Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 09-21-2012, 09:35 AM   #1
EJ20(GDB)
Member#: 85507
1995 WRX STI
Default Headers fitment
Is it pretty much all the aftermarket headers will fit on jdm engine 2.0l ? As long is turbo ?
EJ20(GDB) is offline   Reply With Quote
Old 09-21-2012, 02:20 PM   #2
AgentJ17
Member#: 306411
1995 STi RA
very eg33 such braap
I believe so, in fact I think any manifold will fit any turbo subaru motor from EJ20G-EJ257. Oil pan clearance is the only issue.
But someone confirm this please.
Actually, I don't think there are any oil pan clearance issues with UEL manifolds, just EL manifolds.
AgentJ17 is offline   Reply With Quote
Old 09-21-2012, 02:44 PM   #3
PSBeachBum
Member#: 279870
2005 WRX Wagon
I have had fram clearance issues with my recent UEL Headers. Other than that 2.0l needs the 2.5l oil pan for equal length headers.
PSBeachBum is offline   Reply With Quote
Old 09-21-2012, 02:50 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
its actually any dual port ej from 1989+
Old 09-23-2012, 10:00 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ This right here. If your car happens to have what's called (everywhere else in the world but the USA) a twin scroll pan (same as USDM STi Pan) then you should be able to use ANY header.
CHECK HERE
Old 09-23-2012, 01:17 PM   #6
AgentJ17
Member#: 306411
1995 STi RA
Hmm, looks like I'll be picking up an 06+ STi or a KillerB pan in the near future for when I get an EL manifold. Any idea if the STi pan or your KillerB pan/tray/pickup combo will work on the EJ20G?
Nice article, btw.
Old 09-23-2012, 01:20 PM   #7
AgentJ17
Member#: 306411
1995 STi RA
CHECK HERE
Looks like I'll picking up either a 06+ STi pan or your pan/tray/pickup combo in the near future before I get an EL manifold. Any idea on either of those for fitment to an EJ20G?
Old 09-23-2012, 02:45 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Oil pans/pickups/baffles are all backward compatible with all EJ engines. Just make sure you always use the baffle that goes with the pan you are using.
