Old 09-23-2012, 08:35 PM   #1601
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Originally Posted by subarutah View Post
file sharing is off so I can't get a direct link but I'm going to be doing a little tuck job myself. I didn't go all out on the shaving though....kinda wishing I would have now. Anywhere here is a few pictures in this link.
http://www.flickr.com/photos/6449139.../in/datetaken/
Paint looks good. I can tell you from my experience that you went the much, much easier/faster route. I have so much time in mine, and it still is not half as good as some of these. It was done 100% by me in my garage. I am sure it could have been done much faster by a pro.
2006whitesti is offline   Reply With Quote
Old 09-23-2012, 08:40 PM   #1602
subarutah
Member#: 248428
2006 STI
FROZEN GREY
Yeah I still want mine to be fully functional so I'm not going all out and crazy with it. I am also having professionals do it, partly because I'm still in Afghanistan and partly because I just don't have the time to have the car torn apart, and partly because I'm a sissy when it comes to jobs of that nature.
thanks for the compliment on the paint, it look way way better in the sun when the blue pearl really shines through
subarutah is offline   Reply With Quote
Old 09-23-2012, 11:19 PM   #1603
brcewane
Member#: 63990
Flat Grey
Originally Posted by Smurftastic View Post
Following removal of cruise control and after a discussion with Richy, exploring ways to clean up the throttle cable... tried gently rerouting it... half-way successful. It works but too much stress is causing throttle issues.
Damn drive by cable... yargh!
Flip your throttle body upside down, and then run the throttle cable underneath the intake manifold on a bracket. That is how I will be running my DBC throttle body on my 2.5 RS reversed intake manifold.
brcewane is offline   Reply With Quote
Old 09-24-2012, 02:49 AM   #1604
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
That only works with drive by wire. On a cable setup the iacv won't let you do that in any reasonable way that I know of.
onesicksoob is offline   Reply With Quote
Old 09-24-2012, 09:30 PM   #1605
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
^actually thats what we did with mine as well, no problems here
StealthWRX is offline   Reply With Quote
Old 09-25-2012, 01:36 AM   #1606
brcewane
Member#: 63990
Flat Grey
Yup, cribbie did the same and others as well
Old 09-25-2012, 04:02 AM   #1607
onesicksoob
Member#: 215841
Dont PM me about
wheel specs
Well then don't mind me, I guess. How does that work though? The passage cor the iacv would be blocked if you flipped the throttle body. Just tightening the throttle cable until it idles decent, or some other simple solution I'm over looking?
Old 09-26-2012, 01:07 PM   #1608
sledge_hammer
Member#: 125784
2004 Wrx
Anyone have any pics of there relocated fuel filter?
sledge_hammer is offline   Reply With Quote
Old 09-27-2012, 12:22 AM   #1609
brcewane
Member#: 63990
Flat Grey
You would basically need to drill holes in the intake manifold for air to flow into the iacv. Possibly even an adapter plate
Old 10-02-2012, 10:49 PM   #1610
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Damn. That's a good idea. I'm concerned about the throttle cable though... one thing I definitely learned during this process is if curves are too sharp, it's really not happy! Any pics of the bracket setup? I will seriously look into this.
One option is a smaller in-line fuel filter. Currently looking into this myself.. plenty of options at Summit.
In other updates, spent about four hours last night installing a Jegs battery relocation kit, distribution block, and in-line fuse with built in kill switch. Hell of a lot of work to do it right, but it's definitely worth it. Now to clean up all those extra wires..
Smurftastic is offline   Reply With Quote
Old 10-05-2012, 04:54 PM   #1611
john_411690
Member#: 162866
2004 STI APRwidebody
custom Green & carbon
here is stage one of my 04 STi shave I'll be doing some more work this winter http://www.facebook.com/photo.php?fb...type=3&theater
john_411690 is offline   Reply With Quote
Old 10-05-2012, 10:47 PM   #1612
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Originally Posted by dudley123 View Post
Hmmm.. I'll play
No one has seen this shot yet, except for D..
What raintray? Milspec connection into tranny tunnel, Tilton pedal setup, Shaved everything! Not sure many people can tuck "315's" like I can
YEP No one can touch that bay bro. Sad to see you part it out, but i'm sure you will be a lot happier in the GTR. Hopefully you'll drive this one and enjoy the car the way it was meant to be, beating the piss out of it every week lol
Old 10-07-2012, 12:14 AM   #1613
Smurftastic
Member#: 243697
02 | BLOD Founding
Over the last week, relocated battery (Jegs kit with inline 200amp circuit breaker, kill switch, and distribution block) and fuse box into quarterpanel... shaved down the engine bay but no paint yet. Looking pretty damn raw. Still have a few wires to extend and reroute, but def getting there.
Old 10-07-2012, 11:09 AM   #1614
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Post some pictures!
CobbWRX is offline   Reply With Quote
Old 10-07-2012, 11:26 AM   #1615
Smurftastic
Member#: 243697
02 | BLOD Founding
Originally Posted by CobbWRX
Post some pictures!
Maybe a teaser shot of the trunk setup but the engine bay is still too raw :-)
Old 10-07-2012, 11:26 AM   #1616
Dpwhitehead1
Member#: 139996
2016 Silverado 1500
Deep Ocean Blue
how much did that kit cost you?
Dpwhitehead1 is offline   Reply With Quote
Old 10-07-2012, 12:22 PM   #1617
Smurftastic
Member#: 243697
02 | BLOD Founding
The Jegs kit was about $100, the circuit breaker and distribution block were about $15ish each. Ended up buying some extra 4 gauge wire for the starter for $7.
I wanted a box large enough to fit the Optima Redtop, which is a pretty sizeable battery... tons of room, but also a setup that would be SCCA legal, hence the rest of the setup.
Old 10-12-2012, 11:03 PM   #1618
Smurftastic
Member#: 243697
02 | BLOD Founding
Reading more into engine harness modifications -- for wire-to-wire crimping/soldering, any input on solder & seal heath shrink terminals?
Old 10-14-2012, 05:58 PM   #1619
Smurftastic
Member#: 243697
02 | BLOD Founding
Made some good progress today on the wiring harness, but definitely a long ways to go. For now, finally sharing some pics of the trunk setup:
Old 10-14-2012, 10:49 PM   #1620
richy_21
Member#: 58670
2005 got muuuuu?
Looking good bud
richy_21 is offline   Reply With Quote
Old 10-15-2012, 01:48 AM   #1621
traction issuez
Member#: 86559
2005 RS Wagon
Does anyone have the diagram or schematics of the brake system? I may attempt to venture into deleting the ABS system; I am unsure where and what lines goes where.
traction issuez is offline   Reply With Quote
Old 10-15-2012, 03:48 AM   #1622
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Just being honest here, if you are not mechanically inclined enough to figure out the brake system line routing then you donít need to be touching it all.
Token-Negro is offline   Reply With Quote
Old 10-15-2012, 08:44 PM   #1623
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I can email you my fitting list and pics of my setup however token-negro is correct about what he said above. Hes just comes off a little negative, nothing new.
D Money is offline   Reply With Quote
Old 10-16-2012, 12:14 AM   #1624
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Negative? Nahh just stating the facts as always.
Old 10-16-2012, 08:31 AM   #1625
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Mmmhmmm.
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 04:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 09:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 02:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-16-2004 12:58 AM
