Old 09-26-2012, 01:10 AM   #1
v_khotsky
Member#: 303995
2012 Impreza STI
2006 Yamaha YZF-R1
Default 2012 STI Pro Tune
Last week I installed TBE and took my car to local dyno shop , to get it tuned
(not realy trusting "of the shelf maps"
Just want to know your opinion about the numbers.
Mods I got:
Injet CAI
Invidia Q300 catted TurboBack
COBB with a Stage2 map.
The first pull "baseline" (4th gear) showed a
249whp / 344lb
After few more pulls and some mapping magic, we got
307whp / 347lb
Correction was STD , Smoothing was 5
Dyno : Dynojet
Car feels totaly new now, nice and smooth, also guys reprogram "throttle input table" for I mode , so now it feels more like S before tune.
Well... my question is : those gains is sufficient enough for the stuff i got?
I been looking around the WEB , and got confused, some people posting 350whp just with ctock+protune.
v_khotsky is offline   Reply With Quote
Old 09-26-2012, 03:10 AM   #2
10splaya22
Member#: 283020
2016 Subaru
WRX Limited
Numbers seem pretty typical for stage 2. 350 would definitely be too high for a basic stage 2 setup
10splaya22 is online now   Reply With Quote
Old 09-26-2012, 08:42 AM   #3
masterforce
Member#: 221580
2011 WRX STI
Nice! I got mine protuned at Cobb in Plano, TX and and was able to get 312 AWHP and 352 lb-ft TQ. Mods are Cobb SF intake + box, Invidia catless DP and Q300 exhaust.
masterforce is offline   Reply With Quote
Old 09-26-2012, 08:56 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
Those numbers seem about right to me. With WRXs and STIs, whatever the crank HP is, you can normally get just above that in WHP.
Old 09-26-2012, 09:40 AM   #5
Source,LLC
Member#: 322524
3.5 WRX STI
249whp / 344lb
307whp / 347lb
First I'm guessing you mean 244ft/lbs of torque in your baseline pull. So you gain roughly 58whp and 100wtq from the addition of a downpipe, after market intake, and a tune. That sounds about right, if not a little on the high side. Be less concerned with the actual numbers because every dyno will read different and even the same dyno will read differently day to day depending on a variety of external conditions. You picked up respectable gains from a few very basic modifications that's all that matters. Enjoy it
Source,LLC is offline   Reply With Quote
Old 09-28-2012, 02:10 AM   #6
v_khotsky
Member#: 303995
2012 Impreza STI
2006 Yamaha YZF-R1
I'm enjoying it not sure yes , but it seems like a fuel consumption got better too.
I know those numbers means nothing without baseline. I just was wondering if those gains is sufficien enough. Bcause the guy in dyno shop (know him for a while) he rather make car safe than "top of power".
As well i was a litle surprized how unsuficient COBB maps are, if car pulled 248whp with stage 2 map ,
Lets say dyno is mistaken by 10hp so car makes 260whp with stage 2 map. And this map gives 20hp gain (i hope at least 20hp ) , so stock car will show 240whp , WHAT ??! 305hp on crank and it lost 65hp in powertrain ?!
Well .... Whatever car is fast.
Old 09-28-2012, 02:15 AM   #7
v_khotsky
Member#: 303995
2012 Impreza STI
2006 Yamaha YZF-R1
Maybe some of you guys may give me advice with one more thing -
If i will replace a headers (un equal off course) with up pipe plus new fuel pump and injectors and tune it again - make sence ? Powerwise.? Or just a waste of money without bigger turbo ?
Wanna know for next project .....
Old 09-28-2012, 10:06 AM   #8
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
http://forums.nasioc.com/forums/showthread.php?t=601219
from
http://forums.nasioc.com/forums/showthread.php?t=533787
Old 09-28-2012, 10:59 AM   #9
masterforce
Member#: 221580
2011 WRX STI
AWD system are around 20-25% drivetrain loss. this number can change due to mods done.
Cobbs maps are a "one size fits all" deal. It is better to get a fitted cap than a one size fits all cap. Same thing for cars.
Old 09-28-2012, 06:38 PM   #10
k mier
Member#: 98000
05 sti [email protected]
IMO,YMMV, etc.
Dyno numbers seem just a bit optimistic. Does the tune seem safe?
...at this level, headers will cost more than they are worth.
What was your injector duty cycle? Unless this was high new fuel pump and injectors will net you 0. They will, however, be needed for later upgrades so should be considered worth while upgrades.
k mier is offline   Reply With Quote
Old 09-28-2012, 10:31 PM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Aftermarket up's don't really add power, just mostly make your spool quicker. (And VERY marginally at that since you are catless)
An aftermarket header will not really touch anything on the fueling side to require injectors or a pump.
So yes, waste of money IMO.
Old 10-06-2012, 11:37 PM   #12
v_khotsky
Member#: 303995
2012 Impreza STI
2006 Yamaha YZF-R1
Seems like ill stay with this hp for now unless i win a lotto
