Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 09-22-2012, 01:04 AM   #176
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
wtf is the difference..lol
Celery GT-5 is offline   Reply With Quote
Old 09-22-2012, 10:05 AM   #177
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
With the hyperbolic comments here you'd think the STI trips over itself and explodes when you try to turn it in. Am I the only one that with a STI that destroys curves and corners? I don't even have a bigger anti-sway bar.
To counter a previous post I really don't think the BRZ will leave your STI for dead in a corner. In the same corner the STI probably requires a lower entry speed and a later turn in but it'll exit the corner sooner and with a higher rate of speed. The BRZ may feel faster but feelings are just that.
I appreciate the BRZ. I have a well balanced RWD turbo Ford which is a joy to drive in twisties. But I think some of the rhetoric is a bit overboard and misleading to uninformed readers considering the two vehicles.
Mike Costin is offline   Reply With Quote
Old 09-22-2012, 10:17 AM   #178
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
At least from WRX to BRZ there is no comparison on cornering Mike.
When the dealership got one in they let me take a test drive with one of the sellers who autox's an MR2. We took one of the tight corners in town, labeled 25mph that the wrx doesn't like to take much past 35 at 50 and there was still room to go faster in the brz. The difference between at least the WRX and BRZ is that the BRZ just feels very solid thru the corner, very little body roll and a lot of confidence.
Mind you this is a 2011 which I have been informed is a lazy boy with a turbo attached.
CopperTopNWOR is offline   Reply With Quote
Old 09-22-2012, 03:48 PM   #179
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah the WRX has no finesse to it. It can claw its way around corners nicely but it has no balance. It just turbolag, huge wave of torque, slam on the brakes to avoid understeering into a tree at that point you can probably go WOT in anticipation of the corner exit which I think is the WRX's strength IF you get back on he throttle soon enough to kill the lag other wise you are a dead fish coming out of the corner...its really not something that is rewarding to do on curvey back roads and the brakes are far too weak for the track. Seems like auto x might be ok though from what I hear.
I just parked next to a WRB brz...the size/practicality downgrade is just not in the cards right now.
Old 09-22-2012, 08:30 PM   #180
iLuveKetchup
Member#: 66258
Originally Posted by Jive Turkey View Post
the STi is so heavy and it plows itself through corners and i always have to ****ing give it so much throttle to keep form understeering when i want to go into the corner fast.
The problem is you are adding throttle when you no longer have any grip. I do I agree that the STi is a plow machine. lol
iLuveKetchup is offline   Reply With Quote
Difference in weight from STI to STI KAT_Ayanami General Community 15 11-08-2009 11:14 PM
Conversions from Sti to 2.5i and WRX to 2.5i (2007 2.5i) Sterlingw Normally Aspirated Powertrain 4 08-17-2008 11:35 PM
TMIC compatibility from STi to WRX.... mindchatter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-16-2005 11:47 AM
Any benefit going from STi to APS TMIC? mhartwell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-31-2005 12:46 AM
From STI to a 2.5 RS Random thoughts brunetmj General Community 43 06-28-2004 12:19 PM
