#626 | |
Member#: 107000
Vehicle:2008 STI <3 TXS and 2011 F150 Andrewtech |
#627 |
Member#: 88501
BAIC
Vehicle:2006 WRX Wagon CGM |
Tangent question... how does injecting air into the exhaust stream ignite the unburnt fuel? Isn't the air from the air pump cooler than just burned cylinder air? (there's no ignition)
#628 |
Member#: 206912
International
Vehicle:2006 Forester XT DGM |
Good question, the cat is getting unburned hydrocarbons and some oxygen (not much in a well tuned engine) but it's stone cold, so it all passes thru without reacting, giving a relatively large 'spike' of pollution during a cold start, until it gets up to its running temp.
To minimize this spike, the ECU adds extra fuel, well beyond a rich mix and also injects outside air thru the secondary system (BMW has electric coils in their cats in some models for better pre-heat.) Using a cat means the car can never run lean, so it always uses more gas than a better designed 'lean burn' system. This system adds more gasoline to reduce 'pollution'! |
#629 | |
Member#: 88501
BAIC
#630 |
Member#: 206912
International
Sorry, assumed you knew how the catalyst works - it only catalyses CO to CO2 above 450*F, but will self-heat when fuel and oxygen are present, so instead of waiting until exhaust gas heats the media to temperature, they add some gas+air to the reaction and 'light it off' much quicker.
Then they keep the mix over-rich to keep the reaction going. http://community.discovery.com/eve/f...8/m/4911967329 |
#631 | |
Member#: 88501
BAIC
I only have two quarters of Chem in my background. ![]() |
#632 |
Member#: 326231
Vehicle:04 Sti Silver |
kasldk
#633 |
Member#: 333179
Vehicle:2006 WRX Grey |
The last time i checked the codes on my car, the valves were stuck open. Now, it is stuck closed so I pulled the fuses for it because thats what most people said to do in this case. Other people in the thread said to make sure it is closed to do this but how can I really tell if its closed or open besides on what the code is saying.
Also, do i need racetuner to remove the codes permanently? I already bought a Cobb Ap. I already got the block off plates and planning on doing it this weekend but if I can avoid it by removing the fuse id rather do that until it gets worst if it does. |
#634 | |
Member#: 333179
#635 |
Member#: 4574
Vehicle:2011 Legacy 2.5i LMT Silver |
Get Racetuner
Remove system Install block off plates Disable the codes with Racetuner Be done with it forever |
#636 | |
Member#: 249431
South East
Vehicle:2009 370z SP Touring Black |
#637 |
Member#: 98747
South East
Vehicle:07 WRX WRB |
I'll add this. I have an 07 and when my tuner loaded his first base map it was from an 06 that was similarly modded, but my car was throwing codes as if the the ambient air sensor was not plugged in... blah blah blah... my car could not be tuned because boost would be inconsistant depending on the weather.
He quickly realized the OBD codes were different. Maybe not the numbers persay but the chart in the computer or something about how an 07 processes codes. Either way if you have an 07 make sure you keep your 07 OBD settings in the computer. IMO a tuner should be doing this anyways, but if you flip your shizz because you slaved away fixing your car and then drive a hour away only to think you'll have to limp your car back home again check this first. |
#638 |
Member#: 324808
E. Canada
Vehicle:2006 IWL Stg2 OBP |
My car is 100% stock n I got the same P2443 code, but i ignore it (place hand on pump at start up-it vibrates-it works-does it's job-need not worry). I've reset the ecu 2-3 times already when doing headlight bulb replacement and spark plug replacement, the code disappears temporarily, throttle response becomes really soft/weak making you push more gas to prevent stalling(this improves overtime due to ECU learning). after a trip or two, the CEL comes back on. this will happen no matter how many times u reset your ecu (resetting too many times is not advisable). picking up a CObb AP this week. hopefully can just delete the code permanently.
#639 | |
Member#: 132389
BAIC
Vehicle:2006 WRX Wagon SGM 2003 SV1000S --> my DD |
.What's the cost of a Cobb AP + Racetuner? I'd pick up a used Tactrix/BFM cable and I'd turn the codes off with Romraider for a more cost effective solution to this issue. Personally, I didn't want to spend too much time into it which is why I simply pulled the fuse and the air pump relay. I have been using a tune from XPT/Braden, the relevant ECU codes *may* have been *already deleted* by the author of the map (Braden). In any case, it's getting colder over here at night, and I don't get any codes in the morning (again, I pulled both the fuse and the air pump relay). |
#640 | |
Member#: 132389
BAIC
EDIT: it looks like AccessTUNER Race (that's the name of the software) is FREE. Very cool. |
#641 | |
Member#: 333179
#642 |
Member#: 206912
International
If it says a fault code of 'stuck closed' they are prolly shut for good, no worries.
#643 |
Member#: 333179
#644 |
Member#: 333179
Just to be sure...how many relays and/or fuses do i need to pull out & what are they labeled? I pulled out the the relay thats labeled air pump, another one thats labeled air pump relay and the 10a fuse labeled air cut. Is there anything else? For instances, the one labeled a/c relay?
#645 | |
Member#: 132389
BAIC
I'd snap a pic but I'm away from home and I didn't take my car. Maybe what you removed is the air pump fuse (I'm not sure there's actually one). EDIT: for sure you don't want/need to pull anything else (the a/c relay is obviously for the A/C and has nothing to do with the air pump...). Last edited by neg_matnik; 10-14-2012 at 07:49 PM. |
#646 |
Member#: 324808
E. Canada
update: it's been almost a month since i reset my ECU. it's strange my CEL P2443 never came back on. the other resets i had didn't make it go away.
#647 |
Member#: 227624
the pump is only there to push air in the exhaust to warm up the cat so it reduces emissions more so. taking it off does nothing different that the older wrx's didn't do.
so again it does nothing. it only comes on when your car is cold and you start it. then it turns off and that's it. it's more pricey keeping it on cause those valves go bad and you have to replace them and they are $350 each plus the labor. a smog tech might look for them while smogging the car, or might not. but as long as you don't have a cel on for them then it should be ok. BTW if you want to sell the longer pipe that goes from the valve to the right (passenger) head, i'll buy it off of ya. PM me. |
#648 |
Member#: 118698
Vehicle:07 WRX Ltd Wagon 94 Miata |
My 07 is throwing codes P2432, P2431, P2444, and P1410. I've read through this entire thread and am evaluating my options. Thanks to all of you who have blazed this path for those of us embarking.
My immediate concern is about those last two codes "stuck on/open". Am I okay to drive the vehicle while I continue troubleshooting? If not, why not? What is the risk? |
#649 |
Member#: 275250
Vehicle:2006 WRX White |
I didn't look up the codes. But if they are related to your air pump, you are fine. As mentioned 200000x's the air pump is just there for emissions purposes.
#650 | |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
That is incorrect If they are stuck open that's bad, basically there is an open hole in one of your cylinder heads, and it leads back to the air pump. The air pump activates for the first 30 seconds of all cold startups, it pumps extra air into the passenger and drivers side cylinder heads leaning out the AFR causing the catalytic converters to heat up faster. Remove the valves and install the block off plates. Enjoy the new found peace of mind and less cluttered look of your engine bay. ~Evil |
| Thread Tools | |
| Display Modes | |
| Air pump removal + fail? 07 WRX. | Badmunky | Factory 2.5L Turbo Powertrain | 13 | 04-29-2013 08:05 PM |
| WTB 06-07 Wrx AIR PUMP | StageWrx | Private 'Wanted' Classifieds | 1 | 03-30-2009 10:44 PM |
| is it safe if i remove the restrictor on my wrx | prlblkwrx02 | Factory 2.0L Turbo Powertrain | 44 | 03-24-2007 07:21 PM |
| Is it safe to switch to summer tires yet? It is March after all... | Samirr76 | Tri-State Area Forum | 38 | 03-06-2003 09:25 PM |
