Old 09-26-2012, 10:15 AM   #26
conklin_02
Member#: 324190
2005 wrx STi
Try cleaning your maf. Reset your Ecu. If its not misfiring, run about a tank of gas through and watch your afr ratios. A, b, c, d should all be +/- 5%. If any are over, than it probably is the maf. Could just be dirty or bad.
conklin_02 is offline   Reply With Quote
Old 09-27-2012, 05:33 PM   #27
oOIIJoshIIOo
Member#: 295983
Cleaned MAF, reset ECU and checked it with my Snap-On Solus Ultra and no code. I'm thinking a coil.
oOIIJoshIIOo is offline   Reply With Quote
Old 09-27-2012, 05:55 PM   #28
conklin_02
Member#: 324190
2005 wrx STi
Is it hesitating under heavy loads or sputtering are higher rpms?
Old 09-27-2012, 06:10 PM   #29
oOIIJoshIIOo
Member#: 295983
Sure is.
Old 09-27-2012, 06:12 PM   #30
oOIIJoshIIOo
Member#: 295983
Starts at around 4-4500 RPMS and continues from there. Only does it usually at WOT.
Old 09-28-2012, 09:24 AM   #31
JMSok8
Member#: 309967
2003 WRX PSM vf34
Another possibility is to find someone local here on the forums to swap out some parts to try and locate the problem. Other than that, with no data logs, videos, or other detail its very hard to determine what your problem is. At this point, you could swap parts with another member, take it to a mechanic, or just not drive WOT.
JMSok8 is offline   Reply With Quote
Old 09-28-2012, 10:17 AM   #32
conklin_02
Member#: 324190
2005 wrx STi
Probably a bad coil pack is my guess. I recently had a similar problem. At WOT it was hesitating over 5k. I replaced my maf and fuel filter, my afr readings went back to normal, but still hesitating. Bought 4 new coils, it fixed it. Also, check your connections. Maybe a bad wire. I replaced mine because they have never been replaced
