Old 11-17-2011, 11:33 AM   #51
hardhitter_alert
Member#: 293841
2007 STi
preliminary dyno:
very slow spooling right now
hardhitter_alert is offline   Reply With Quote
Old 04-16-2012, 08:43 AM   #52
one11
Member#: 255398
Any updates
one11 is offline   Reply With Quote
Old 09-18-2012, 10:44 PM   #53
hardhitter_alert
Member#: 293841
2007 STi
UPDATE: I am seeing full boost at 5,300RPM which really sucks. Does anyone know how I can fix this? Is it the FMIC? I see someone else with the same turbo making full boost at 3,400rpm. http://legacygt.com/forums/showthrea...ek-171262.html
Old 09-21-2012, 01:19 AM   #54
compression/leakdown test time
bet its toast
Old 09-21-2012, 01:22 AM   #55
hardhitter_alert
Member#: 293841
2007 STi
bet its toast
Yeah I know you said that already but why? Wouldn't there be detonation or some kind of better indication?
Old 09-21-2012, 02:26 AM   #56
the det is all over and done witn and is what caused the issue
im betting its toast...99.4% sure
Old 09-21-2012, 02:29 AM   #57
hardhitter_alert
Member#: 293841
2007 STi
Ever since I started tuning it almost a year ago there was only slight knock once in while and it was tuned out. The lag has always been the same. Do you live in Houston?
Old 09-21-2012, 02:33 AM   #58
Just1More
Member#: 319078
2005 STi
Vacuum leak? Mine pulls 18-20" at idle
How quickly does the vacuum guage jump to 0 when you hit the throttle from an idle? It should be almost instant no matter if you're coasting or idling...good luck man, also keep an eye on oil pressure
Just1More is offline   Reply With Quote
Old 09-21-2012, 02:35 AM   #59
hardhitter_alert
Member#: 293841
2007 STi
Yes I have been sealing leaks all day and the vacuum is now at 18 with the AC on and 22 with it off at idle.
Old 09-21-2012, 03:48 AM   #60
if there is raw exhaust coming outta the oil filler tube with the engine running at operating temp, there are 1 or more pistons with bad ringlands and you would have to have a pretty bad leak to get that slow a spool...either a boost leak---it would run real rich on boost....or an exhaust leak pre turbo...and that would be LOUD and leave carbon/scorch marks where it is leaking
and/or the tune is so far off that it isnt ever gonna spool without a real tune
Old 11-19-2012, 11:38 PM   #61
dwmilton
Member#: 323318
update?
dead?
dwmilton is offline   Reply With Quote
Old 11-20-2012, 11:47 AM   #62
myblusti
Member#: 337871
2010 5-door STI
blue/gold
with a vacuum leak its going to run horrible more than likely. what kind of manifold and turbo are you running? also what about exhaust. obviously and i may be stating the obvious your exhaust is what powers the turbo if your engine isnt exhaling properly your not going to spin that turbo adequatly. my expertise is mainly from nissans primarly the rb25 but a turbo setup is a turbo setup. if the turbo is too big or the exhaust is impedded its going to slow the spool. also is the turbo a journal or ball bearing? journals will also spool slower. but tend to be cheaper. your graph looks to be pretty linear though. at least to me.
myblusti is offline   Reply With Quote
LOTS OF NEW PARTS! AP v2!TXS TBE! MORE! nothingclub Engine/Power/Exhaust 27 08-14-2007 04:08 PM
FS: '85 MR2, lots of new parts. daniel_gabriel Private Vehicle 'For Sale' Classifieds 0 06-08-2006 10:31 AM
Fresh pics of the Mighty WRX, lots of new parts!! MightyWRX02 Member's Car Gallery 71 12-09-2005 09:47 PM
Lots of new parts must go!!! Yellow03Wrx Tri-State Area Forum 0 02-20-2003 08:09 PM
Lots of new parts in stock today! Z1 Performance Tri-State Area Forum 14 05-22-2002 12:45 PM
