Old 09-24-2012, 10:14 PM   #14126
jasonz34
Member#: 312498
Originally Posted by Blackmamba24kb View Post
danstheman7, ans2k, CLL_OBP Thank you guys!! very nice of you guys to provide links to the bulbs you guys got!! much much thanks!!
i love this thread!! thanks again for the info! now to buy the bulbs.
anyone have a hard time getting the cover off the cargo area of the 5 door wagon? i couldnt get the cover off the cargo light. is it the same bulb as the dome and map lights?
Same type of bulb. I want to say it was the same size as the map lights. Use a small flathead screwdriver like the manual shows. It's easy.
I managed to get 30 LED bulb in mine, with modification. The thing is almost blinding, but it certainly helps with the night time visibility.
jasonz34 is offline   Reply With Quote
Old 09-24-2012, 10:33 PM   #14127
Penguin44
Member#: 315883
2012 IMPREZA
Originally Posted by FlyerHazen
Describe how your car feels.
I'll give it a try. I mean it still seems normal but, a little higher revs it seems but I can't remember what they were before. Would the dealer have to disclose they did this? I got the car back exactly as it was. Radio settings and trip were unaffected so no battery was disconnected. She just seems different.
Penguin44 is offline   Reply With Quote
Old 09-25-2012, 12:48 AM   #14128
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Originally Posted by jasonz34 View Post
I found SuperBrightLEDs to be a good source. I ordered replacement bulbs for the map, dome, and hatch. Also changed the accent "eyebrow" bulbs on the front headlights.
Do you have any idea how to replace the sidemarker light/"eyebrow" lights on the front headlights?
I can't seem to find any other way to change that bulb aside from removing the entire headlight (unscrew it, and replace the bulb the hard way).
danstheman7 is offline   Reply With Quote
Old 09-25-2012, 12:51 AM   #14129
danstheman7
Member#: 331089
2012 Impreza Base
Dealer doesn't have to disclose it, but it should be on the piece of paper that Subaru gave you after you picked up the car (the 'invoice statement', noting everything they did during the appointment)
If not, they might not have done it, or it was covered under the 27-point inspection if that was done.
All you need to do is bring it in and have them connect their computer to it, and they can tell you whether it's up to date or not. Call ahead though
Old 09-25-2012, 01:47 AM   #14130
Penguin44
Member#: 315883
2012 IMPREZA
Ok thanks. Yeah not on the invoice. I'll call and ask. Thanks for being patient with a loon like me!
Old 09-25-2012, 02:16 AM   #14131
imcausinmadrukis
Member#: 318978
Originally Posted by Unknown77 View Post
I might be interested in buying that custom drop down. Where are you located?
NorCal - Oakland, CA
imcausinmadrukis is offline   Reply With Quote
Old 09-25-2012, 04:55 AM   #14132
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I've more or less replaced all halogen bulbs with LEDs and HIDs in my car. eBay seems to be a good place to buy the bulbs.
http://www.ebay.ca/itm/280680234431?...84.m1439.l2648
Backup lights
http://www.ebay.ca/itm/261091239024?...84.m1439.l2649
Turn signals
http://www.ebay.ca/itm/170868314745?...84.m1439.l2649
Map lights
http://www.ebay.ca/itm/120970661537?...84.m1439.l2649
Dome lights
http://www.ebay.ca/itm/170887127018?...84.m1439.l2648
License plate lights
http://www.ebay.ca/itm/280911408823?...84.m1439.l2648
Hatch lights, side accents on headlights, and taillights
That should be most of them.
Old 09-25-2012, 09:19 PM   #14133
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Anyone with the iPhone 5 having Bluetooth pairing issues?
http://forums.nasioc.com/forums/show....php?t=2412482
SleepNMnky is offline   Reply With Quote
Old 09-25-2012, 11:59 PM   #14134
ennpe
Member#: 333283
2012 Impreza Premium
Dark Gray Metallic
try using the voice setup to pair the bluetooth. someone else on the forum had this problem, and it also worked with my android. when i used the head unit to pair it, it wouldn't auto connect either.
ennpe is offline   Reply With Quote
Old 09-26-2012, 12:09 AM   #14135
SleepNMnky
Member#: 302491
through the steering wheel voice commands? is that what you're referring to? thanks for the suggestion, i'll try it tomorrow.
Old 09-26-2012, 04:42 AM   #14136
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes. The command is "setup" but you might have to try "help" i did on my car anyway
Old 09-26-2012, 11:37 PM   #14137
SleepNMnky
Member#: 302491
Voice commands seem to have done the trick. Thanks all!
Old 09-27-2012, 03:09 AM   #14138
pkL
Member#: 313093
2012 Impreza 2.0i
While we are on the topic of bluetooth, is there a way to get the head unit to display caller names as opposed to the phone number? This is the HU I have.
Old 09-27-2012, 06:04 AM   #14139
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
PKL, on the LED swap did you require a resistor for the turn signal bulbs? Otherwise all other LED bulbs worked fine?
uspopo is offline   Reply With Quote
Old 09-27-2012, 09:49 AM   #14140
SleepNMnky
Member#: 302491
There is a way. You have to program the contacts on the head unit. It doesn't just pull the info from your phone or sync like the other models do.
Old 09-27-2012, 10:05 AM   #14141
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Does anyone else find themself yelling while using hands free? After a conversation im out of breath from how much effort is involved yelling for an entire conversation. lol if i dont speak up loud enough the people on the line say they cant hear me.
is it a crappy mic? or is it just common for hands free in general?
Old 09-27-2012, 10:32 AM   #14142
uspopo
Member#: 317014
ISM
No experience with the BT mic on the car but I find myself yelling and giving the handful Bird to people that cut me off (from behind the tint...lol). Those stock horns are horrible.
Old 09-27-2012, 11:48 AM   #14143
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Not me, you can adjust the volume on the headunit, maybe it increases mic sensitivity?
Ladeef is online now   Reply With Quote
Old 09-27-2012, 01:56 PM   #14144
imcausinmadrukis
Member#: 318978
Out of curiousity I copared the 12 to the 13 Impreza.
These facts arent correct are they?
The 13's have better gas millage?
Whats the deal with the 265hp? WRX/STI?
Comparison by jmaiden91184, on Flickr
Old 09-27-2012, 02:15 PM   #14145
uspopo
Member#: 317014
ISM
Now which website is that from because if it isn't Subaru.com I don't trust the numbers plus they got the WRX mixed in...
Old 09-27-2012, 02:31 PM   #14146
Zeeper
Member#: 299286
2015 WRX CVT
Nah,
My 2012 Sport has 265hp, but I only get 33 mpg highway...
Old 09-27-2012, 03:40 PM   #14147
imcausinmadrukis
Member#: 318978
Cars.com
Old 09-27-2012, 03:52 PM   #14148
Angelus911
Member#: 89967
2012 Impreza Sport
19/25 seems to be the WRX fuel economy numbers. Fuel economy isnt any different between '12/'13 Impreza models (save the XV)
Old 09-27-2012, 04:19 PM   #14149
kenny doggins
Member#: 326540
2012 Impreza MT SP
Default WRX wheels
For the folks putting 16" WRX wheels on their 2012+ Imprezas, how do you figure the 1/2" narrower wheels? Most of the WRX oem feet are 16"x6.5" while the sport alloys are 17x7" wide.
It'd be nice to have more tire in the winter and for crappy fire roads, but giving up a combined 2" of contact on the road seems like a deal breaker.
kenny doggins is offline   Reply With Quote
Old 09-27-2012, 04:23 PM   #14150
ans2k
Member#: 315631
2012 Impreza Sport
first off, it is actually better to have narrower tires for snow driving. second, even though our wheel are 7 inches wide, the oem tires are 205 wide. usually a 7 inch wheel uses a 215mm size tire. just saying.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
