#13426 |
Member#: 146287
BAIC
Vehicle:2009 Impreza 2.5i 5D Sunlight Gold Opal |
You're not really taking advantage of the higher octane unless you're tuned for it.
If you're tuned, you can squeeze out about 10-15 hp depending on what kind of fuel you go for. With the stock tune, bumping up the octane isn't that big of a deal. The ECU will adjusst for it a little bit, but you won't be making much more power. The problem will come when you want to go back to the lower rating. The ECU will have to adjust back to the lower stuff and in that adjustment period, you could experience detonation and knock. But Will's car is an Australian car, it's most likely that the factory tune is different than what is in the US. Simply because you can buy higher octane fuel in Australia.
#13427 |
Member#: 316101
Tri-State
Vehicle:2011 Impreza 2.5I Sliver |
will your car is amazing! thanks for the extra pics! where did u get that lip?
#13428 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
Oh maybe he's got a tune, that would make sense.
#13429 |
Member#: 253642
NESIC
Vehicle:2008 Impreza 2.5i SSM |
cleaned up the subie today
#13430 |
Member#: 200420
RMIC
Vehicle:'08 DGM 2.5i Sedan '05 AW STI Track Car |
i've only ever put 91 octane in my car. no reason really. i figure it will protect a tiny bit against detonation when i drive hard and it's usually only ~$2 per tank more than 87
#13431 | |
Member#: 277301
Tri-State
Vehicle:2010 Impreza Satin Pearl White |
#13432 |
Member#: 253642
NESIC
#13433 | |
Member#: 277301
Tri-State
#13434 |
Member#: 291519
NESIC
Vehicle:2011 OBS Black |
I tried using higher octane to see if the ecu would adjust for it and make any difference. What I found is my gas mileage went down, my power felt off and I swear my exhaust tone was louder. Now I wanted this to work so the placebo effect would be a positive result but all I got was negatives. I cannot confirm, but I would guess that the ecu can't adjust enough for the higher octane and there wasn't a complete burn in the combustion chamber. This would account for lower power, mileage and increase sound. Just my .02
#13435 |
Member#: 327439
International
Vehicle:2009 Impreza RS OBP |
well for us in Australia the standard fuel is 91, 95 or 98 Octane, in Europe and Japan Octane levels of 100 are not uncommon. Just depends on the country I guess...
#13436 |
Member#: 286580
MWSOC
Vehicle:2008 2.5i Sedan DGM |
I've never contributed any of my cars, just lurked and comment every once in a great while.
Here was my first subie. Previous owner did everything you see to the car(purple tint , msr wheels-super light and noticeable in acceleration i have to say, CF trunk and hood, smoked tails, 4 piece bolt-on ground effects kit- , and some loud-ass cbe)I didn't have the money to change much, but i took off the body kit, I added Kartboy solid front endlinks and was going to order a better rear swaybar. I also put the stock hood back on and did the complete 90k maintenance schedule myself. I ended up trading in the car before I did the rear sway and therefore will be selling the rear kb solid endlinks that I had bought in advance. Again, I no longer have the car, only kept for about a year, but I will admit it was more fun than my current stock 08 2.5i. http://i1188.photobucket.com/albums/...DSC_1730-1.jpg Last edited by DexteRS; 09-16-2012 at 05:59 PM. Reason: Edit: Please restrain your enthusiasm for my awesome plate block technique |
#13437 |
Member#: 268284
Tri-State
Vehicle:2008 2.5i impreza spark silver |
I want to see more pics of n/a model subies with roof racks. Im deciding on crossbars and a bike rail. I just want a better visual. Thanks
#13438 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
#13439 |
Member#: 291857
SWIC
Vehicle:2009 Impreza 2.5i |
Snowboarding season is around the corner. I defiantly need some roof racks!
#13440 |
Member#: 268284
Tri-State
Thanks KartRacer3 ! I was looking at the oem crossbars, and the subaru bike rack.
#13441 |
Member#: 216858
MWSOC
Vehicle:2009 Impreza OBSlow Steel Silver/Spark Silver |
I will have to get some pictures up, but I am happy with my setup. I have an '09 OBS with the OEM crossbars. The crossbars are VERY secure with no flex. Running 2 Yakima ForkLift trays and Thule Wheel-On front wheel holders. And modified the Subaru universal mounts so that I could mount a Thule front fairing. Whole setup is very secure and nothing moves around. Actually, when riding season is over I just undo the 4 mounts on the crossbars and remove the entire assembly and hang it up for the winter as a complete unit...
#13442 |
Member#: 290517
Tri-State
Vehicle:2008 Impreza 2.5i Dark Grey Metallic |
anyone got a 08 hatchback with the 04-07 wrx bbs wheels on them? im looking to pick up a pair but i want to see how it will look first.
#13443 | |
Member#: 262503
MWSOC
Vehicle:2008 Impreza 2.5i |
#13444 |
Member#: 314870
Hi guys
Wonder if you can help me. I would like to know if this set of springs will fit my car. My car is just around 7k miles and would like to have these springs installed. I am thinking of purchasing these eibach springs. see link below. Your help will be appreciated. You can also suggest other brands that will fit my car. http://www.rallysportdirect.com/Eiba...wering-Springs |
#13445 | |
Member#: 288727
NESIC
Vehicle:2008 Impreza 2.5i Satin White Pearl |
#13446 | |
Member#: 288727
NESIC
Tires are 235/45 so they look pretty close to the fender lol. ![]() |
#13447 |
Member#: 230925
MAIC
Vehicle:04 WRX Wag Stage 4 06 Impreza 2.5I |
#13448 |
Member#: 268328
BAIC
#13449 |
Member#: 268284
Tri-State
#13450 |
Member#: 268328
BAIC
| Thread Tools | |
| Display Modes | |
| What's the widest tire that can be put on the 2.5i? | SubieSubie | Impreza Forum | 17 | 06-25-2012 06:17 PM |
| Will the STi Front and Rear Bumper will fit on the 2.5i? | GD6Noob | Interior & Exterior Modification | 7 | 04-30-2012 08:33 PM |
| Wheels that fit the 2.5i and the best offset. | VIsubi | Tire & Wheel | 2 | 06-23-2010 09:19 PM |
| Test Drove the 2.5i Legacy at SoD | maclif | Texas Impreza Club Forum -- TXIC | 8 | 06-02-2004 08:42 PM |
