Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 09-04-2012, 08:08 PM   #1526
gtasti
Member#: 152036
2004 Sti
Originally Posted by vicious_fishes View Post
anyone in this thread deleted their airbags? specifically on a GD model?
I got the steering wheel out and the seat bags haven't done the dash yet
gtasti is offline   Reply With Quote
Old 09-04-2012, 11:18 PM   #1527
68Cadillac
Member#: 95901
I'd like to say the dash one is the heaviest. I've never removed mine.
Old 09-05-2012, 01:03 PM   #1528
sorrowfulkiller
Member#: 170439
I <3 Lamp
I removed mine when I took the dash out to remove the stock fuel lines, the thing feels like 7-10 lbs
sorrowfulkiller is offline   Reply With Quote
Old 09-11-2012, 12:47 AM   #1529
68Cadillac
Member#: 95901
Swapping the Front Lower Control Arms on the wagon for the aluminum ones off an STi. Seller said they were "JDM", and that he "Imported them from Japan". Whatever. Paid him the USDM price.
They look like 2004-2006 STi/2006 WRX control arms to me. EDIT: Apparently they're 2007 USDM STi
Track is wider. 10mm wider per side? 20mm overall?
OEM, 2004 Wagon, Steel, Front Lower Control Arms weight: 4.173kg
OEM, 2007 STi, Aluminum , Front Lower Control Arms weight: 3.493kg
A savings of 680 grams per side or 1.360kg (3.00lb) total.
Old 09-11-2012, 12:58 AM   #1530
Web Foot STi
Member#: 39086
2004 STi
They look like 2004-2007 STi/2006 WRX control arms to me.
OEM, Wagon, Steel, Front Lower Control Arms weigh: 4.173kg
OEM, STi, Aluminum , Front Lower Control Arms weigh: 3.493kg
The JDM STi arms didn't have the extra castor of the Spec C, or the USDM '04-'06 STi arms. The '07 STI didn't ether.
It also looks like you didn't get the steel cones for the ball joints.
There is a big front control arm thread with some pictures.
Web Foot STi is offline   Reply With Quote
Old 09-11-2012, 01:05 AM   #1531
68Cadillac
Member#: 95901
How can I tell which ones I have? Is there a casting mark or something?
Didn't notice that. Hopefully I can pick those up at the dealer easy.
Old 09-11-2012, 10:29 AM   #1532
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
You have USDM 07 STi control arms. There is a casting mark of sorts. Near the tab where the sway bar mounts would be more of a diamond shape rather than the straight line.
Old 09-13-2012, 07:27 AM   #1533
RRR
Member#: 274842
What a thread.. Inspired, Ive read the whole thing now (took 1 month, gave me 2 pages of work to do ).
Anyways, there is so much fuzz on these bumper beams, and for the record these appear to be USDM only. European cars dont have them as far as I can tell, checked 2 now (GD).
Anyone with the windscreen washer fluid in the trunk? How do you route it? I suppose the intercooler spray line would work, but I dont have that....
Im quite worried about wheight distribution. These things are 60/40 stock, and 3/4 of the wheight removed in this thread appear to go from the rear... Good excuse for keeping that big rear wing though. Ill also go for the battery in the trunk, I feel those extra oz of wire is worth the slightly better distribution.
RRR is offline   Reply With Quote
Old 09-13-2012, 12:42 PM   #1534
68Cadillac
Member#: 95901
There is a good amount of weight that can be removed from the front half of the car. Problem is it's harder to remove. It's either more time consuming or costs more money. The low hanging fruit is in the rear half. Other than the offset frontal crash u-beam which is fairly easy and significant.
Old 09-17-2012, 03:38 PM   #1535
RRR
Member#: 274842
I just replaced my wheel nuts with Rays engeneering light weight nuts. I dont have a scale to measure such low weights, but the steel nuts weigh a ton, and the Rays weigh next to nothing! And its unsprung at the far ends of the car, so a good mod indeed. Wild guess, 100grams.
Oh and I felt a serious increase in power
Old 09-19-2012, 04:29 AM   #1536
vicious_fishes
Member#: 158864
2003 SOHC destroker
up front off the top of my head:
bumper beam 12kg
subframe 12kg
AC 10kg
battery 9kg
steel bonnet to alloy if you had a steel: 7kg
i mean there's 100lbs for you turbo guys straight off the bat for a sum total of about 100 bucks for another battery. or near 80lbs for nothing. 50kg for the n/a folks. then you can pull the firewall sound deadening for another 7-8kg. remove the passenger seat on track days for 20kg. airbags would be at least another 10kg if you want to get rid of those as well.
then there's another 20kg stripping the boot out with the spare wheel etc. spend some money on a stainless exhaust and there's another 25kg to go no problems. you yanks have rear bumper beams that are another 12kg. there's about 3kg in the bar under the rear seat too.
you can pull 10% of the weight out of these cars very practically without much effort at ALL.
Old 09-20-2012, 02:26 AM   #1537
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
My LW beam - I will be able to weight it soon.
bue car is offline   Reply With Quote
Old 09-20-2012, 11:00 AM   #1538
gtasti
Member#: 152036
2004 Sti
Any one know if we can remove the rear caliper bracket
Looks like a U with a round circle not sure what it's for ?
Old 09-20-2012, 11:46 AM   #1539
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
I was told its a dampener of sorts, I believe that is what the manual says. So why not?
Old 09-20-2012, 11:55 AM   #1540
gtasti
Member#: 152036
2004 Sti
So ur telling me next time I'm under the car to remove em
Old 09-20-2012, 03:37 PM   #1541
A-man07
Member#: 271525
07 STi
It's damper, not dampener, and yes they can be removed. Mine are gone.
Old 09-20-2012, 03:50 PM   #1542
68Cadillac
Member#: 95901
Gta, would you mind posting a picture of it? Thanks man.
Old 09-20-2012, 04:01 PM   #1543
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Old 09-20-2012, 04:02 PM   #1544
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
i always spelled it wrong, no wonder.
Old 09-20-2012, 04:16 PM   #1545
68Cadillac
Member#: 95901
Looks heavy. I don't think the station-wagon got those.
Old 09-20-2012, 04:44 PM   #1546
gtasti
Member#: 152036
2004 Sti
Yup that's what I'm talking about
I'll remove mine once I get under car again
Kinda off topic anyone running kw v3
I'm just wonder how the rear tops look don't think mine are sitting right
Old 09-20-2012, 04:46 PM   #1547
A-man07
Member#: 271525
07 STi
They are just under 1 lb each as I remember.
Old 09-20-2012, 05:00 PM   #1548
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
because you don't have sti rear brakes
What do you mean, the springs sit like oem springs on the perches.
Old 09-20-2012, 05:22 PM   #1549
68Cadillac
Member#: 95901
Okay.
Old 09-20-2012, 05:34 PM   #1550
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
hahah
ill weight my new bar tonight when I bring it home!
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 01:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 12:02 PM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 11:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 01:53 AM
