Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 09-20-2012, 07:10 PM   #1
redrex2002
Member#: 118915
2002 wrx
srp
Default misfire code help please
hey guys, where do i begin...
i own 2002 wrx that i bought in 2005 with 42k miles on the clock. it now has 202k miles and i just recently gave it a fresh coat of paint. while doing the paint job and waiting for my mechanic buddy to put in some power steering lines the car sat around for about a month, only being started briefly to move it around the parking lot and the shop. i got my car back last night and started driving it around town running errands. i was able to drive maybe 5 or 6 miles before my cel started flashing at me. so i scanned the code and it was a p0304. so i had the car towed back to the shop today and i swapped out the coilpacks and the spark plug.
when i go to start the car and see if all is well it starts perfectly and runs normal for the first 30 or 45 seconds, then the motor starts to shake and run rough. then the check engine light begins to flash again and i shut it off.
i am at a loss for what to do next and rather frustrated. over this last summer i have put 800 dollars of paint and clear, as well as a starter (x4), cps sensor (x2), battery, spark plugs (x4), and one coilpack for cyl. #3 all to try and pix a p0335 cel that as still to this day eluded capture. i have all but run out of money at this moment, right now me and my wife are sharing one car which is getting almost impossible now that school has started.
please help me save my car, if anyone has any ideas as far as what i should look into next i would really appreciate it.
and now banna's
redrex2002 is offline   Reply With Quote
Old 09-20-2012, 07:58 PM   #2
pghana66
Member#: 302066
have u had the timing belt serviced?
pghana66 is offline   Reply With Quote
Old 09-20-2012, 08:40 PM   #3
redrex2002
Member#: 118915
2002 wrx
srp
yes at around 120k
Old 09-20-2012, 08:54 PM   #4
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
There are a ton of threads, search P0304. This misfire code can be everything from needing plugs replaced, to your motor having ringland issues.
Start diagnosing with the easy stuff, plugs and wires, moving them to different cylinders and check lights.
Best thing to do is a compression/leakdown test if you have the equipment. It's pretty cheap to get done.
You can search a ton, but there are so many causes you need to get your car looked at professionally if you don't have experience working on cars.
How would this be the first thing you ask about for a misfire?
Also, P0304 is a cylinder 4 misfire, not 3.
GGSimpreza is offline   Reply With Quote
Old 09-20-2012, 10:45 PM   #5
pghana66
Member#: 302066
was looking at the other code in the thread saw cps was maintenaced, car starts but then goes awkward. 200k, figured id ask as didnt see it in the listed updates.
Old 09-20-2012, 11:23 PM   #6
redrex2002
Member#: 118915
2002 wrx
srp
my mechanic said i should try and find out where the pcm is located, he said i might have a bad ground somewhere in there because we have eliminated the plugs coilpacks and wires unless there is a broken wire somewhere in the harness.
on a side note does anyone know if the engine wiring harness from a 2004 wrx will swap into my 2002 wrx?
Old 09-20-2012, 11:55 PM   #7
nomoredsm
Member#: 281987
2002 wrx wagon
i strongly suggest a compression check and if good then a leakdown test.. My 02 wrx acted similarly when piston #4 had a cracked ringland. I changed plugs, swapped coilpacks, cleaned grounds, cleaned maf, but rather than waste $ i just swapped the coilpacks to see if the miss went from cyl 4 to another and when it didnt i did a hot compression check to find only 90psi in cyl 4. Also, if cyl 4 is missing then you will most likely wipe out rod bearings in cyl 2, i did.. Its a horrible feeling to find that a rebuild is whats needed, so have some ginger ale handy to calm that sick stomach!!
nomoredsm is offline   Reply With Quote
Old 09-21-2012, 12:14 AM   #8
TwoFifty
Member#: 261764
2003 Impreza WRX
The best place you can start with a misfire in my opinion is this,
Swap plug from cyl 4 to different cylinder, see if misfire follows
Swap coil from cyl 4 to different cylinder, see if misfire follows
Swap injector from cyl 4 to different cylinder, see if misfire follows.
If code follows part then you know where the problem lies.
If not could be an internal engine issue, Perform Compression test and leakdown test!
In fact you can perform a compression test while you've got that plug out to move it, might save you a little time depending on the results.
TwoFifty is offline   Reply With Quote
Old 09-21-2012, 04:56 PM   #9
redrex2002
Member#: 118915
2002 wrx
srp
thanks guys i am not shure that it is an internal problem. because when i start it up it takes 30 seconds to a minuet for the light to start flashing. then if i clear the code while it is running it runs fine for annother min. then the light starts blinking again. i would think that if a valve is sticking or a ringland was cracked then it would start flashing as soon as i started the car and would return immediatly after being cleared while it was running
Old 09-22-2012, 01:13 AM   #10
laxton
Member#: 324094
02 wrx
wrb
I HAD THE EXACT SAME PROBLEM! Changed coil packs and plugs and cleaned mafs.. Still nothing. Done a comp test and it was 80psi! Put in a scope and seen bad valves so I got all new ones. When the head was removed I descovered I has multiple cracks in my head. (explanes why it runs fine when cold) its bc the cracks were small but as it heated up the cracks would expand and I would lose more compression. Please take my advice and get a test ran to save u more time.
laxton is offline   Reply With Quote
Old 09-22-2012, 10:30 AM   #11
redrex2002
Member#: 118915
2002 wrx
srp
thanks i definitely will. i have access to a totaled 2004 wrx is there anything stopping me from swapping that motor and harness into my car?
Old 09-22-2012, 12:43 PM   #12
Haelan
Member#: 151045
2013 Subaru STI
CBP
Why not do a compression test on cylinder #4 first? You'll know in 10 minutes whether there is a major problem or not.
Haelan is offline   Reply With Quote
Old 09-23-2012, 01:03 PM   #13
nomoredsm
Member#: 281987
2002 wrx wagon
You can lead a horse to water, but cannot make him drink
Old 09-23-2012, 01:23 PM   #14
redrex2002
Member#: 118915
2002 wrx
srp
i am going to have my mechanic do a compression test but my car is at work right now and i do not have access to it untill monday. i am obviously going to perform all the tests and check before i get involved in a motor swap i was just making sure that if it does come down to a bad head or piston etc. that i can use a motor from a 2004 wrx with half the miles that my car has and was running up untill a week or so ago when my friend rear ended a dump trunk lol bad for him great for me potentially
Old 09-24-2012, 10:31 AM   #15
frostmasta
Member#: 217178
I had same issue, turns out the timing belt had slipped 1 tooth off.
frostmasta is offline   Reply With Quote
Old 09-24-2012, 01:41 PM   #16
redrex2002
Member#: 118915
2002 wrx
srp
if the timing belt was mis-aligned wouldent both cyl. number 2 and 4 be having problems? annother thing to dbl. check i guess thanks guys. i am trying everything i can to save my baby. just got to wait for my mechanic to have time to get it in and start running down the list of possible problems
Old 10-01-2012, 03:18 PM   #17
redrex2002
Member#: 118915
2002 wrx
srp
ok i finally had time to do the compression test today. the results were
cyl. 1, 135 psi
cyl. 2, 142 psi
cyl. 3, 132 psi
cyl. 4, 148 psi
it seams that the motor and its internals are A-OK, especially for the amount of miles that i have on her. lol i guess running 4 quarts of mobil 1 full syn. and a quart of lucas really does do the trick lol.
any more ideas of where to look next. wensday probable i am going to JB weld a peice of scrap metal over the flex section of my downpipe because i have a really big exhaust leak commin from there. hopefully that helps but i am still open to any other things to check out.
and thanks for all the help so far guys.
Old 10-01-2012, 06:46 PM   #18
quazimoto
Member#: 70395
Old 10-01-2012, 08:05 PM   #19
Kastley85891
Member#: 127704
2013 Leggy
Scooby no4 - huntin for 5
My fix was as simple as a loose negative battery terminal
Old 10-15-2012, 01:29 PM   #20
redrex2002
Member#: 118915
2002 wrx
srp
hey guys finally got my misfire problem figured out last friday. finally got around to swapping the fuel injectors around and sure enough the misfire went from #4 to #2, so out came all 4 injectors and i shipped em all out to deatschwerks saturday. hopefully ill get em back thursday and i can have my baby up and running by the weekend. damn it feels good to finallyhave this problem figured out it only took me a month and a half to find the time lol
Old 10-15-2012, 03:50 PM   #21
CanadianImprezaSTi
Member#: 312159
2004 WRX
Glad to hear you solved it without a rebuild!
Sorry to drift off topic, but since metal expands under heat wouldn't it close the cracks as it got hotter?
Not to mention, small cracks in the heads of a WRX are fairly common.
I'd say your valves were the only issue.
Joel
CanadianImprezaSTi is offline   Reply With Quote
Old 10-15-2012, 07:57 PM   #22
danger1138
Member#: 279525
04 rex luger!
Damm. I love good endings!! Gives me hope in regards to po304 code on my hybrid setup. Though i doubt its a piston problem in mines but u never know.
danger1138 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:27 AM.
