#1551 | |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
#1552 |
Member#: 179846
Vehicle:07 STi MPS Build EFR 7670 TS |
i actually put the clip on throw out bearing it self lol dont ask
#1553 |
Member#: 124282
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
#1554 |
Member#: 195711
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Oh okay. I found that if you have the Pressure Plate on the bench, plate down and let the throw out bearing settle, you can pop it out very easily with a flat head screw driver and a twist. Whew. Thanks gentlemen!
#1555 | |
Member#: 190729
The clip never comes out of the pressure plate for any reason. |
#1556 |
Member#: 195711
#1557 |
Member#: 179846
was about to renew tabs after car is all back together guess what emissions test required wtf...
now i need AP |
#1558 |
Member#: 65140
Vehicle:2007 STI Limited#213 05 STI (rip) 03 WRX (rip) |
#1559 |
Member#: 179846
Been getting weird AFR spikes lately, not sure if its the Innovate MTX gauge or its actual misfires! Feedback any one?
https://docs.google.com/open?id=0B8g...W9UczUzQUJLbU0 https://docs.google.com/open?id=0B8g...UpVdmJNbmFORDQ https://docs.google.com/open?id=0B8g...XV1VmE1RjlSUWs https://docs.google.com/open?id=0B8g...3JqYkRaOUE0WVU Happens at random boost levels, usually anywhere from 4500 to 5500 rpm under load. Same with meth injection as well Cant really feel it in the car, also knock sensor is quiet. Running Brisk 2 step cold plugs gaped to .030 and factory coil packs. Last edited by Bariga; 09-17-2012 at 04:46 PM. |
#1560 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
I'm I missing something here? The logs you provided don't go into the 4500 -5500 rpm zones??????
SCRATCH THAT. you think google docs would work better on android. |
#1561 |
Member#: 32669
SCIC
Do you have a log with individual EGTs at the time of the AFR fluctuation
#1562 |
Member#: 179846
EGTs looks same as always climbing to about 690c at red line, with no major bumps, the EGT system is not very fast acting anyways, its only good to see a big picture.
#1563 |
Member#: 32669
SCIC
http://www.exhaustgas.com/Deptselect.asp
A little OT but I'm running these guys EGT probes and oil sensor probes and I'm trying out one of there exposed junction EGT probes that they use on top fuel cars. The response time is 250 ms and they say with their probes you can see a single misfire @ 8000 rpm. I'm going to log the exposed junction probe along with the normal EGT probe to see the difference in response times. |
#1564 |
Member#: 179846
i'm thinking it might be the spark plugs, going to drop in old NGK iridiums or Denso IKH22 and if it changes anything.
step 2 cold plugs are rated for 700+ whp, Last edited by Bariga; 09-17-2012 at 06:59 PM. |
#1565 |
Member#: 179846
passed emissions today thanks again Dom!
#1566 |
Member#: 179846
after long time of trouble shooting the AFR spikes thinking its misfires went to store bought new sensor and boom afr in perfect line!
****ing innovate support is trying to blame it on missfires and that if the sensor is not showing error code its good ********... |
#1567 | |
Member#: 134949
VIC
#1568 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
So you've had that innovate for like 4-6 months and it crapped out? Sounds about right.
Innovate tried to blame the car or install for problems with their product....sounds about right. That's why I stopped recommending them. 99% of their "troubleshooting" is blaming the customer and telling them they didn't install it correctly. I really believe innovate has some serious electrical issues with their controllers that causes premature wear. The same Bosch sensors last a million times longer with uegos than innovate. |
#1569 |
Member#: 163108
International
Vehicle:07 EuroDM STi 2.5L Silver |
What kind of Innovate is that? LC-1? I have LM-1, removed it and replaced with LC-1. LC-1 is horrible compared to LM-1. I'm thinking if LC-1 gets damaged easily due to severe heat of the engine bay, unlike LM-1 since LM-1 controller is inside the car, much cooler but eats up a lot of space.
#1570 |
Member#: 179846
its mtx-l, the problem with uegos its very slow!
ill be calling them on monday to get free sensor, will see how thats going to flow |
#1571 |
Member#: 134949
VIC
I had an lc-1 with main unit mounted on my strut bar, sensor mounted at rear o2 location and I went through sensors like nuts. I sold it after the 5th or 6th sensor swap. On an aem now and still on the original sensor. Might give the mtx-l a try though.
#1572 |
Member#: 179846
can sensor get damaged from cleaning it with compressed air?
#1573 | |
Member#: 163108
International
![]() I'll try to put the lc-1 controller inside the car, if it still kill sensor that soon, i'll just remove it and put back my lm-1. |
#1574 |
Member#: 179846
As i have 1 available table left thinking to use it for AFR limit under boost, does it make sense?
#1575 |
Member#: 134949
VIC
That's probably going to cut in and out under shifting
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
| +1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
| My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
