Old 09-20-2012, 12:05 AM   #926
rynzilla
Member#: 284635
2011 WRX STi
Wow thats an amazing color, also it looks very clean. Do you do this professionally?? I'm planning to have my car dipped, I would really like a new look
Originally Posted by DKDunn04 View Post
Entire car. Used 3 gallons through the Wagner gun, and will put on at least one more. Its only been on 2 weeks, but its holding up great. No chips in it, and all the bird crap and pollen has washed right off.
rynzilla is offline   Reply With Quote
Old 09-20-2012, 12:42 AM   #927
jesseber
Member#: 293509
2004 WRX STI
Nice! That's bad ass man. Let us know how it holds up. Does it pose a risk to your factory paint if/when removed?
jesseber is offline   Reply With Quote
Old 09-20-2012, 07:38 AM   #928
DKDunn04
Member#: 275640
1968 Corvette-Yellow
2004 STI-Silver
I dont do it professionally, just took my time. When you take it off, I have found that the paint under it actually looks better than it did before. Its like a stick on clay bar!
DKDunn04 is offline   Reply With Quote
Old 09-20-2012, 10:28 AM   #929
Trudd84
Member#: 250706
2004 Impreza WRX
WR Blue
There are also two videos a few pages back that I posted of removal, and the paint actually looks cleaner than before. Its all about an even thick build-up so you can actually peel it off!
Trudd84 is offline   Reply With Quote
Old 09-20-2012, 11:01 AM   #930
jesseber
Member#: 293509
2004 WRX STI
Wow. That's tempting..
Old 09-20-2012, 11:09 AM   #931
Trustkevin13
Member#: 259184
2008 Subaru WRX
Looks awesome with less chrome back there.
Trustkevin13 is offline   Reply With Quote
Old 09-20-2012, 12:38 PM   #932
dye.sti
Member#: 136297
OBP w/ Red and Flat Black
plasti-dipped my rear badges and side fender badges
dye.sti is offline   Reply With Quote
Old 09-21-2012, 10:36 PM   #933
BeachZone
Member#: 232668
'11 Sti Limited
Matte White
Did you use anything to thin the Plastidip before applying it?
-Beach
BeachZone is offline   Reply With Quote
Old 09-22-2012, 08:21 AM   #934
DKDunn04
Member#: 275640
2004 STI-Silver
I used the pre-thinned gallons from dipyourcar.com. Next time I will buy the dip myself and thin it. Most people use a 1:1 ratio.
Old 09-23-2012, 12:11 PM   #935
BeachZone
Member#: 232668
'11 Sti Limited
Matte White
Hmmmm... I wonder what they thin it with and whether or not it has long term affects on the paint. I've seen a couple places where people say that it has made their paint somewhat hazy, with the clearcoat ending up not as "clear" as before? IDK just curious
-Beach
Old 09-23-2012, 02:51 PM   #936
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Xylene to mix it.
Smoke is offline   Reply With Quote
Old 09-23-2012, 05:53 PM   #937
DudeCris
Member#: 314662
2006 WRX Limited
Can't say I've been an overall fan of orange but you sir have done a hella good job of showing me some cars do fit it. Looks sick man
DudeCris is offline   Reply With Quote
Old 09-25-2012, 07:24 PM   #938
mstngturk10
Member#: 331677
2006 2.5i Wagon
Steel Gray Metalic
My project for the past weekend. Did the stock '06 rims and the grill surround. Painted the calipers while I had the wheels of. Great cheap way to make your car look good. Love this stuff!!
mstngturk10 is offline   Reply With Quote
Old 09-25-2012, 07:40 PM   #939
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
You painted your calipers with plasti-dip?
Do you have any idea how hot those bad boys get? Calipers require high temp materials.
Old 09-25-2012, 09:50 PM   #940
bugeye_ry_RI
Member#: 332552
2003 wrx
My buddies using this stuff to paint his car, i don't know how I feel about it but it seems pretty legit
bugeye_ry_RI is offline   Reply With Quote
Old 09-25-2012, 10:49 PM   #941
mstngturk10
Member#: 331677
2006 2.5i Wagon
Steel Gray Metalic
Nah. I got some caliper paint for them. Just did it since I had the wheels off
Old 09-28-2012, 01:07 PM   #942
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Can you guys chime in on how this matches the oem dash in a 05 sti? (black)
I want coat my gauge pod with it, but it has a good bit of crevices that are hard to dust off. Does dust stick to the plasti dip pretty good?
This is actually the same color as mine (and the same gauge pod actually).
It's def not a bad match, but i think the difference is the kicker. Is there a somewhat glossier finish that might match better?
IceWilly is offline   Reply With Quote
Old 09-28-2012, 01:41 PM   #943
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
If you spray close to the surface the layers will come out more glossy. normally dust sticks pretty good to it. can probably clean it with a brush tho. if you dont like it you can peel it off.
Old 10-10-2012, 01:10 PM   #944
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
Just ordered a wheel kit from dipyourcar.com
Does anyone have experience with their shipping? How long does it usually take? I'm trying to get my wheels dipped before winter mode.
Daniel_DeWitt is offline   Reply With Quote
Old 10-10-2012, 02:49 PM   #945
aliasgx
Member#: 271589
Obsidian Black Pearl
Would also like to know. Thinking about buying the wheel kit as well.
aliasgx is offline   Reply With Quote
Old 10-14-2012, 10:26 AM   #946
Decipher
Member#: 262760
2011 WRX Hatch Limtd
I'm thinking about dipping my front lip white, but I've read time and again about how the white gets filthy. Anyone try a clear layer on top of the dip to help with clean-up and dirt resistance?
I've read about this matte clear, but I haven't seen it.
Decipher is offline   Reply With Quote
Old 10-15-2012, 11:58 PM   #947
Freemanwrx
Member#: 270135
Loving the plasti dip!
Freemanwrx is offline   Reply With Quote
Old 10-17-2012, 03:34 PM   #948
goob_os101
Member#: 173185
2005 Saabaru
I dipped the chrome grills and bottom of the bumper.
goob_os101 is offline   Reply With Quote
Old 10-17-2012, 10:39 PM   #949
ScoobyBlack
Member#: 123978
04/6 Subaru WRX STi
'Identity Crisis'
Can't remember if I posted mine up or not. Did my car a while back.
And did a tutorial on the process:
http://www.youtube.com/watch?feature...&v=h4NUjVh3zTA
It was a fun project. So far it's been about 2,000 miles and two months. I've been on the highway with it quite a bit, and I've scrubbed the hell out of it in the car wash, and it still looks new. Definitely a good investment if you just want to clean up the look of your car (which I obviously had to).
ScoobyBlack is offline   Reply With Quote
Old 10-17-2012, 10:45 PM   #950
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
You can clear it. But be warned, its gna be a PIA to remove it.
BSP671 is offline   Reply With Quote
WTB Plasti wheel well covers EJ22t Kid Private 'Wanted' Classifieds 3 01-21-2009 06:46 PM
Decided to Suede & Plasti badfish1134 North West Impreza Club Forum -- NWIC 22 10-30-2008 07:11 PM
Plasti-Kote 5604 - Silverthorne match.... -Kevlar- Interior & Exterior Modification 3 05-09-2008 01:46 PM
repainting optical drives, where can I buy Plasti-kote online? captaind Off-Topic 2 10-21-2006 05:36 PM
Is the WRX OEM front spoiler plasti or fiberglass? thejean Interior & Exterior Modification 5 02-04-2003 02:47 PM
Message Board Statistics All times are GMT -4. The time now is 06:37 AM.
