Old 05-10-2012, 05:45 AM   #1
toxin
Member#: 51259
2007 WRX
СGM
Default Too rich at idle (CL/OL status issue)
Hi everyone,
I'm working on my '07 WRX now, and I have an issue related to CL/OL status and warm engine start.
After a warm start the CL\OL status stuck at 7 and switches to 8 after 3-5 minutes which I consider really long.
Normally, when hit the gas pedal, the CL\OL status switches from 7 to 8 instantly. Not in my case..
From what I've read, the condition to switch the CL\OL from 7 to 8 is the O2 sensor warm-up.
Does that mean that O2 sensor heater does not working properly?
Anyway, I can live with CL status stuck at 7 for a few minutes, but the AFR at idle is running too rich, and this drives me crazy.
Code:
(rpm)	AFR	CL/OL	ECT	TPS
756	12	7	205	1.96
756	12	7	205	1.96
728	12	7	205	2.35
695	12	7	205	2.75
695	12	7	205	2.35
650	12	7	205	2.35
650	12	7	205	1.96
612	12	7	205	1.57
612	12	7	205	1.96
558	12	7	205	1.96
558	12	7	205	1.57
512	12	7	205	1.57
512	12	7	205	1.96
512	12	7	205	1.57
454	12	7	205	1.57
454	12	7	205	1.96
The appropriate cells in the Min Primary base enrichment table are zero'ed, still the car idles at 11.5-12 AFR while CL status set to 7.
Mods are:
-700 cc injectors
-TD05-18g turbo.
-TGV deletes
-EWG
Any advice how to resolve the issue will be highly appreciated.
toxin is offline   Reply With Quote
Old 09-29-2012, 08:06 AM   #2
JLHK
Member#: 322967
may i know if you have got it solved dude? i am running into the same **** now, advice please
JLHK is offline   Reply With Quote
engine lean/rich at idle, otherwise good, help tune, gearing up for stage 2 MAtwal Engine Management & Tuning 0 02-17-2010 02:28 AM
Running Rich at Idle Problem windozer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-24-2009 10:33 PM
Running rich at idle but only while fans are on..?? SubieStylez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-01-2006 09:56 PM
Too Rich at High Speeds/RPMs 96WRX North West Impreza Club Forum -- NWIC 20 02-22-2005 01:51 AM
Too Rich at High Speeds/RPMs 96WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-21-2005 06:51 PM
