Old 09-11-2012, 08:21 AM   #26
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
How are you resetting the ECU? Through RR or pulling the battery terminal? Also, you need FLKC, FBKC, and IAM in your logs.
I would really like you to pull a learning view image for us.
If it ran better before, why don't you get a new 2 port solenoid and flash the old map back?
Old 09-11-2012, 09:24 AM   #27
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I am re-setting the ECU through RomRaider. I'll do a battery reset tonight. I'll also install Learning View and get a screenshot of that for you.
I think that when I put the new 3 Port EBCS on, it just amplified the issues I am having with the car. I'm hoping that if I can get this all sorted out it will work better.
criscross79 is offline   Reply With Quote
Old 09-13-2012, 07:37 PM   #28
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Any news on this?
Old 09-13-2012, 10:10 PM   #29
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I actually just got back from pulling some logs. I also got some screenshots of Learning View.
Run 1 (Forgot to add FLKC)
https://docs.google.com/spreadsheet/...lplTE9COWNyc3c
Run 2 (Added FLKC)
https://docs.google.com/spreadsheet/...DFUT2hRWTVEVmc
Learning View Screenshots
https://docs.google.com/document/d/1...WV-2ODllY/edit
Old 09-13-2012, 10:52 PM   #30
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Look at A/F Learning range "c" on learning view, its almost maxed out, as well as "a" at nearly 6%, that is concerning. The FLKC its showing isn't bad.
I still say there's an underlying MAF/leak problem here.
Old 09-14-2012, 05:00 PM   #31
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I'm trying to get see if I can barrow a MAF sensor locally before I spend money on it. In the meantime, I'm going to triple check my for a boost leak.
I also had a question about the CEL that shows up in Learning View. It is P0457 EVAP LEAK DETECTED (Fuel Cap). Would that error give me these problems? .. I'm pretty certain the fuel cap isn't loose, but maybe whatever is causing it is why the car is running lean?
Old 09-16-2012, 07:39 PM   #32
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Ehh, I suppose it could case some issues depending on where the leak is.
Old 09-19-2012, 02:46 PM   #33
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Weird coinceidence. My car just came up with this code today and has started some random knocking as well...
Old 09-20-2012, 10:40 AM   #34
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Any idea what it is?
I don't know if it's related, but I do get a very strong smell of gasoline whenever I get gas. the smell is in the cabin and starts even before I turn the car on and last 10-20 minutes after driving. I guess the car is just getting old lol
Old 09-22-2012, 08:23 PM   #35
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Yeah, I second this I guess this is what happens with old, used subies. At least my CEL hasn't come back on.
Old 09-24-2012, 02:52 PM   #36
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I'm pretty sure I fixed mine. My coolant overflow bottle had came loose. I'm guessing that was tricking the kock sensor, since after I re-secured it I havent been able to get it to knock.
Old 09-24-2012, 03:00 PM   #37
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Does your overflow resemble a connecting rod?
Dr. octagon is offline   Reply With Quote
Old 09-24-2012, 03:02 PM   #38
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Check and make sure the fuel pump gasket is flush if you were/did any work involving the fuel pump. Also ensure that you do not have a fuel leak from your fuel lines.
Old 09-24-2012, 09:11 PM   #39
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Uhhh, what??
Old 10-06-2012, 01:56 PM   #40
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Just an update: ... So, I cleaned out my air filter, cleaned the maf and zip tied a bunch of stuff and walah! the car is 95 percent better. It's still pulling a tiny bit of timing, but it's nowhere near as bad now and the car is running much better.
I am still getting that P0457 EVAP LEAK DETECTED CEL and I have figured that out too .. it is a broken Fuel Vapor Solonoid! one of the plastic nipples broke off. So, now I have to figure out where to get one, or fix the one I have. :-/
Old 02-07-2013, 08:05 PM   #41
Strider327
Member#: 131280
2004 Impreza WRX
So your pulled timing was due to a bunch of stuff all shaking all at the same time causing a false knock which caused your ecu to pull timing? May I ask what was shaking so bad to cause this?
Strider327 is offline   Reply With Quote
