#201 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
For best results don't buy your E85 until you're ready to use it. If you can store it in an airtight enclosure that's what you want to do also.
#202 | |
Member#: 195711
MWSOC
Vehicle:STi 04/05/06/07 JBP / OBP for now |
![]() Thank you for the heads up Kelly, I will hold off on getting some. |
#203 |
Member#: 32669
SCIC
#204 |
Member#: 195711
MWSOC
Thats funny Kelly, I assumed no news yet.
Got my fmic pipes all fabbed up yesterday, glad to have that monkey off my back. I have to finish trimming bumper to fit the FMIC behind it, and it'll start to look like a car again. Can someone measure the OD of a stock MAF Size short ram? I'm hoping I have a coupler, but cannot find what size it is for some reason. Excitement is building now, Oil, coolant, PS Fluid, Trans fluid are all being purchased this week. NEVER know, next weekend could be the start up if the moons align properly. Truly the only things left to do are: Install all FMIC pipes once Rich welds on the coupler beads. Re-install the MAF connector wires Tighten down suspension components in the front Fill all fluids mentioned above, and snag some E85 Flash Break in Map Prime & Pray If anybody has an AP V2 that would work with my car, and has their car out of commission right now, I'd really love to use an Accessport for break in, but I don't want to shell out the coin, cause quite frankly, I don't have it right now. So a 4-6 week rental would be sweet. I dont want to deal with romraider again, but I know how to use it so I will if I have to. I got my JDM V8 seats monday, and thought it was a little intriguing that the drivers side had ridges in the bolstering to hold the driver in a little better. Didn't matter to me too much, since I'm getting a Carbon seat for my side of car for track days, passenger can have the height adjuster i suppose. Last edited by Layvon; 09-24-2012 at 05:18 AM. |
#205 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
your going to break it in on e85??? i have always been told not to because of the added amount of fuel in the cylinders and the cooler cylinder temps which is why i ran mine on 93 for so long
#206 |
Member#: 195711
MWSOC
I haven't decided. Will let Dom decide. It would be easier for me to do it on 93 but if those injectors don't want to run right itd be 85.
#207 |
Member#: 193757
MWSOC
Vehicle:2006 XTI Limited OBP, Junior tuned |
Stock MAF is 65mm
#208 | |
Member#: 193757
MWSOC
#209 |
Member#: 195711
MWSOC
Thanks for MAF size. It was in mailbox when i got home and off the phone with you lol. I have no problem with that. Makes life easy really.
#210 |
Member#: 195711
MWSOC
Getting everything buttoned up today, will be waiting on my break in map for next weekend!
Added some blood to diff / trans / motor. Might seem goofy, but is it advantageous to pour oil in thru the head breather on the passenger side to get some oil over there. I doubt it is practiced often, but just something I was thinking about last night as I poured the first two quarts in. |
#211 |
Member#: 32669
SCIC
Are you starting it up on the Vipec or stock ECU?
#212 | |
Member#: 193757
MWSOC
#213 | |
Member#: 195711
MWSOC
And to you Manitou - I haven't got it yet. Dom has my mod list, and knows I'm doing romraider, so I'm patiently waiting. I don't have my tactrix cable - seanathanq83 above is letting me borrow his for break in.. and is sypposed to mail it out today. So I couldn't even turn it on if I wanted to. Fighting the front clip right now. Was going to try to make the 07 front end work without buying the Radiator support / light brackets, but no luck. Turbo and exhaust are next on the list. That is exciting you'll get your stuff back this week too! Once we're up and running perhaps a meet greet and break in day? ! |
#214 |
Member#: 195711
MWSOC
Base maps have arrived (in the command and conquer voice)
As long as tactrix shows up tomorrow or Saturday .. should start up this weekend! |
#215 |
Member#: 195711
MWSOC
Got the tactrix cable and when I was soldering up my MAF extension I found the knew I had originally pulled off it. Oh well, I guess next time ill look on the shelf I thought I had it on.
Hopefully will be doing some oil priming yet tonight! |
#216 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Git 'er done!
#217 |
Member#: 195711
MWSOC
Here goes nothin!!
#218 |
Member#: 32669
SCIC
IBjealous
#219 |
Member#: 195711
MWSOC
Haha I'm sorry Dude!
Well, patience paid off. Got it primed, reinstalled spark plugs and prepped for start up. Have a super small fuel leak, which I will fix with a new AN fitting. The main issue I have is the wastegates. They are tials with the 5lb spring for break in. At idle they are open and blowing everywhere. Scared me $hitless at first when I started and heard that. I initially thought I hooked up hoses wrong, ie switched top / bottom ports .. so I changed that, still no luck. In a last resort before I left for family function, I hooked the top ports right to Turbo... still letting exhaust out. Meanwhile, idling afr is 14.5-15.0 . Though I don't trust it because I have to believe that the wastegate taking most of the exhaust would.change something. Any ideas fellas? |
#220 | |
Member#: 193757
MWSOC
#221 | |
Member#: 32669
SCIC
Are you sure you put the seat in the wastegate? Without it it will never close.
#222 | |
Member#: 195711
MWSOC
I've read about this since I've found my problem. I don't have any extra parts laying in the Tial Boxes, and I kept them 100% organized. I took the top of the canister off to change springs, and then put it back together. Is there something you have to do in addition to that? I'll start searching. Edit... you mean these?! ![]() ![]() I wish i knew about these. ![]() Last edited by Layvon; 10-06-2012 at 09:48 PM. |
#223 |
Member#: 32669
SCIC
Yes, that goes inbetween the wastegate and the vband fland and forms the valve seat for the wastegate to seal againsts. Without it the wastegate will never seal.
#224 |
Member#: 195711
MWSOC
Just finished installing those. I think it fixed it. AFR was around 11.8-12.8 at 1000-1500 rpms just now. Car won't idle on its own I have to massage the gas.
I have two more maps, both a little leaner so ill test those out tomorrow. Will be sending Dominic some logs of it so he can look. It was exciting to gear it fire up again today. |
#225 |
Member#: 195711
MWSOC
Well, Day two of motor being alive has been interesting. Trying to figure out why everything is so noisy on the exhaust side of things. Not the tail pipe either.
I'm thinking I have a combination of a leak (fish eye in a weld) and new exhaust ringing. Buddy suggested that it was new and that there isn't anything to stop the echoing, but my gut tells me otherwise. I hope he's right. My first thought was that it was the throwout bearing not clipped in and the fingers on the pressure plate hitting it, but I put a stethoscope on the bell housing and couldn't pinpoint it. I installed a ACT Streetlight flywheel and 6 puck clutch, so I was expecting some noise, but not this much. In other news - I have an AEM Wideband, and am having one heck of a time getting it to communicate with romraider. Any tips? **Edit - I was doing a couple investigations about the USB - Serial Adapter that I have, and it turns out that if you get a yellow ! and a code ten, it isn't any good. I've been trying to get hyperterminal to work and fighting it and it is a darn hardware problem. The worst kind. Thankfully Amazon came through in the clutch, and I'll have a good one here tuesday.** Thanks fellas for reading my pleading for help. Last edited by Layvon; 10-07-2012 at 07:28 PM. |
| Thread Tools | |
| Display Modes | |
| Maxwell Power EFR 7670 | Bariga | Proven Power Bragging | 1869 | 06-02-2013 07:46 AM |
| WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps | wrx. | NWIC Private Classifieds | 0 | 11-13-2011 06:49 PM |
| FS : NJ: 2004 STI Race Build | dsds711 | Private Vehicle 'For Sale' Classifieds | 22 | 03-19-2011 11:39 AM |
| 2004 sti build questions | GA_STI | Factory 2.5L Turbo Powertrain | 2 | 09-09-2009 03:31 PM |
| 2004 STI Parts from Racecar Build | TxSpeed1 | Complete Car Part-Out | 36 | 03-21-2009 03:00 PM |
