#1 |
Member#: 298536
South East
Vehicle:2011 wrx Satin white |
https://docs.google.com/spreadsheet/...k1JeEtqWHJsUUE
Mods: Cobb SF Intake, Invidia Catback exhaust, Cobb accessport. i am not sure what is wrong, boost creeped only once in the beginning and now it won't go past 15psi and i have reflashed.
#2 |
Member#: 332937
Check out cobbs website they have maps with high and low waste gates address the problem you are having.
#3 |
Member#: 298536
South East
#4 | |
NASIOC Manufacturer
Member#: 4803
Thanks, Bill |
#5 |
Member#: 297565
Vehicle:2011 WRX hatch Silver |
The LWG map would have a lower target boost. If you are not achieving the boost u want with the LWG or normal map, then the HWGap is the map you want to use. On my 2011, I had to use the HWG map when i was jot stage 1 and stage 2.
#6 |
Member#: 298536
South East
So you had to use the highwaste map?
#7 |
Member#: 298536
South East
#8 | |
NASIOC Manufacturer
Member#: 4803
Mileage should not be notably impacted by these maps, but you will have more power across most of the RPM range, so if you take advantage of that to accelerate faster than you would before, mileage could decrease a little. Bill |
#9 | |
Member#: 298536
South East
#10 |
Member#: 228010
Vehicle:2012 WRX Prem Hatch Dark Gray Metalic |
Just out of curiosity - how did you do your test run? I thought I was underboosting because no one ever told me (even cobb after showing them my datalogs) how to log a proper run. Once I put the car in third and floored it at 2K, I saw a proper boost build, peak, and trail off through the RPM range until redline.
In your log I see you didnt step on it till 3200K (i think since its cut off). And we dont know what gear you are in. After I did it the way I described above I saw I was actually over-boosting a bit at 17.23psi. |
#11 | |
Member#: 298536
South East
