Old 09-10-2012, 06:55 PM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default ATP GT3076R Internal Wastegate + MBC issue, Can't Surpass 22PSI
Hey Guys,
So I have an ATP GT3076R that came with a stock 12-14psi Wastegate. My plan was to up the boost via MBC to about 24psi. My issue is that I can only hit 22psi and it would tapper to 20-21.
I tried a Grimmspeed MBC and a Turbosmart Dual Stage MBC. Both seem to be limited to around 22 psi. Can my Wastegate spring be too weak to handle x amount of boost?
Is there anything I can add to the system to help out?
I found this:
http://www.atpturbo.com/mm5/merchant...egory_Code=WGT
This should substantially help I think but is it the proper solution? I don't mind buying it if its proper. Also if my Wastegate is the problem then wouldn't it be cracking open earlier then it needs too thus the tapper?
OC_Nooby is offline   Reply With Quote
Old 09-10-2012, 07:46 PM   #2
holyjoetart
Member#: 232986
07 Legacy GT
Sounds like your BPV/BOV is leaking
holyjoetart is offline   Reply With Quote
Old 09-10-2012, 08:00 PM   #3
OC_Nooby
Member#: 311781
2003 WRX w STI V8
You might be right, I have a BOV. I could put my Go Pro in my engine bay and see what happens! (if its cracking open)
Also I could just crush my stock bpv and see if I can hold more boost.
Old 09-10-2012, 09:06 PM   #4
Schister66
Member#: 271648
2015 STi
What is the internal wastegate set to hold? The rule of thumb is that you can't run more than double the pressure (reliably)
Schister66 is offline   Reply With Quote
Old 09-10-2012, 09:13 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Why are you just cranking boost up blindly How are you determining its only making 22psi? Gauge, logs, etc?
Old 09-10-2012, 09:18 PM   #6
OC_Nooby
Member#: 311781
2003 WRX w STI V8
ATP states 12-14psi on this particular wastegate
I'm logging via romraider, gauges, have det cans etc (not doing it blindly). I can see it not wanting to produce more boost/sustain no matter what I do with the MBC.
Old 09-11-2012, 03:53 PM   #7
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Alright, put my bpv back on (crushed it) and still in the same situation as before. Getting 22psi nothing more.
Could I have a boost leak? I smoked the motor 2 months ago and had no leaks so I'll rule it out. Wastegate creeping open?
Wouldn't a lot of gt3076r owners have this issue though?
Old 09-11-2012, 04:31 PM   #8
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Log MAP not MRP, see if you read over 22
Old 09-12-2012, 01:32 AM   #9
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Yah, one of them reads 18.43 max. I changed that so its reading right.
Strange thing happened today though. If I go from 1-5 full blast it hits 22 psi and stays there. Now if I'm on the highway in 5th and stomp on it the boost surpasses 24psi and the car goes know where fast. You can hear the turbo go but the car is like blah. I guess this ATP GT3076R is a hair dryer up there.
Reading this from my boost gauge (didn't have laptop).
Old 09-12-2012, 08:20 AM   #10
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What are you tuned for? It sounds like you're well on your way to blowing things up.
Old 09-12-2012, 08:59 AM   #11
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I'm tuned for 22psi and its a very safe tune if I may say so.
I'm going to buy a stiffer wastegate spring and see if it helps. No reason a MBC shouldn't be able to allow the turbo to produce more boost.
For simplicity sake, let's keep the tuning out. Assume it's perfect. I'm playing with a MBC so I'm not using the stock system/ecu to control boost. I'll try the bov and see if I can reproduce.
Recap:
I've used 2 mbc's, bpv/bov and with the bpv I can cause the car to overboost if I'm in 5th gear.
Old 09-12-2012, 11:29 AM   #12
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
It sounds like you're knocking, your car is retarding timing trying to save itself from popping.
What intake/inlet are you running?
pet3r is offline   Reply With Quote
Old 09-12-2012, 02:55 PM   #13
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Yeah, this is the next course of action. The MBC can only do so much, and backpressure will force open the wastegate no matter what.
What??
Old 09-12-2012, 04:04 PM   #14
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Your car will pull timing when it knocks. This slows your car down, even though you might be maintaining boost levels.
If it's a silicon intake hose, it could be collapsing on high boost.
Old 09-12-2012, 04:50 PM   #15
sexyyrex
Member#: 128022
2015 Mustang GT
On a ATP 30R, in fifth gear, not at speed, Of course the car isn't going to go anywhere. its a 30r. Full spool is what, 3800/4000 rpm?...you'd have to be doing over 100 at least. No one should be loading a larger turbo car, on pump gas, in 5th gear, not at speed, its a recipe for disaster. My guess if your car is reading full boost, not at speed, that your boost gauge is broken. Verify with a datalog...but if you'd been loading the car, again, not at speed, chances are you'll need more then just a new boost gauge.
& knock has nothing to do with the car not reaching target boost. My guess is you are out of the limitations on whatever boost controller/diaphragm setup you are running.
sexyyrex is offline   Reply With Quote
Old 09-12-2012, 06:36 PM   #16
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I don't hold it. I know it's a disaster if I'd hold it. Boost gauge/log read the same. This turbo fully spools at like 4700rpm which is weird. I don't have AVCS but it can't play such a big roll in spool timing I don't think. (2.5l sti)
Anywho, the more I tighten down the boost controller the more it will over boost in 5th gear (1-5 WOT run). Currently will over boost to 24psi and come back down to 22 psi. Though 1-4 seem fine, slight overboost but most noticinle when shifting into 5th for a sec it will spike during a full on WOT run.
Old 09-12-2012, 08:30 PM   #17
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
You're pretty much overloading the wastegate to mechanically creep, that's why its overboosting like that. And yes... AVCS does make a difference....
Old 09-12-2012, 08:43 PM   #18
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I had same problem but ended up I had intake leak lol.
07wrx84 is offline   Reply With Quote
Old 09-12-2012, 09:33 PM   #19
OC_Nooby
Member#: 311781
2003 WRX w STI V8
You think a wastegate spring upgrade will help? Essentially a siffer spring mention for 22psi instead of 14psi which it currently is? I've just herd stories that this is not the issue but gah, this isn't making sense.
Don't say that!!!! I smoked the intake a while back. Didn't have any issue.
Old 09-12-2012, 09:44 PM   #20
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
honestly, a 30R with a 14psi spring and a MBC should have ZERO issues hitting 22psi. it sounds to me like your wastegate is stuck open. try pushing the flapper open and closed a few times by hand to see if you can break whatever is causing it to stick open free. then see if it helps you hit your target boost.
Old 09-13-2012, 01:40 AM   #21
OC_Nooby
Member#: 311781
2003 WRX w STI V8
The wastegate looks closed but could be a hair open. The flapper moves and takes quiet a bit of pressure to open. I'll try adjusting to see what happens.
Old 09-13-2012, 10:19 AM   #22
amalgrover
Member#: 183480
2009 Forester XT
its going to take alot of force to open it, you are overcoming 14psi of spring tension. even the 8psi vf turbos take a decent amount of force to open.
Old 09-13-2012, 11:59 AM   #23
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Your saying by hand it would be really hard?
Old 09-13-2012, 12:20 PM   #24
amalgrover
Member#: 183480
2009 Forester XT
yes, by putting your hand on the actuator arm and manually actuating the wastegate flapper open and closed is going to take some effort because you are overcoming the spring tension.
Old 09-13-2012, 01:03 PM   #25
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Adjusted the wastegate actuator 2 turns. Nothing. It already seemed pretty tight to be honest.
Kinda lost.
