Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 09-25-2012, 12:47 AM   #1
Member#: 99400
2005 sti
Default overwrite cobb v1 map
my brother had his car broken into and they took his accessport which was in the glove box It was a cobb v1. Can the car be flashed via open source?? or will i have to either find a used/new ecu??
thanks in advance!
y2ldude is offline   Reply With Quote
Old 09-25-2012, 12:50 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
If it was a v2 AP you could do the following:
Find a neighbor with an AP. Temporarily divorce it from their ECU, marry it to your brother's, divorce it (flashing back an OEM map in the process), and then marry it back to the owner's ECU. That will wipe the locked AP map from your brother's ECU and allow it to be flashed via Open Source.
I'm not sure how things change with a v1 AP though.
Old 09-25-2012, 08:25 AM   #3
Member#: 70395
Yes it can be reflashed with Opensource. The V1 did not lock the ECU like the V2. You can even pull the Cobb map off the ECU and manipulated it and reflash it.
quazimoto is online now   Reply With Quote
