Old 09-16-2012, 10:59 PM   #1
Franko
Member#: 193628
2010 STI
SSM
Default 2010 STI 376whp 401lbft
Event: Road Dyno Session
Ambient Temp: 20c
Elevation: 100
Weather: Overcast
Car: 2010 STI
Tuner: Franko
Dyno Info: Virtual Dyno
Transmission: Stock 6 Speed
Gear: 3rd
Peak HP at RPM: 376 @ 6184
Peak Torque at RPM: 401 @ 4510
Baseline hp/tq for a stock on same dyno: no idea
Target Boost: 25psi
Target AFR: 11.5 (12.5 true gas afr)
Fuel: 91 octane with 50/50 meth
Engine/Power Modifications:
CP drop in pistons arp head studs etc etc...
20g XTR 8cm
GT spec UEL headers
Invidia Q300 Catless tbe
TGV deletes
Aquamist hfs 3
ACT HDSS clutch
Seems a bit low to me considering xluben is making 491 ft lbs on essentially the same setup but with e85. I figured I would be able to come close to that with 50/50 meth.
Are my numbers about right for the setup or is something else going on here and holding me back? Tuning gurus chime in please.
Franko is offline   Reply With Quote
Old 09-16-2012, 11:05 PM   #2
macker01
Member#: 210527
07 STi
JBP
About what RPM does it hit peak boost?
macker01 is offline   Reply With Quote
Old 09-16-2012, 11:11 PM   #3
Franko
Member#: 193628
2010 STI
SSM
3700 rpm i guess.. Its in the graph there.
Old 09-16-2012, 11:18 PM   #4
macker01
Member#: 210527
07 STi
JBP
Sorry forgot this was a road dyno. Does it seem to spool much slower than stock?
Old 09-16-2012, 11:37 PM   #5
Franko
Member#: 193628
2010 STI
SSM
Not bad. A little slower then stock naturally but keeps the car fun which is what I wanted.
Old 09-16-2012, 11:55 PM   #6
macker01
Member#: 210527
07 STi
JBP
Thanks. Numbers aside it looks like a strong setup.
Old 09-17-2012, 09:41 AM   #7
kleinkid
Member#: 27091
2010 STi SE
My 2010 STi is at 377hp 398tq.
Blouch 20g XT 8cm
DW 1000cc
AEM intake
AP uel header/up pipe
Invidea catted dp, Harmon Motive cbe
ETS tmic
open source tune
Similar results, all things considered.
kleinkid is offline   Reply With Quote
Old 09-17-2012, 10:18 AM   #8
KurtP
Member#: 44836
1999 Fozzy
looks like it is holding power up top really well. E85 will make more power than 91 + 50/50 though, so shouldnt be too surprised
Old 09-17-2012, 10:23 AM   #9
Franko
Member#: 193628
2010 STI
SSM
Blouch 20g XT 8cm
DW 1000cc
AEM intake
ETS tmic
open source tune
What are you running for fuel?
Old 09-17-2012, 02:02 PM   #10
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Thats about right. With a Fp green 7cm 2.4" and Meth i made 380/412 @22 psi. E85 is More potent and makes power easier than Meth. From what i see most 93 vs E85 tunes are 60-100whp different. e85 would put u near 450whp easily. Plus Xluben is running like 27-28psi to make those numbers.
Slimsti is offline   Reply With Quote
Old 09-18-2012, 01:51 PM   #11
kleinkid
Member#: 27091
2010 STi SE
Franco--Deatschwerks 1000 cc injectors, DW 265 fuel pump, stock rails.
Looks like what you are seeing is probably about right. Have fun and enjoy.
Old 09-18-2012, 02:18 PM   #12
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Are you iwg?
k04sti is offline   Reply With Quote
Old 09-18-2012, 02:51 PM   #13
Franko
Member#: 193628
2010 STI
SSM
Yep, running the internal gate in the 20g.
Thanks! I meant to ask what kind of fuel you are using. 93 oct? Meth?
Old 09-18-2012, 03:45 PM   #14
Nickcrsx
Member#: 196071
Post Logs so we can see Timing, Boost, RPM, Etc....
Nickcrsx is offline   Reply With Quote
Old 09-19-2012, 12:12 AM   #15
kleinkid
Member#: 27091
2010 STi SE
Franko-- 92 octane, here in WA state.
Old 09-21-2012, 03:16 AM   #16
Ray_21
Member#: 307236
ewg or iwg?
Ray_21 is offline   Reply With Quote
Old 09-21-2012, 06:43 AM   #17
k04sti
Member#: 171773
04 wrx sti
Originally Posted by Ray_21 View Post
ewg or iwg?
Learn to read
Old 09-21-2012, 02:53 PM   #18
Ilovecugars
Member#: 299442
2005 Forester XT
Franko, what part of easten Canada? As far east as the maritimes by chance?
Ilovecugars is offline   Reply With Quote
Old 10-03-2012, 05:19 PM   #19
Franko
Member#: 193628
2010 STI
SSM
Nope, newfoundland. Yeah, its out there.
