Old 08-07-2012, 07:58 AM   #76
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
I have recovered a 2008 STI ECU without issues. However you CANNOT do it with the Renesas Tool as it doesn't support the SH7058S MCU properly. You need the latest BETA ECUFlash to do it. It uses different Clock Type ratios vs. previous SH7058F MCUs.
Just connect to the Testpads as usual which on the 2008 ECU are all inline on a proper location rather than scattered all across the board .
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 08-07-2012, 08:11 AM   #77
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Originally Posted by Hagen5244 View Post
Everything is unhooked and put away now, and I don't have a log from eirlier, but. I have tried 2 stock roms for the 08/09 sti and one tuned rom from an 08/09 rom. All with the same error or in ecuflash the same success, but then when the key is on the car acts like there is no ecu connected, dccd and sdrive amoung other lights flashing. Thanks again
Maybe a stupid question........
But were you sure you used the correct ROM for your ECU?
EG. EDM, USDM, or other...........
I have seen this problem when flashing (not Recovery) somebody's 09 STI with a tuned ROM I made. After flashing succesfully I had the same phenomena as you mentioned. It seems it only happens on 2009+ cars so far from my experience despite them both running AZ1G202G (EDM) ROMs.
Luckily I had made a backup of THAT ECUs stock ROM. I ended up pasting all my tuning data into the stock ROM from THAT ECU and flashed it. After that there was no problem.
You might have the same problem as such that you MUST have the actual ROM that was on the ECU from the beginning.
Cheers,
Jasper.
Old 09-11-2012, 08:35 PM   #78
WrxBogdan
Member#: 281716
2005 Impreza Wrx
Platinum Silver Metallic
Would this work for fixing an 05 wrx bricked ecu?
WrxBogdan is offline   Reply With Quote
Old 09-11-2012, 08:39 PM   #79
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
No, the 05 WRX uses an ECU with a different microcontroller and requires a different procedure.
Noah is offline   Reply With Quote
Old 09-12-2012, 12:57 AM   #80
WrxBogdan
Member#: 281716
2005 Impreza Wrx
What is that procedure? i bricked mine today
Old 11-21-2012, 06:33 AM   #81
toxin
Member#: 51259
2007 WRX
СGM
Originally Posted by norbs View Post
Great thread guys.
Just one question.
Is it necessary to earth C446??? If so, does someone have a clear/zoomed picture of how that is done?
Cheers.
Yes, it is.
You can tie it to P413, as it shown on page 2 of this thread.
toxin is offline   Reply With Quote
Old 11-15-2013, 08:37 AM   #82
hockey3592
Member#: 164924
Does anyone have a schematic for a 2011 STi ecu pinout? I am struggling with the ground connection since the caps arent on my board.
hockey3592 is offline   Reply With Quote
Old 11-19-2013, 10:07 AM   #83
JMRS
Member#: 374033
mad, awesome help!
JMRS is offline   Reply With Quote
Old 11-20-2013, 09:53 PM   #84
Franko
Member#: 193628
2010 STI
SSM
The reason for the connection to the cap is to remove signal noise on the rx and tx connections. It can be seen when using a scope.
Connect it to the ground terminal on the closest cap that looks the same and it will work fine.
Franko is offline   Reply With Quote
Old 11-20-2013, 11:02 PM   #85
Mar4Chris
Member#: 374001
is willing to help you out to build this thing
Mar4Chris is offline   Reply With Quote
Old 03-16-2014, 06:46 PM   #86
AlexTRD
Member#: 135627
2005 WRX td06-20g
ej207/02 wrx/s4/C32 AMG
I know this thread has been dead for a while, but I believe I'm having trouble with my timing circuit. Radio shack and my local elec store didn't have the exact resistor values I needed, so I ended up having to use several to get the necessary values. Checked with my meter and the ohms seems to be correct. My watchdog frequency seems a bit high though at 154hz, and when I check the voltage with my meter is comes in at about 1.15v. This should mean my duty cycle is lower than the 50% on/off im shooting for? Any suggestions?
AlexTRD is offline   Reply With Quote
Old 03-16-2014, 09:54 PM   #87
AlexTRD
Member#: 135627
2005 WRX td06-20g
ok so without the output wire of the timer connected to ecu pin p407 I get 2.2v, but when connected it drops to 1.14v. Does this seem right?
Old 03-16-2014, 10:28 PM   #88
AlexTRD
Member#: 135627
2005 WRX td06-20g
here's an example of my ecuflash log:
[19:26:01.237] sending bit rate sync bytes...
[19:26:01.247] received bit rate adjust response
sending boot command
[19:26:01.772] received bit rate adjust response
[19:26:02.302] received bit rate adjust response
[19:26:02.832] received bit rate adjust response
[19:26:03.878] received bit rate adjust response
[19:26:04.408] received bit rate adjust response
[19:26:04.938] received bit rate adjust response
[19:26:05.469] received bit rate adjust response
[19:26:05.999] received bit rate adjust response
[19:26:06.530] received bit rate adjust response
[19:26:07.060] received bit rate adjust response
[19:26:08.090] received bit rate adjust response
[19:26:08.620] received bit rate adjust response
[19:26:09.150] received bit rate adjust response
[19:26:09.696] received bit rate adjust response
[19:26:10.227] received bit rate adjust response
[19:26:11.256] received bit rate adjust response
[19:26:11.787] received bit rate adjust response
[19:26:12.317] received bit rate adjust response
[19:26:12.863] received bit rate adjust response
[19:26:13.394] received bit rate adjust response
[19:26:14.423] received bit rate adjust response
[19:26:14.954] received bit rate adjust response
[19:26:15.468] no bit rate adjust response
[19:26:15.468] interface close
Old 03-16-2014, 10:30 PM   #89
AlexTRD
Member#: 135627
2005 WRX td06-20g
and here's my fdt log:
OS: Windows Vista/Server 2008 [Admin]
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM1'
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM1' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0xFD
Attempting 4800
Received immediate response from device: 0xD5
Attempting 2400
Received immediate response from device: 0x00
Attempting 1200
Received immediate response from device: 0x02
Error No 15024: Boot failed
Old 03-16-2014, 11:29 PM   #90
AlexTRD
Member#: 135627
2005 WRX td06-20g
I've got activity on the Tx and Rx pins of my ft232rl, just seems like the ecu refuses to go into boot mode.
Old 03-29-2014, 07:25 AM   #91
andea79
Member#: 373537
2008 Impreza STi EDM
I also had a bricked ECU last week on my 2008 EDM STI and I had the sh bootmode cable made by a friend, this is how it looks like (and also worked with ecuflash):
The first picture is the cable and the second one is the ECU on my car with the grey cable and the connector on the right, the wires from the grey cable are still attached to the ECU so in case it happens again I just conect to that connector without taking the ECU out ....
andea79 is offline   Reply With Quote
Old 05-10-2014, 03:13 AM   #92
awadkhan
Member#: 372587
Default ...
Which rom did you use to recover. I did not have the original rom so I tried each and every rom there is for EU 2008-2011 and SADM ROMS. It writes successfully but the ecu is not unbricking. I downloaded roms off internet as well stock one just to be sure that mine arent corrupted. Any input will be highly appreciated.
And for those whose WDT timer is fine and it is not connecting try hitting OK in Ecuflash as soon as you turn the ignition on. I was having connectivity issues as well. When I hit ok as soon as I turned on ignition it connected and wrote right away.
awadkhan is offline   Reply With Quote
Old 05-25-2014, 09:57 PM   #93
Marvin54
Member#: 317521
2015 WRX
Hi.
who can make me one SHboot board
Marvin54 is offline   Reply With Quote
Old 06-12-2014, 02:42 AM   #94
Marvin54
Member#: 317521
2015 WRX
programming complete, but ecu dont work in car
help
Old 07-29-2014, 09:54 PM   #95
robbyredneck
Member#: 346999
2003 wrx
blue
any of you guys who have successfully done this wanna get paid to do mine? 04sti a2zj700j
scratch this. did it myself. just had to eliminate resistor on output of the timer and cap is mislabeled on timer circuit should be .01nf at least thats what worked for me . this works and it saved my bag.
robbyredneck is offline   Reply With Quote
Old 12-12-2014, 05:58 AM   #96
fabio.fxt
Member#: 408422
2010 Forester XT
Gray
Hi Guys,
I write the ECU for the Forester XT 2010 Brazilian with the EcuFlash, but the car don't start. Somebody help me?
fabio.fxt is offline   Reply With Quote
Old 12-27-2014, 08:55 AM   #97
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Fabio,
Unless you have disconnected wires when making the pictures you are missing wires so I doubt you are able to recover the ECU. You need to have wires connected to:
P405 --> +5V (From USB power, FTDI module)
P407 --> Watchdog Timer signal (Timer circuit)
P409 --> Rx (going to Tx on the FTDI module)
P411 --> Tx (going to Rx on the FTDI module)
P413 --> Ground (USB GND, FTDI module)
Make sure everything is connected properly. Also make sure you are supplying +12V power to BOTH Control-supply pins and Backup supply pins on the 4 Main connectors as well as connecting 1 or 2 GND connections. Have a look at the wiring diagram. If you can't get it sorted I can tell you which pins should be used but it should be easy to find in the FSM.
Cheers,
Jasper.
Old 12-27-2014, 11:16 AM   #98
fabio.fxt
Member#: 408422
2010 Forester XT
Gray
Hi Jasper,
Sorry, in this photos I don't show all the connections. I make all connections in my ECU and the Ecuflash show the message complete the ROM write, but the ECU don't work in the car. This is the same problem that occur whith Hagen5244 below.
Thank you
Anyone done this on an 08+? I dont see the c446 cap, with only the p4xx pads connected I get a success full flash from recovery in ecu flash, but the car will not start, the dccd and s drive stuff is flashing on the dash and I can not communicate with the ecu using obd2 port. Any help would be great.
Old 01-02-2015, 11:44 PM   #99
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Try again using an extra GND connection from P413 to the 2nd CAPACITOR from the bottom left corner in your picture to see if that solves your problems. Make sure you have the correct ROM for your car and make sure you disconnect the SHBoot recovery board before attempting to start the car. Trying to start the car with the SHBoot board still attached will not work.
Regards,
Jasper.
Old 01-08-2015, 12:16 PM   #100
nhawks
Member#: 367296
so everyone that as successfully reflashed using this method, did you use the stock rom or were you able to get it to reflash with anything else?
nhawks is offline   Reply With Quote
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How to Make an STI Look Like a Sleeper? FostersAFB General Community 88 10-20-2004 09:29 PM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
