Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-11-2012, 07:15 PM   #1
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Default Infrared Testing Volume 1 *featuring PTP turbo blankets and GRIMMSPEED*
2011 WRX with the grimmspeed heatshield,Cobb catted downpipe, I let the car warm up and idled it for 20 min after operating temperature. The ambient temp outside was 72 F and the car was in the shade when I used the camera. The turbo itself was 352 F, the top of the grimmspeed heat shield was 137 F, and the top of the TMIC was 112 F. I will upload pics when I get a chance.
Now I just recieved in the mail my new PTP turbo blanket, and am very curious to see the differences. I will be updating this thread with all my info when I complete the install.
turbo temp--352
heatshield temp--137
TMIC--112
Old 09-11-2012, 07:24 PM   #2
mechatricity
Member#: 290592
2006 WRX Wagon
2004 WRX Wagon
bump for updates!!!
mechatricity is offline   Reply With Quote
Old 09-11-2012, 07:41 PM   #3
Spenk
Member#: 7164
---> Spoiler alert:
Everyone dies at the end.
Originally Posted by mechatricity View Post
bump for updates!!!
9 minutes after the OP?
Save me, Jebus.
Spenk is offline   Reply With Quote
Old 09-11-2012, 08:13 PM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
This should be something also to consider taking the exhaust temps from dp to midpipe with infrared.
Thx for taking the time to do something like this as this can be very useful info.
trev762 is offline   Reply With Quote
Old 09-11-2012, 08:17 PM   #5
SubiSteveGD
Member#: 256552
2004 impreza wrx sti
java black pearl
I am curious to see the differences as well!
i use infrared cameras to hunt for people haha.
pics ftw!
SubiSteveGD is offline   Reply With Quote
Old 09-11-2012, 09:58 PM   #6
mechatricity
Member#: 290592
2006 WRX Wagon
2004 WRX Wagon
Save me, Jebus.
Lol didn't mean right then
Old 09-12-2012, 08:41 PM   #7
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
engine bay
turbo
heat shield
Old 09-12-2012, 08:46 PM   #8
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
TMIC
by request--- Trev762---- downpipe from top of engine bay, downpipe from under the car.
dp near cat
Old 09-12-2012, 08:53 PM   #9
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
a better TMIC pic
Old 09-12-2012, 08:57 PM   #10
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Nice work herocrank as this will aid people trying to prevent heat soak. U can clearly see where the heatsoak is on the tmic hence clearly where the turbo is lol.
Old 09-12-2012, 09:01 PM   #11
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
now I seriously regret not heat wrapping my cobb downpipe. I will post up the updated pics with the PTP turbo blanket soon.
Old 09-12-2012, 09:31 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Lol when I bought my perrin TB and thought the same so I got the DEI titanium pipe wrap and also got the DEI gold tape for my end tanks on the tmic. Since I had 30' of it I even taped up my Cobb SF cold air box. Didn't think would be much of a difference but all I can say is wow!! Spools around the same maybe a littler quicker but its the way the boost comes in i immediately noticed especially when getting off the throttle then rolling back into wot.
Edit: also to I noticed when sitting at long lights the throttle is much more responsive do to less or taking longer to heat soak everything.
Old 09-12-2012, 10:00 PM   #13
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
These are awesome! Looking forward to seeing the results with the PTP blanket. I have a PTP blanket and a GrimmSpeed heat shield on mine. I'd also be interested in seeing how it looks after some hard runs through the gears.
Old 09-13-2012, 08:25 AM   #14
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 290.5whp 331wtq
in for results with PTP!
freddy121389 is offline   Reply With Quote
Old 09-14-2012, 01:16 AM   #15
d0wnShifT
Member#: 140318
2011 STI
PBP
Is there any way you can do the same with a STI intercooler installed, perhaps a buddy's car.
d0wnShifT is offline   Reply With Quote
Old 09-14-2012, 04:04 PM   #16
Farfrumwork
Member#: 10202
'07 Spec B
'07 fozzy/'85 EJ22 Westy
Also, pull your heatshield and apply the gold foil to the inside of the shield. This helps keep radiant heat from transfering through the HS in the first place.
Here's the chimney from my old '93 Turbo Leg. (I did the same thing to my specB stock heatshield)
Farfrumwork is offline   Reply With Quote
Old 09-15-2012, 09:37 PM   #17
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
If you can arrange someone to meet up with me up here I will make that happen.
Old 09-15-2012, 09:40 PM   #18
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
Neat.
Old 09-15-2012, 09:44 PM   #19
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Subscribed for updates
LIQUIDSK8S is offline   Reply With Quote
Old 09-15-2012, 09:53 PM   #20
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
This is awesome, a fellow enthusiast with the access to a camera that 99% of us wouldn't be allowed to be in the same room with....
Bump and Kudos to your sir.
~Josh~
ballitch is offline   Reply With Quote
Old 09-15-2012, 09:57 PM   #21
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
Subscribed!
Very interested in the results. Thanks for taking the time to do this!!!
punkNdrublic04 is offline   Reply With Quote
Old 09-15-2012, 10:22 PM   #22
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by punkNdrublic04 View Post
Subscribed!
youre welcome
Old 09-15-2012, 11:42 PM   #23
JhnBrackett
Member#: 42460
*slow clap* you da man and thank you
JhnBrackett is offline   Reply With Quote
Old 09-16-2012, 03:59 PM   #24
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
PTP turbo blanket is installed, be looking for infrared updates tomorrow night.
Old 09-17-2012, 12:54 PM   #25
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
can't wait!
tazswing is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 04:44 AM.
