Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-26-2012, 10:35 PM   #1
n00bar00WrX
Member#: 293495
2004 WRX
Default How do my logs look guys? Minor adjustments to XPT stage 2
Hey guys I had some problems with my recent flash to XPT stage 2 but I lowered the target boost tables and lengthened the wastegate arm by quite a bit. I think it's running much better now from what little I've come to understand in my learnings so far. I was just hoping some of you more experienced guys can take a look at a couple logs I ran today. I appreciate any feedback, this looking good?
Both third gear, had to let up at the end on both runs...caught up to traffic...
https://docs.google.com/spreadsheet/...KX2lEekE#gid=0
https://docs.google.com/spreadsheet/...GZWwtRUE#gid=0
n00bar00WrX is offline   Reply With Quote
Old 09-26-2012, 10:41 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Wrong forum, post this in the Engine Management forum.
Old 09-26-2012, 10:48 PM   #3
n00bar00WrX
Member#: 293495
2004 WRX
Sounds good
Old 09-27-2012, 11:26 AM   #4
n00bar00WrX
Member#: 293495
2004 WRX
Anyone?
Old 09-27-2012, 11:31 AM   #5
paul_p1
Member#: 77372
2005 Spec C
WR Blue
What's the car, specs etc. Boost comes in really late.
paul_p1 is offline   Reply With Quote
Old 09-27-2012, 11:33 AM   #6
n00bar00WrX
Member#: 293495
2004 WRX
godspeed downpipe , gimmick motorsports catback, grimmspeed ebcs, cobb uppipe, k&n drop in air filter, 2004 wrx w/ stock turbo
Old 09-27-2012, 11:34 AM   #7
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Wgdc is way too low at spool up, no wonder it isn't boosting quickly.
Old 09-27-2012, 11:42 AM   #8
n00bar00WrX
Member#: 293495
2004 WRX
What should I do to correct? Change the max wastegate duty cycle tables?
Old 09-27-2012, 12:08 PM   #9
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Yes, with that setup you should make 16 psi before 3krpm. I don't know if the us cars are different, but I never touched my actuator to get that on the wrx's I've tuned.
Old 09-27-2012, 12:10 PM   #10
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Can you post a pic of the wgdc tables?
Old 09-27-2012, 01:01 PM   #11
n00bar00WrX
Member#: 293495
2004 WRX
Old 09-27-2012, 10:34 PM   #12
n00bar00WrX
Member#: 293495
2004 WRX
Anyone?
Old 09-27-2012, 11:05 PM   #13
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Why did you lengthen the WG arm you should be tightening it. Could explain the poor spoolup if the WG is loose
Old 09-27-2012, 11:43 PM   #14
n00bar00WrX
Member#: 293495
2004 WRX
Well the short answer to that would be I don't know what I'm doing and I'm a n00b. I will shorten the wastegate tomorrow and log again and see what the results are. My big thing was getting rid of the knock. I don't want to make things worse before I make them better.
Old 09-28-2012, 01:31 AM   #15
Speedy Claxton
Member#: 256284
07 stage 2 STi
ewg & Phatron tuned
There was no new knock events, only the learned knock. That means that the ecu pulled timing and fixed it on its own. Your iam is 16 so it seems like its happy. Pull a learning view and post it up. It shows the overall health of your engine better.
Speedy Claxton is offline   Reply With Quote
Old 09-28-2012, 05:37 AM   #16
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Just return the wastegate arm to what it was, post all of your wastegate tables and boost target tables.
