Old 09-21-2012, 10:58 AM   #51
Tripintaz
Member#: 245218
2013 STI Limited
Still sounds like your tune or your MBC is setup wrong. If air was rushing past the rings like a hurricane you would be burning quite a bit of oil. It does not hurt to perform a compression test just to make sure. But I still think you have something set up wrong.
Old 09-21-2012, 11:40 AM   #52
hardhitter_alert
Member#: 293841
2007 STi
The only thing I can really tune is the AFR and timing. With the hybrid boost control the WGDC is set to 100% at WOT so the MBC takes over.
hardhitter_alert is offline   Reply With Quote
Old 09-21-2012, 12:11 PM   #53
stevejones19
Member#: 275250
2006 WRX
Why not just suck it up it and take it to a professional. You're not tuning a mustang anymore. Take it there, and ask him what you did wrong and where to correct NEXT time.
stevejones19 is offline   Reply With Quote
Old 09-21-2012, 12:51 PM   #54
hardhitter_alert
Member#: 293841
2007 STi
I don't feel like wasting a ton of money taking it somewhere. When I had my Mustang tuned by a professional it drove terribly and that's what got me started in tuning in the first place. I tuned it a lot better myself and I didn't have to pay anyone. Every time I added an upgrade I didn't have to pay to get it tuned again.
Old 09-21-2012, 01:55 PM   #55
Source,LLC
Member#: 322524
3.5 WRX STI
It sure sounds like you aren't having the same luck with your subaru though. These cars are extremely fickle when it comes to tuning, they really need a special touch, and experience to make them run like they should. There is ALOT more to tune then simply AFRs and boost. MAF scaling needs to be correct, you need the correct injector latency, good AVCS, correct turbo dynamics, along with those boost and fueling tables. If you need some tuning advice (which in my opinion is the root issue, especially if you can't find any mechanical issues) then I'd head over to the romraider forums. You will find much more information and better advice there.
Also a quality e-tune only runs you about $200, which is an extremly small investment on your car that you've already put much more into. There are more then a handful of very reputible ones here. Go check the proven power bragging section for them.
Source,LLC is offline   Reply With Quote
Old 09-21-2012, 02:05 PM   #56
hardhitter_alert
Member#: 293841
2007 STi
I have been to the romraider forums and I know that there is more to a tune than what I have mentioned but since the maf scaling, injectors, ect are already correct I am talking about the things that can make a difference to spool time. The tune is never going to be correct if there are mechanical issues so I want to make sure that everything is right before I consider tuning.
Old 09-21-2012, 02:13 PM   #57
hardhitter_alert
Member#: 293841
2007 STi
Here are the exhaust leak locations that I have found. I used brand new gaskets when I installed the header and I torqued the bolts to spec. Should I tighten them more? How should I solve the leaks at the header joints? One of the bolts is actually missing. The joint at the uppipe does not appear to be leaking but the it clearly is not a flat seal. It is bowed out slightly.
Old 09-21-2012, 02:24 PM   #58
stevejones19
Member#: 275250
2006 WRX
I've seen plenty of people just have those slip joints in your headers. That Will take care of that.
Old 09-21-2012, 02:31 PM   #59
hardhitter_alert
Member#: 293841
2007 STi
What will?
Old 09-21-2012, 04:16 PM   #60
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^Get that **** off of there man.........those leaks and the quality header youve got there are gonna equal many problems. I had a similar header to yours.......lasted about 10 miles before it started runnin rough.....boostin less and less......i inspected my header joints and what not. Lets just say after i saw the obvious sooting at what appeared to be at every connection on that header...even at the head, i swapped the oem cast manifold back on and am sooooo satisfied.
Old 09-21-2012, 04:42 PM   #61
hardhitter_alert
Member#: 293841
2007 STi
Well I was able to tighten the bolts at the heads to 55 ft-lbs so they are a little bit tighter. The problem is definitely at the slip joints. Can I just get them welded up? I could feel the air blowing out a decent amount.
Old 09-21-2012, 05:41 PM   #62
stevejones19
Member#: 275250
2006 WRX
Haha I was thinking faster than typing. I meant to say people have the slip joints welded so they won't leak there. My bad.
Old 09-21-2012, 05:47 PM   #63
Tripintaz
Member#: 245218
2013 STI Limited
What POS header is that? I would be livid if I bought a header and it fit like that.
Old 09-21-2012, 06:00 PM   #64
hardhitter_alert
Member#: 293841
2007 STi
I just had them welded and it doesn't seem to be leaking now.
Perrin
Old 09-21-2012, 06:26 PM   #65
hardhitter_alert
Member#: 293841
2007 STi
Wow and that increased the spool by 0 RPM
Old 09-21-2012, 06:47 PM   #66
DaveC113
Member#: 126901
2016 STi
ISM
Did you replace all the exhaust gaskets? When you get a leak like you're showing you must replace the gaskets, just tightening down the bolts won't so it.
An exhaust leak will certainly increase boost lag, even a very small one.
DaveC113 is online now   Reply With Quote
Old 09-21-2012, 06:54 PM   #67
hardhitter_alert
Member#: 293841
2007 STi
Do I didn't replace the gaskets. They were expensive double thick ones and the leaks seem to be gone now.
Old 09-21-2012, 06:54 PM   #68
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Perrin
Real perrin or a copy?
If real send them pictures. That's crap.
Old 09-21-2012, 07:05 PM   #69
hardhitter_alert
Member#: 293841
2007 STi
Do the copies actually say Perrin on them?
Old 09-21-2012, 07:38 PM   #70
hardhitter_alert
Member#: 293841
2007 STi
Is it possible one of the boost controllers is not working correctly?
Old 09-21-2012, 07:47 PM   #71
the suicidal eggroll
Member#: 51961
2005 STi
A bad boost controller won't delay initial spool, but it might increase the amount of time it takes for the boost to go from wastegate pressure to target boost. If you notice it hitting wastegate pressure very quickly, then taking forever to go from there to target boost, that's when you would look at the boost controllers. If it takes forever just to get to wastegate pressure then that's not the issue.
Old 09-21-2012, 08:10 PM   #72
hardhitter_alert
Member#: 293841
2007 STi
How would I know what the wastegate pressure is? I am commanding 100% wastegate duty cycle in the tune at WOT and letting the MBC take over. Target boost is higher than actual.
Old 09-21-2012, 08:38 PM   #73
Member#: 51961
2005 STi
The turbo specs should say. It's usually around 7-15 psi
Old 09-21-2012, 10:15 PM   #74
hardhitter_alert
Member#: 293841
2007 STi
1 Bar / 14.7 PSI
Old 09-21-2012, 10:23 PM   #75
hardhitter_alert
Member#: 293841
2007 STi
I have tried adding timing.. up to 8 degrees advance with no knocking and the spool is even slower.
