#676 | |
Member#: 201277
MAIC
Vehicle:2008 Legacy OBP |
Are you going forward with a design that only bolts to your CBE or mid-pipe ? If so ![]()
#677 | |
Member#: 231489
MAIC
hahahaha. Noted! We just want to produce the right part for the community, and one that works! We take pride in r&d, so it's sometimes tough for us to sign off on projects like this
![]() No, simply because the current design is *very* easy to make equal length. it will mean a change in the CNC bending data, but that's no biggie. The problem is that batches of tubing bends will have to be different for each header, thereby making it a little harder for us to pass the savings onto the customer. Quote:
#678 |
Member#: 216984
NWIC
Vehicle:1996 Impreza outback Green |
I think that the collector design going straight back is a better design compared to the sideways collector and flange that bolts to the stock location cat section. The reason is the less bends the better for exhaust gases which leads to faster velocity given the right diameter piping is used for the application.
However, like some people on here have pointed out, if this header is used with the straight back collector then the cat section either has to be made up or get the header and cat section together from Moore Performance. On the other hand, getting the whole combo would still be nice because these two pieces of the exhaust will be worth it because of the craftsmanship that goes into each header and cat section. If I remember reading right, any catback will be able to bolt up like a 2.25 or 2.5" and then a 3" if so desired with an adapter. If I build the engine I am thinking then I would definitely like to buy one of these headers and most likely the cat section as well. It won't be for higher end power just low and mid so it would be perfect ![]() |
#679 | |
Member#: 231489
MAIC
What if we were able to drop the price of the header/midpipe/cat combo to something close to the better headers on the market? Yes, the header won't just "bolt up" to a stock cat section, but as mentioned, the flow will be vastly improved. other pluses: - no heat shield rattles from the mid pipe section - no wafer thin/rusty donut gasket flanges. - high-flow vs. low-flow cat - stock cat section can be sold for its platinum to recoup some $ ![]() |
#680 |
Member#: 318411
South East
so how much are these gonna go for?
#681 |
Member#: 317014
Tri-State
Vehicle:2012 Impreza Sp Ltd. Dark Grey Metallic |
I know you are currently working out the final design and pricing for the 2.5 motor and I hope eventually the design will lead to a FB20 variant. As long as it doesn't trip CEL codes and is quality I don't mind paying a little more...
#682 |
Member#: 231489
MAIC
We havent decided on a price, but we're leaning toward doing the header and the mid-pipe as a package that will be competitive with buying say, a Borla and an aftermarket mid-pipe with high-flow cat. We're leaning toward offering it as a package only, as both will work with one another.
I'm sure we will. We're doing a one-off exhaust on an FB this week, so we'll have some solid inspiration! |
#683 |
Member#: 317014
Tri-State
Sweet..ftw!
#684 | |
Member#: 201277
MAIC
#685 | |
Member#: 231489
MAIC
Making it bolt to a stock axle back makes sense for those wanting to keep things a bit more stealthy - it's just really hard justifying making the header bolt up to a factory mid-pipe due to its quirky design. |
#686 | |
Member#: 201277
MAIC
Oh yeah that near 90 degree connection is perpendicular to the path of exhaust flow, not so good for efficiency. Well we all look forward to your design rollout. |
#687 |
Member#: 231489
MAIC
#688 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
#689 |
Member#: 231489
MAIC
There's a pretty good header on there to begin with. I'm not ruling it out, but it's not first on the list. We are however doing a group buy on FB exhausts for Imprezas here in a few short weeks.
#690 |
Member#: 251482
VIC
Vehicle:2000 2.5RS silver 2011 Lexus, 1990 all-trac |
installed brullen headers with their hi-flow cat
much much better performance compared to what was before they claim 21hp increase and probably that's what it is |
#691 | |
Member#: 231489
MAIC
21 HP sounds like a lot though. Are there any dyno plots? |
#692 |
Member#: 336270
MWSOC
Vehicle:2005 Impreza Black |
Bump for this -
If I have to I'll drive straight to your shop. As of right now I have the stupid p0420 code and rear flange on my cat is slowing rusting away (awesome exhaust leak). Very interested in 304 header and cat section that gets rid of that stupid donut gasket. Any option for a wideband o2 bung? I have a AEM UEGO laying around from an old project that never got used I'd like to put to use. Only 2hrs away from your shop and 40 from the fab place. |
#693 | |
Member#: 231489
MAIC
Give us a ring to discuss some options! Moore Performance (412) 951-6493 |
#694 | |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
#695 | |
Member#: 336270
MWSOC
Will do in the next week or so. Quaker City...I haven't been there in years... Last edited by BlobEyeRS; 10-27-2012 at 04:45 PM. |
#696 |
Member#: 6119
BAIC
Vehicle:1999 GM6 RBP |
I'm swapping, so I'm no longer a potential customer, however here is something to compare to (OBX EL):
![]() My 1999 (MAF) RS had intake, catback and was catless. This is fairly low reading mustangs dyno (GST Motorsports). If your header can produce power like that, it's definitely going to be a good header. But do note that the OBX header can be had for about $300 shipped. So if your design is truly superior, I think it would have to produce the best dyno results of any NA header out there. Can't wait to see the finished project! Last edited by joltdudeuc; 11-02-2012 at 08:04 PM. |
#697 | ||
Member#: 231489
MAIC
Oh man. I guess that should have been worded a bit more delicately. hahahaha
#698 |
Member#: 42912
MAIC
Vehicle:2003 Outback Sport bird **** & door dings |
any updates?
#699 |
Member#: 231489
MAIC
| Thread Tools | |
| Display Modes | |
| Moore Performance Axleback for 93-05 impreza.....feedback wanted! | Moore Performance | Normally Aspirated Powertrain | 181 | 03-21-2011 10:11 AM |
| Moore Performance 08+ wrx/sti divorced wastegate DP ready for production! | Moore Performance | Factory 2.5L Turbo Powertrain | 3 | 02-25-2010 09:57 PM |
| Moore Performance 08+ sti downpipe/catback.....what do you want?? | Moore Performance | Factory 2.5L Turbo Powertrain | 2 | 12-26-2009 06:30 PM |
| Moore Performance Divorced Wastegate Downpipe and Catback Exhaust Group Buy!! | Spun Autosports | Vendor 'Group Buy' Classifieds | 27 | 12-03-2009 07:48 PM |
