#1 |
Member#: 291102
SCIC
Vehicle:2011 WRX SWP |
Any recommendations for HID kits? Don't want no cheap ones. Just want to see the road more. Thanks in advance.![]()
#2 |
Member#: 328461
MWSOC
Vehicle:2003 WRX Sonic Yellow |
HID kits in stock non HID housings are a bad idea. Look into HID retrofit kits.
#3 |
Member#: 330050
NWIC
Vehicle:2013 WRX 5DR Limited Silver |
#4 |
Member#: 291102
SCIC
#5 |
Member#: 311160
BAIC
Vehicle:2012 WRX 5 door SWP |
Ddmtuning.com is pretty good. I have several kits of theirs, never had a problem with them. Getting them before subiefest is questionable though.
#6 |
Member#: 296721
SCIC
Vehicle:11 5door SWP |
JLC Lighting in El Monte. They did my Angel eyes too
#7 |
Member#: 214050
MWSOC
Vehicle:2007 WRX World Rally Blue |
#8 |
Member#: 291102
SCIC
#9 | |
Member#: 291102
SCIC
#10 |
Member#: 261307
South East
Vehicle:04 wrx wagon WRB |
I second TRS. You can do it yourself for a fraction of the cost. It took me about 7 hrs to complete my retrofit. Morimoto H1minis are your friend.
#11 | |
Member#: 296721
SCIC
[IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]Last edited by Dka67; 09-29-2012 at 09:44 PM. |
#12 |
Member#: 313938
NWIC
Vehicle:2007 wrx wrb |
Another +1 for trs. If you have reflector headlights I probably wouldn't do it. But if you have projectors its well worth the money.
#13 |
Member#: 141373
E. Canada
Vehicle:2008 2.5i-hatch - now with a HID retrofit |
+1 for TRS. Bixenons are fun
![]() Edit: this is one perfect example of a HID kit thread which did NOT turn into flamed name-calling. Why? because the OP posted an uniformed question, and listened to answers without arguing that "my yobuddies have a 90000K kit and its da best" Group hug for a nice thread ![]() Last edited by Bluefoton; 09-29-2012 at 06:41 PM. |
#14 | |
Member#: 273621
Tri-State
Vehicle:2013 WRX Limited SWP Hatch |
#15 | |
Member#: 291102
SCIC
#16 |
Member#: 291102
SCIC
#17 |
Member#: 271928
Tri-State
Vehicle:2007 Impreza 2.5i SE OBP |
![]() Its a little off metered by my tail lights but these are my morimoto d2s's switched on high beams without the actual high beams being plugged in. Hope this helps |
#18 |
Member#: 327339
MWSOC
Vehicle:1996 Impreza Outback Forest Green |
+1 on ddm if your gonna go with a kit you can use with stock headlamp assy. but retrofits are always the way to go if you wanna be legit and legal.
#19 |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
Lightwerks or trs. Recommend going full retrofit to reduce glare to a minimal and you will be happier with the higher quality equipment and overall outcome
#20 |
Member#: 321805
MWSOC
Vehicle:2002 Jdm v9 STI Blue |
does the TRS kit auto height adjust or manual like the sti? or is it non adjustable
#21 |
Member#: 334054
Vehicle:2011 WRX Premium World Rally Blue |
I love my TRS quickretro kit. I didn't wire up the bi-xenon, although the projectors are setup for it if I ever want them. The TRS retrofit kit was the most I've ever spent on HIDs, but they came with the ballast that mount to the bottom of the stock headlight and put much more useable light on the road where it is needed and comes with a razor sharp cutoff pattern. Also, when you see my car head on at night, it is just two blue/white circles, no glare. I highly recommend theretrofitsource.com's kits. The adjustment is made just like the stock halogen lights. You have to pop the hood and level them that way. I don't know of any way to add auto leveling, or the motors like the STis have.
#22 | |
Member#: 275418
SWIC
Vehicle:2010 WRX Hatch OBP |
![]() This is also true in this case, because I've seen many other newbies ask similarly clearly stated questions politely get their butts handed to them without provocation! Guys will be guys I suppose haha |
#23 | |
Member#: 311160
BAIC
Ok, sorry for the rant, back on topic |
#24 | |
Member#: 271928
Tri-State
#25 |
Member#: 304299
NESIC
Vehicle:2011 WRX Sedan White |
