Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 09-12-2012, 09:15 PM   #1
ricky0418
Member#: 236866
2013 Charger SRT8
white
Default 2011 wrx Normal driving datalog, Knocking?
its a 2011 wrx only mod a invidia catback, running a stage1 93 octane Cobb OTS map. is it knocking ? and what are my options should i try a different map?
https://docs.google.com/spreadsheet/...EcwVVh6RS1iSlE
ricky0418 is offline   Reply With Quote
Old 09-12-2012, 10:34 PM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
None of your log is useful. YouTube Wrx Cobb Datalog How to. You need to be in 3rd gear, just above 2k rpm and go WOT till redline. And where date to do so. Watch the video though and others. Great learning tools.
bacalhau16 is offline   Reply With Quote
Old 09-12-2012, 10:40 PM   #3
ricky0418
Member#: 236866
2013 Charger SRT8
white
so what is those numbers that showed on the feedback knock column? i was datalogging normal driving. oh man this stuff is complicated lol
Old 09-13-2012, 04:18 AM   #4
kaczmarz
Member#: 307624
2008 WRX Hatch
325/347, 380XT, 8 cm2
Touch the gas pedal only very slightly when you're under 2000 RPM at 3+ gear!
You don't have any boost/torque there.
Better yet, stay above 2000 RPM in 3+ gear all the time unless you're cruising.
kaczmarz is offline   Reply With Quote
Old 09-13-2012, 09:40 AM   #5
Cobb Tuning
Member#: 4803
You want to put the car under some load (if you can do safely) so we can see how it reacts. Check out our data logging video below.
Bill
Old 09-13-2012, 02:33 PM   #6
ricky0418
Member#: 236866
2013 Charger SRT8
white
i tried the best i could , but its a hard thing to do in NYC, here are 2 more datolgs i did today
https://docs.google.com/spreadsheet/...2tKSjFRaGlibUE
https://docs.google.com/spreadsheet/...1k1QmNadXlYdlE
Old 09-13-2012, 03:32 PM   #7
Delphi
Member#: 239335
Change your map to the 91oct map. You're getting fine knock learn in the high rpm's which isn't good. Post logs of the 91oct map.
Delphi is online now   Reply With Quote
Old 09-13-2012, 11:32 PM   #8
Cobb Tuning
Member#: 4803
You have some knock in the first log - I would reflash the 91 octane map. One of your A/F Learning 1 trims in the very low airflow range is borderline high (+7%) - I would keep an eye on that to see if it gets worse there (or in any range). You may have an intake tract leak.
Bill
Old 09-14-2012, 04:12 PM   #9
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill
Thanks ! I switched to the stage 1 91 octane map and i did 3 more datalogs , i tried my best to do it safely and without getting caught speeding .and i also changed to a new gas station.
https://docs.google.com/spreadsheet/...mR5anIxYnlmMEE
https://docs.google.com/spreadsheet/...3pac2NNNTBlZHc
https://docs.google.com/spreadsheet/...3BQME5qVHlSNEE
Old 09-15-2012, 02:39 PM   #10
Cobb Tuning
Member#: 4803
The first two logs look good. The last log has a single count of feedback knock correction. I would continue driving the car on the 91 map and see where your fuel trims end up (through a tank of gas). They were cleared when you reflashed the map, so they will take some time to populate.
Bill
Old 09-16-2012, 10:25 PM   #11
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill
this is a datalog i did today, stage 1 91 octane.
https://docs.google.com/spreadsheet/...kt4bktuUzNleWc
Old 09-17-2012, 09:41 AM   #12
Cobb Tuning
Member#: 4803
How much driving have you done since you reflashed the 91 map?
Bill
Old 09-17-2012, 10:03 AM   #13
ricky0418
Member#: 236866
2013 Charger SRT8
white
Bill
about 100 miles more or less
Old 09-17-2012, 11:47 AM   #14
cmiovino
Member#: 134005
2004 WRX Premium
I literally just swapped over to the 91 oct map after experiencing some FKL in the 2-3k range. Mine took effect immediately after driving and I had no knock. I'll log again after a week of driving, but in my opinion, what you were experiencing with the 93 oct map should have gone away after switching.
Old 09-17-2012, 12:26 PM   #15
ricky0418
Member#: 236866
2013 Charger SRT8
white
I don't really know what to do at this point :/ .How bad is it? Would a protune fix this ?
Old 09-18-2012, 03:34 AM   #16
bacalhau16
Member#: 297565
2011 WRX hatch
its not that bad. You're DAM is still at 1 which is good. This is basically saying you are on the optimal timing map.
Like said before, continue to get through this tank of gas, fill up with the best gas in town and log again.
Old 09-18-2012, 09:28 AM   #17
Cobb Tuning
Member#: 4803
Continue driving some more and then check the long-term fuel trims (A/F Learning 1 A, B, C, D. Switching to a quality gas brand, as bacalhau16 suggested, is also a very good idea. It could be what you were filling up with is very low quality (or even just the station itself). Or, you could have a mechanical issue that is causing a problem (fueling is a big area where you can have issues which is why it is good to check your long-term fuel trims once they've had enough time to populate more accurately).
Bill
