#1 |
Member Sales Rating: (26)
Member#: 102140
South East
Vehicle:your mom |
Car: MY97 Subaru Impreza Outback Sport (5dr)
Color: Brilliant Red/Bronze Mileage: 126,000 Trans: 5 Spd Manual Location: Gainesville, FL Price: $2500 Exterior: 5/10 Interior: 6/10 Engine: 9/10 Supension/Drivetrain: 7.5/10 I have owned this vehicle for over two years now and I have put a lot of maintenance into the engine to make sure it would stay running. I live 1.5 miles from school and I can't afford to have two cars. I have changed the oil every 3,000 miles with Castrol High Mileage and a PureOne filter. The car has had all its fluids changed within the last 3,000 miles. Now has 02-04 WRX wheels with Continental tires. I have maintenance records since I have owned the vehicle. In the past 26,000 miles I have owned it, these items have been replaced: Clutch Timing Belt Water Pump Oil Pump Timing Belt Tensioner Timing Bearings Front Ceramic Brake Pads Front Brake Rotors Front Oxygen Sensor Radiator Thermostat Battery Battery Cables Passenger Front Axle I am probably missing some stuff The Bad: The boot for the steering rack is torn and the rack leaks fluid The power steering pump leaks The drivers side cam seal leaks, 1/8 qt over 3,000 miles The paint is single stage, minor dents and dings, but the prep work was bad. Also there is some bumper scrapes and scratches. (Only reason why exterior was rated so low, no major dents) Drivers seat has cigarette burns, (2 small ones), car does NOT smell like smoke, I do not smoke. No rust underneath, on any major parts, quarters, or bolts. There is a little in the hatch area where it closes from the ocean. ![]() ![]() ![]() ![]() ![]() ![]()
#5 |
Member#: 102140
South East
Vehicle:your mom |
I thought it was bad enough to move two haha. I just can't do it while in school, I know I will never buy a car for this cheap... that has actually been taken care of mechanically.
#14 |
Member#: 102140
South East
Vehicle:your mom |
I also have a 2000 RS Coupe, Dark Gray Metallic, built hybrid swap, I would be willing to trade both these for something newer, 5spd.
