09-15-2012, 08:33 PM | #13976 |
Member#: 317014
Vehicle:2017 Crosstrek ISM |
Flyboy, what was the mileage on your Impreza when you did the diffs/tranny fluid?
09-16-2012, 08:52 AM | #13977 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
09-16-2012, 08:53 AM | #13978 | |
Member#: 314216
09-16-2012, 09:05 AM | #13979 |
Member#: 314216
And the handling with the 19mm bar is impressive. I think going to a 22 would be way to much without a bigger bar in front (does anyone even make one?).
And driving in crosswinds is much easier now, the car doesn't get blown around quite as much. I couldn't imagine driving a car with the sway bar |
09-16-2012, 09:19 AM | #13980 |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2014 Honda Accord Hybrid |
09-16-2012, 09:41 AM | #13981 | |
Member#: 310435
Vehicle:'12 Sport Limited Black - 255,685 miles |
The owners manual is all over the place with the differential fluids. It's got monograde 80W, 85W and a 90 (whatever that is). Then multigrade 75W/90 at the bottom. As long as it's GL-5, I guess either one of those is okay. |
09-16-2012, 09:58 AM | #13982 | |
Member#: 209172
Vehicle:2012 Impreza CLL BL2 |
G- |
09-16-2012, 10:21 AM | #13983 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
It is the same weight as what is recommended in the service manual (75W90). And I felt no difference in shifting between before and after the tranny/diff fluid changes. But I was surprised with how cruddy the fluid looked that came out of the rear diff. Apparently this is normal for the rear diff fluid (I asked in another thread).
09-16-2012, 12:04 PM | #13984 | |
Member#: 310435
09-16-2012, 12:12 PM | #13985 | |
Member#: 322264
What makes it so hard to change the fluid in the CVT tranny? Why did you feel comfortable doing the rear diff fluid change yourself, but not the CVT fluid change? |
09-16-2012, 12:31 PM | #13986 | |
Member#: 310435
09-17-2012, 07:40 AM | #13987 |
Member#: 325234
Vehicle:2012 Impreza Pre CVT |
there's not another brand of cvt fluid you could have used that comes in smaller quantity container.
09-17-2012, 08:37 AM | #13988 | |
Member#: 310435
09-17-2012, 08:39 AM | #13989 | |
Member#: 322264
That's a surprising bummer. |
09-17-2012, 10:41 AM | #13990 |
Member#: 323103
Vehicle:2018 WRX Pure der |
Does it hurt the lifetime of the vehicle with such dirty fluids? Will they change any of it under warranty?
09-17-2012, 10:55 AM | #13991 |
Member#: 322264
I doubt that having dirty fluid in the rear diff causes any harm. They are all that way. I'm told that the next time I change the fluid out of my rear diff, the Amsoil fluid I put in will look cruddy too. So I assume that looks are deceiving and that the fluid is doing its job in the rear diff regardless of its appearance.
I changed my rear diff and tranny fluids because I like to be proactive. But I doubt it was necessary. You should be safe following Subaru's recommended change intervals. |
09-17-2012, 11:21 AM | #13992 |
Member#: 330797
Vehicle:2012 Impreza 5dr Prm Satin White Pearl |
Fuel Range Computer
Hi Guys
I would like to get some input on others who own the 2012 Impreza 2.0i. I have the Premium 5 door wagon. When I purchased the vehicle I loved how we had a fuel range computer which told us the range we had left in the tank. However, I've noticed lately that its been either acting up or off. I use to see on a full tank an average of 420 miles - 450 miles UPON fill up. However, now when I fill the tank up, it says my range on a full tank anywhere between 380-340miles?!?! what gives?!?! I thought it could have been my driving habits but I even started to watch how I drove the car (commuter, don't go hard on the pedal or anything)...but I am just confused as to whether its the computer that is acting up? a leak? (not really possible since its a brand new car, at least i hope not). Could it also be the weather? I live in socal and its been in the 90s or high 80s lately compared to when I bought the car earlier this year? Any input? I dont drive in much traffic (lucky me, i go to work and leave work early enough to avoid most of traffic). So not sure whats up. I drive a mix of freeway and surface streeets, mostly freeways. Anyone else have the same situation? Any solutions or advice? |
09-17-2012, 11:37 AM | #13993 |
Member#: 330797
09-17-2012, 12:19 PM | #13994 | |
Member#: 314216
09-17-2012, 12:21 PM | #13995 |
Member#: 314216
Oh, and i got that car to slide yesterday attempting to take a corner at 35-40 with my new 19mm rear sway bar. Caught me off guard, i blame the tires though as it was sprinkling so the street was wet, but i have never had a car do that before.
09-17-2012, 12:50 PM | #13996 | |
Member#: 323103
I am in no way qualified to make these assumptions, lol, but i figure that would be the easiest way to calculate it since the car already has algorithms to figure out instant/avg mpg. |
09-17-2012, 01:18 PM | #13997 | |
Member#: 330797
A read in the manual doesnt say that it does calculate based on previous driving history/behavior, but just that it gives you a range on how many miles you can drive on the amount of gas in the tank. who knows, maybe ill just ask the dealer if it changes like that. its just weird going from 420-450 mi to 380 and yesterday after a fill it says only 340mi on a full tank. thats a huge jump. i feel like my old 2000 Honda Accord V6 drove further on a full tank of gas (granted the gas tank was a lot bigger) still, this 4 cycl should smoke it in terms of milage especially since its CVT. |
09-17-2012, 01:23 PM | #13998 | |
Member#: 302559
But if you pull of the highway, get dinner, then drive somewhere else to go shopping, then get gas, it will be down in the high 3xxs or low 4xx miles range for the range remaining on that tank. |
09-17-2012, 01:24 PM | #13999 |
Member#: 73068
I will say this again for those who missed. You do not have to change the rear diff fluids or any fluids for that matter before the interval specified by Subaru. You can however if you feel like it. Don't feel like you have to though.
With regards to the rear diff fluid, it will get dark and have a metallic look. This is completely normal and don't be alarmed. As stated above, you will see the same when you change out Amsoil fluids when the time comes. I just want to say this since it seems like people are getting nervous about not changing the fluids. It is completely optional and there is nothing wrong with using the OEM fluids. It is at the discretion of the owner to put aftermarket fluids if he so chooses to do so. Nothing wrong with that, but it is not necessary! |
09-17-2012, 01:31 PM | #14000 |
Member#: 323103
Lol well said st eye
Similar Threads | ||||
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
