Old 08-05-2009, 05:33 PM   #1
kilowhisky
Member#: 134144
Default Failsafe resistor for BCS.
What is the resistor needed for the failsafe in a aquamist/aem water/meh injection kit? From what i read if you tap into the ecu -> BCS line that it will throw a code when the failsafe engages. People say to use a resistor to stop this from happening but i can't find what resistor i need to use. Does anyone know off hand?
I'm still looking through threads but i wanted to post this quick because i need the answer in the next few hours.
kilowhisky is offline   Reply With Quote
Old 08-05-2009, 05:35 PM   #2
richy_21
Member#: 58670
2005 got muuuuu?
hmmmm also curious.
richy_21 is offline   Reply With Quote
Old 08-05-2009, 05:38 PM   #3
kilowhisky
Member#: 134144
This it?
39R resistor/ 3W 39R resistor
Maybe i should leave it out and just use the CEL as an extra warning light.
EDIT: Ah ha! Found this quote by Aquamist.
Originally Posted by Aquamist View Post
yes, the 39ohm resistor is needed. It should come with the DDS3 gauge. Once we have the DDS3 working as intended, We can then look into the CEL more closely.
Old 08-05-2009, 06:48 PM   #4
elky82
Member#: 215056
39 ohm 25 watt resistor is what you need
elky82 is offline   Reply With Quote
Old 08-05-2009, 06:50 PM   #5
elky82
Member#: 215056
and dont waste your time at radioshack, they dont have it -- you have to go to an electronics supply place
Old 08-05-2009, 07:30 PM   #6
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
The DDS3 should have one soldered on board already.
Aquamist is offline   Reply With Quote
Old 09-22-2012, 10:13 AM   #7
jsudler
Member#: 78189
2005 Legacy GT Wagon
Bumping this for some guidance on how to wire the resistor to prevent a CEL.
jsudler is offline   Reply With Quote
Old 09-24-2012, 02:50 AM   #8
Aquamist
NASIOC Manufacturer
Member#: 110029
what system do you have?
Old 09-24-2012, 05:37 PM   #9
jsudler
Member#: 78189
Thanks for the reply, I have a labonte kit. the failsafe is wired to trigger a NC relay and switch my prodrive EBCS to wastegate pressure.
Old 09-24-2012, 06:19 PM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
After cutting the pulsed wire of the EBCV from the ECU
1. ECU side to the relay "com"
2. EBCV to the relay "NC"
3. 39ohm (10W* to 25W) to the relay "NO" (the other side of the 39ohm to 12V** (switched).
* 10W for short cut-off duration (less than 1 minute).
** you can use the non-pulsed side of the EBCV. (it is normally a switched 12V)
Anyone have 3.3 ohm resistor for jdm seat swap Stang2WRX Tri-State Area Forum 12 07-09-2009 09:36 PM
3.3 ohm resistors for airbag light JayB Private 'For Sale' Classifieds 28 01-20-2004 10:22 PM
WTB - o2 sensor resistor for catless people S-WRX Private 'Wanted' Classifieds 4 07-28-2003 04:55 AM
A ? regarding the resistor for Airbag ?Seat change Weasel 555 Tri-State Area Forum 6 11-06-2002 05:01 PM
Correct resistor for TXS TPS mod? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-25-2002 10:19 PM
