#26 |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
First question, who tuned your car and was it tuned on an electric bcs? You stated that you added an mbc to turn up the boost. Did you run its own dedicated boost lines? Or, did you install it in the existing lines that run through the bcs?
If you installed it in line with the bcs then you won't be able to use the mbc unless you change some tables to keep the bcs closed.
#27 |
Member#: 309444
Tri-State
Vehicle:2005 sti |
Id try a diff Wg spring. I run the same turbo and a 44mm ewg and hit 25 all day. Just work yOur way down the line of solutions starting with the cheapest. Also are you running a tial Wg. Make sure the vaccum hose is on the correct port.
#28 | |
Member#: 311781
Vehicle:2003 WRX w STI V8 |
It's an internal wastegate. So my only solution would be to change up the wastegate actuator with one that can hold 22psi from ATP. |
#29 |
Member#: 183480
South East
Vehicle:2011 Audi A3 Quattro 2009 Forester XT |
the title says INTERNAL WASTEGATE...so i am pretty sure he is on the wastegate that came with the turbo from ATP. he really shouldn't have any problems hitting 22psi on the 14psi internal wastegate.
#30 |
Member#: 183480
South East
for a manual boost controller, you would run one line from the compressor pressure nipple to the boost controller's inlet. then you would run another line from the outlet of the boost controller to the wastegate actuator nipple. that is it...
#31 | |
Member#: 311781
Unless I have the worlds biggest boost leak. I'll go get this checked again I guess. |
#32 |
Member#: 183480
South East
the few times i have seen the issue you are describing it has been one of two things...
the wastegate stuck open, and actuating it by hand fixed it ...or... the boost controller was messed up, was replaced, and was good to go ...since you said you have tried 2 different boost controllers, i would think the problem is not in the boost controller. so either something is wrong with the wastegate, or you have a decent sized boost leak. remember, a boost leak is going to automatically be a vacuum leak at idle, and while sometimes the leaks will not show up until the motor is in boost, alot of times they are present 100% of the time. this means that you could take a can of carb cleaner, and with the engine running spray around the vacuum lines, intake manifold, intercooler, etc. and see if the idle changes. if it changes when you spray somewhere, you found your leak. this doesn't always work, but it does work alot of the time. |
#33 |
Member#: 311781
I'm honestly leaning toward the wastegate being the issue. I have smoked the intake and previously found leaks up to my injectors. Fixed them, went back and had zero leaks.
It's weird, you would hear a lot of people with ATP stock location turbos complain if they had the same issue. Last edited by OC_Nooby; 09-13-2012 at 02:50 PM. |
#34 |
Member#: 311781
I'm removing my inlet and installing an AMR 3" hard inlet. Can only help + I have it laying around. Will inspect inlet once I pull it off.
#35 |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
Do you still have the STI TMIC on there? I've never used one on this size of turbo, but it seems to me that could be restricting you some. A 3076 at 22 psi is a lot of air to flow through there.
You should have your gauge reading manifold pressure, not boost pressure after the turbo. With your setup, with no leaks and a solid BPV, the way I see it, there is either a restriction somewhere or the wastegate sping isn't enough. |
#36 | |
Member#: 311781
Boost gauge is hooked up to a manifold source Wastegate is hooked up to a boost source |
#37 |
Member#: 269076
MWSOC
Vehicle:2004 Wrx WRB 12.7@109 |
My gt3076r will only hit 22psi as well, but thats because my tuner put a failsafe max of 22psi on my tune
![]() It's been a few days, did you figure this out? |
#38 |
Member#: 311781
OK boys, I don't know what to make out of it....
I unhooked my boost source to the wastegate. One would assume that once you unhook this you should get a crap ton of boost. Well guess what, it pegs at 22psi ahahhahah. So then I decided to wire the flap shut (maybe the back pressure was opening the wastegate), nope still 22psi. I unhooked it and left the flap open for ****s and giggles, 2-4psi max. Now I'm thinking the the wastegate flap is not sealing. This makes sense as I'm always boosting a lot later and can't surpass 22psi. Has anyone seen this before. I'm just that lucky? FML. |
#39 | ||
Member#: 183480
South East
i already posted a couple weeks ago telling you that i have seen this exact issue before, and that based on your troubleshooting and descriptions, it sounded like it was the wastegate not sealing all the way. i quoted/highlighted it below for reference. Quote:
you are going to need to either: a. actuate the wastegate flapper by hand by grabbing the arm and forcing it open and closed to see if you can get it to fully close like i said to do in the highlighted post above ...or... b. remove your downpipe to further inspect the wastegate |
#40 |
Member#: 311781
I actuated the flapper by hand, I also tightened it 2 more turns to make sure it was tight. I have to remove the dp to see how it seals.
#41 |
Member#: 311781
Talking to ATP they say my inlet being 2.5" plus the step down adapter they supplied 3" to 2.5" is causing me the problem.
I honestly don't think its that restrictive..... Thoughts? |
#42 |
Member#: 183480
South East
it may be, but i honestly doubt that is the case because your boost went to the exact same thing when you removed all boost control whatsoever. even with the stock inlet on a baby vf, with the boost control completely removed you can easily spike to over 25psi in 3rd. i think that would be a factor as to why you can't target really high boost, but 22psi should be a cake-walk with the wastegate flapper wired shut.
my guess is still a boost leak or the wastegate is stuck open some...who knows though...definitely keep us posted. i am curious to see what your findings are. |
#43 |
Member#: 311781
I'll be taking the dp off within the week to check it out...so depressing.
#44 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
What MAP sensor are you using? I ask because the stock MAP sensor maxes out around 22 or 23 psi.
I have an ATP 3076, with IWG, Hallman MBC, and an AEM 3.5-bar MAP sensor, and I have been running 22psi for months. I had it tuned for 25psi for a little while, and I didn't have any trouble getting there. I get about the same boost taper that you do - boost drops about 1.5psi between 4000 RPM and 7000 RPM. I've been told that an EWG would fix that, but it doesn't really bother me. I am running the IWG actuator that came with the turbo. If I remember right, I get 12psi with the MBC turned all the way out (min boost). But it's been a long time since I actually checked. |
#45 | |
Member#: 140444
NWIC
My setup hits 20psi at about 3300 in 5th gear, at about 65mph. It's not a disaster, it's just a waste of time. 5th gear sucks for acceleration, and it takes a few seconds to build 20psi at such low RPM. In 6th, if I floor it at 2500 RPM, it takes almost 10 seconds to reach 20psi, 3000 RPM, and 80mph (they all happen at once). I've only done that once (in the name of science) but it was almost two years ago and the motor still works just fine. It's certainly a lot more satisfying to shift down, but high boost in high gears really shouldn't blow up your car. |
#46 |
Member#: 183480
South East
i think alot of people see detonation issues in the higher gears is because a vast majority of tuners do not accurately estimate or actually do 5th or 6th gear pulls while tuning to compensate for the higher load values (and boost if not using a MBC) seen in these gears. i think that is generally why alot of people consider it a no-no...
#47 | |
Member#: 311781
What inlet do you have NSFW? |
#48 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
I have a 2.5" inlet on my Blouch 20G XTR and I can hit 28psi peak, no problem. That's not your issue.
#49 |
Member#: 183480
South East
like i said, i have guys running stock inlets, intake boxes, filters, etc. on baby vf turbos without any issues hitting over 22psi. so i highly doubt that is your issue...
#50 | |
Member#: 311781
