Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 09-15-2012, 06:42 PM   #1
Ti Pit
Member#: 146009
2005 Legacy GT Wagon
Default Replacing rear shocks
I'm about to attempt the replacement of my rear shocks, I'm going out on a limb and trying some KYB's that don't actually say they fit but that I think might fit. We'll see how it goes. They are already purchased and waiting for me to get busy.
Now to make this quicker, I noticed the rear shocks seem to be connected somewhere on the inside, I'm just wondering if I should be dismantling the bed liner to get to the top plates or if I have to go from the inside and take apart the rear seat and then the plastic surround. I hope it isn't much of a pain in the ass to get to.
Ti Pit is offline   Reply With Quote
Old 09-15-2012, 08:22 PM   #2
Ahzlon
Member#: 45216
2005 Baja Turbo
YOu get to the rear top hats behind the rear seat.
Ahzlon is offline   Reply With Quote
Old 09-15-2012, 08:50 PM   #3
Ti Pit
Member#: 146009
so I'm guessing I remove the plastic where the jack and the empty pocket are located?
Old 09-15-2012, 10:32 PM   #4
SVO1
Member#: 273287
05 baja/95L/04wrx
RBP/red/WRB
yes remove those two pieces and you will expose the top two nuts for the upper strut mount.
SVO1 is offline   Reply With Quote
Old 09-16-2012, 12:51 AM   #5
steven765
Member#: 105920
2006 Baja 5 Speed
Having just installed mine plan on an hour or two to assemble them if you're taking your time. Make sure to get the lower bolt hole 90 degrees to the line of the upper studs. I installed the 1" lift so that made mine even harder to install, but I suspect much of this will still apply. Two people are highly advised for this operation. Also if you have time go to a shop and have them do the springs with the wall mount compressor, the threaded rod ones from auto zone will be a real pain and will scratch the hell out of the powder coat on the springs.
For the installation i placed a 5ft concrete breaker bar on the body stop point and one of the trailing arms. Be careful not to bugger up the rear dust plate. I was literally hanging upside down with my legs wrapped around the bar and bouncing until bolt slid into the hole. I literally left a puddle of sweat on the garage floor. Loosen the top bolts so you have some play as the angle changes when the trailing arm flexes.
Then I got to the second shock:
To make it easier you still need the 5ft bar, but I placed a jack under the shock and compressed it up a bit. It took about 8 tries until the jack raised it just right so that when I lowered the armature the hole was in position for the bolt. Again not easy, yet much easier than not raising it, but I really could have used a second pair of hands.
steven765 is offline   Reply With Quote
Old 09-16-2012, 12:55 AM   #6
steven765
Member#: 105920
2006 Baja 5 Speed
Then again I just occurred to me the kyb's aren't the same height as the factory ones, Yours should be easier. This could also mean the auto zone threaded spring compressor's will not work. On the factory height springs I barely had enough height to remove the compressor's. Just a heads up.
Make sure you bleed the air from the shocks. For the factory ones you have to compress them inverted, hold the top down and release it in the upright position anywhere from 4-15 times. The way to check is when the shock is upright and you push down on it you should immediately feel the fluid damper engage. If it drops an quickly then squishes into the fluid you have air in the stock still. Factory manual says to keep them upright once they are bleed to prevent air from seeping back in. And this is definitely true. I laid one on it's side for a few minutes just to see, sure enough air was back in. So once bleed keep them upright! This also means you have to put them together upright, I managed it, but wow again NOT FUN. It took two night ~2 hours each to assemble the shocks/struts at home with a complete new assemble of factory parts. Just as a heads up.
Old 09-17-2012, 07:30 AM   #7
hocrest
Member#: 40687
Rather than use a 5' bar to spread down the hub. I followed the instructions in the FSM and used the stock screw jack between the knuckle and the body to get it down so the shock can be bolted up.
hocrest is offline   Reply With Quote
Old 09-17-2012, 02:28 PM   #8
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
I don't recall the rear shocks being that much trouble when I did my 2' lift a few years back. I did use a jack to push the strut up until it lined up with the holes though, and I was working alone (took two and a half days to do the lift)
Buck
Buck Rogers is offline   Reply With Quote
Old 09-17-2012, 03:34 PM   #9
steven765
Member#: 105920
2006 Baja 5 Speed
RTFM Is that in the body manual?
Old 09-17-2012, 03:45 PM   #10
hocrest
Member#: 40687
I looked it up about a year before I had the Baja when I had to replace a strut on my step daughters 2000 Lego. It was in the suspension section, but I don't recall what year between 2000 & 2004 it was.
