 STI
SILVER
Default Map switching
When I was reflashing, and tuning Suzuki ecu's they had A maps for fuel and ignition. I was able to switch between them by grounding, or un grounding a specific wire going in to the ecu. That was the wires only function. Grounded would be map A for exampe just running on motor, and switch (unground) (switch time aprox 60ms) and your in map B (for a dry shot nos map, more fuel and pulling timing as nos was applied). It worked very seamlessly when configured properly. The early ecus ran the SH7052 chip. I'm shure the Subi ecus have this, but I don't know how to switch between the two. I'm shure somebody out there knows. It would be nice for tuning.
t5r is offline   Reply With Quote
Old 10-01-2012, 06:22 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
Joining the test-mode connectors (same ones used to reflash) will drop IAM to zero, but I don't know if it will affect which ignition and fueling tables are used.
Try logging the "map switch ratio" parameter and toggling the connectors. If it moves between 1 and 0 then you're onto something. The catch is that in most ROMs the ratio also changes when driving ("cruise" vs "non-cruise"). The tables that govern the aren't included in the open-source ROM definitions but that could probably be addressed if there's interest.
Old 11-04-2012, 08:40 AM   #7
Bizko1288
Member#: 151260
2011 BMW 135i
__________
Is it general rule of thumb to just match the two tables? I noticed it was like that from the factory, so I just always did.
By "flash block connecter", I am assuming you mean the green test mode one. Connecting the test mode connector throws the car into "limp mode", correct? If connecting that switches to B, should timing be more conservative on the B table?
Bizko1288 is offline   Reply With Quote
Old 11-04-2012, 12:22 PM   #8
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
The flash blocks are used by the 16bit ecus only
Old 11-14-2012, 09:41 PM   #9
ppayer38
Member#: 234407
04 Self-tooned
STi
Ill bump this as I'm intrested in the results if anybody has tested it
ppayer38 is offline   Reply With Quote
