09-08-2012, 10:59 AM | #51 |
Member#: 150966
MAIC
Vehicle:04 WRX WRB |
09-08-2012, 01:39 PM | #52 | |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
09-08-2012, 02:15 PM | #53 |
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
^ yep, been there!
09-08-2012, 09:51 PM | #54 |
Member#: 103631
Vehicle:2004 STI Gray |
I'm working on that stacked radiator intercooler setup I showed you earlier.
After doing some measuring I wonder if a custom radiator support will give a bit more room if the hoop were tied to your crash beam and open up the sheet metal a tad more. But I understand the added costs. I'm also running the 63 gtx3071 now too. I love it!! It really feels like stock but falls a tad flat at redline. This is on a custom rotated setup. I can only imagine what it feels like with the low mount. It feels like stock to me. One other thing I'd like to see is egbp measured. I'm just curious if the reduced header volume lowers the required exhaust pressure by significant amounts. I'm sure theres a difference but it would be cool to see how much. |
09-08-2012, 09:51 PM | #55 |
Member#: 331602
MWSOC
Nice looking kit. Is that big of an intercooler really needed?
On a site note you might want to try something like this for heat-shielding instead of that wrap; http://www.turbosource.com/product-p/ts3-03-40501.htm |
09-08-2012, 09:55 PM | #56 |
Member#: 4414
...all at prices that make Swaintech look like a dimestore alternative... $550 for just the turbine housing? So it would cost more to heat shield the header than the header cost in the first place... brilliant!
09-09-2012, 01:31 AM | #57 |
Member#: 331602
MWSOC
I guess thats what happens when you pay a welder employee $10 an hour @ mass production rate on a jig....
You really have no clue, and if those price tags scare you, you have no business owning a " fast car"..... |
09-09-2012, 04:56 AM | #58 |
Member#: 4414
I guess we might as well close down the forums, because 99% of us apparently have no business being here or owning our cars...
You signed up just to stir the pot, then? Or to flaunt that you have more money than brains? I mean really, inconel shielding on a stainless header? That's a little backwards. The ACL HR140 shielding should perform equally well and not cost $2k+ to shield a header. |
09-09-2012, 06:11 AM | #59 |
Member#: 252934
Vehicle:99 |
Nice work.
Low mount stuff been an off the shelf item in australia from AM Auto for years now. Googling Tino's impreza, Kaiser's ej235, or Nick's H6 impreza. But cad models make it look super pretty. |
09-09-2012, 08:19 AM | #60 | |||
Member#: 198281
MAIC
I've seen those projects, long ago, but there's a big difference between a custom fabricated setup, and one that's designed, engineered and made to just bolts on. Don't get me wrong, those are cool projects, just different. |
09-09-2012, 11:47 AM | #61 |
Member#: 127907
MWSOC
Vehicle:99RS 9.54 @ 146 2.65L & FOBIA fab & S374 |
I'm puzzled by the fact a " fast car " would need heat sheilding. I'm doing 9.5's @ 146 still drive the car on the street and have no heat shielding.
09-09-2012, 01:25 PM | #62 |
Member#: 66060
TXIC
Vehicle:2007 STI Limited#534 Jet Stream Blue |
KillerB Is killin it with this awesome set-up! Lovin the work guys.
Id Like to see it with a Twin Scroll setup as well. I could see myself going with this setup later next year, if you guys have it all done by then |
09-09-2012, 03:54 PM | #63 | |
Member#: 103631
For example evos can get away with .63 housings in combinations that would choke a suby. It would be nice to look at another data set. Theoretically this setup should allow a tad more top end with the smaller turbine or better spool with the larger turbine, but the dyno plot will only show the tuners tuning strategy. We can only guess the reason for a torque fall off for example. Anyways just a thought. It would be good data since you have different housing and are switching turbos. |
09-09-2012, 07:14 PM | #64 | ||
Member#: 198281
MAIC
The really nice part is how easy it is to change the turbine out. Drop the subframe support, remove 3 v-bands and you're there. The turbo itself doesn't even have to come out or get disconnected. Half a day with a tuner and you can swap them out for different events, daily driving etc. Much easier than changing an oil pickup |
09-10-2012, 03:16 PM | #65 |
Member#: 284866
South East
Vehicle:1998 Full RSTi Swap Metallic Grey |
Any ideas on price point of this kit?
09-10-2012, 04:40 PM | #66 |
Member#: 198281
MAIC
~ $5,000
Includes: -Killer B LMK Header made from 321 Stainless Steel -Killer B LMK Up-Pipe -Killer B LMK Down-Pipe -Killer B LMK Waste Gate Dump Tube, Recirculated after the cat -Killer B LMK Intercooler -Killer B LMK Radiator -Killer B LMK Bumper Beam -Killer B LMK Brackets and probably some other stuff I am forgeting :/ |
09-10-2012, 05:28 PM | #67 |
Member#: 195711
MWSOC
Vehicle:PART OUT. PM ME 02-07 Goodies |
Not a bad price at all!! Great material, solid engineering and being one of the first people to own it, I'd have thrown that down in a heartbeat. Pretty impressive for right out of the gate from R&D.
Does that include the IC piping also? Layvon Last edited by Layvon; 09-10-2012 at 07:12 PM. |
09-10-2012, 05:29 PM | #68 |
Member#: 204652
Nice to see something new in the market place
09-10-2012, 07:55 PM | #69 | |
Member#: 198281
MAIC
That price does not include I/C piping for a couple reasons. First it was pretty cheap and quick to order some aluminum tubing and put it all together. I hate charging people more for what they could do fairly easily themselves. Second, I've been playing with different I/C tubing materials to cut down on heat being transfered into the tube. IMO a product that cuts the temps and possibly made from a single piece of tube would be worth paying for Thanks. Not quite to market yet. Still lots of testing to do and we haven't broken anything yet |
09-10-2012, 09:54 PM | #70 |
Member#: 141754
Tri-State
Vehicle:04 stock wrx ;) z31 project, passat dd |
Does price cover scavenge pump and I would say turbo would not be included.
09-10-2012, 10:06 PM | #71 | |
Member#: 198281
MAIC
Turbo is not included as well. |
09-10-2012, 10:15 PM | #72 |
Member#: 309709
RMIC
Vehicle:99 Rs coupe |
Do you wanna dick around with pre-orders or a group buy?
09-10-2012, 11:44 PM | #73 |
Member#: 198281
MAIC
No. WAY too soon for that.
09-11-2012, 06:05 AM | #74 | |
Member#: 195711
MWSOC
/End OT FMIC Pipe rant |
09-11-2012, 08:01 AM | #75 | |
Member#: 198281
MAIC
