Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 09-28-2012, 02:44 PM   #1
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
Default Subaru powered Boxster "Street Version"
This is the next conversion car that I'm working on... actually it's a pair of cars. The goal is to keep them as a street cars that can be daily driven comfortably, but still perform on the track for Time Trials. The engine on the white car is the same EJ255 that is in my green car, but the turbo will be a smaller GT2871 using factory exhaust manifolds.
The silver car will be a little different in some of it's components, but the goal is the same as far as the car's intended purpose.
GT3 front bumper
New timing belt system, water pump, welded/ported TGV's, ID1000 injectors, and secondary air injection delete.
Modified OEM Subaru wiring harness ready to be installed
Engine mocked up in chassis
Air/water intercooler in rear trunk. No goofy roof scoop needed...
Turbo and stuff...
kcpaz is offline   Reply With Quote
Old 09-28-2012, 02:58 PM   #2
kcpaz
Member#: 194611
1998 Legacy GT
Here is the silver car. It's a bit of a mix of spare parts that I have been collecting.
The hard top was from another project that got a fiberglass top.
Stripped the red paint off. The plan is to run the top with a brushed aluminum finish
The silver car had a horrible "pink" colored interior...
So we ripped that out...
And installed a black interior from a 2004 Boxster S. Now it has a glove-box
Old 09-28-2012, 03:34 PM   #3
25rsti
Member#: 166324
Interesting....
Old 09-28-2012, 03:52 PM   #4
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Oh my, subscribed!
Old 09-28-2012, 07:36 PM   #5
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
sweet kent, love the projects!
RonW is offline   Reply With Quote
Old 09-28-2012, 09:29 PM   #6
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Great looking project no one will ever suspect a fast boxster haha just playing let us know how she goes when your done.
Devilteg is offline   Reply With Quote
Old 09-29-2012, 01:02 PM   #7
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Glad to see everything has proven itself in the green car. I hope some of the people that have been bugging you for a street setup will actually follow through with orders.
geronimo81 is offline   Reply With Quote
Old 09-29-2012, 03:12 PM   #8
kcpaz
Member#: 194611
1998 Legacy GT
Me too.
Old 09-30-2012, 01:29 AM   #9
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
As always nice to see your projects...
RSti_Spyder is offline   Reply With Quote
Old 09-30-2012, 06:44 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
This will be fun to follow as well.
I am curious what size tubing and wall thickness do you use for the tubular subframes to mount the engine? And do you just use a manual tubing bender to make the bends? I may have to do some of that in the future so I'm curious how the pros do it and what materials.
Thanks, good work.
Ben
PHATsuby is offline   Reply With Quote
Old 10-03-2012, 01:13 PM   #11
ScottyB
Member#: 155883
2005 2.5RS
silver filth
very, very excited to see where this goes. as boxster prices come down, i keep letting myself get intrigued to buy one but i just can't consider it until there's a reliable and complete solution to getting rid of the stock powerplant. i'll be following this progress closely. nice job!
ScottyB is online now   Reply With Quote
Old 11-15-2012, 03:48 AM   #12
cpturbo
Member#: 49175
2004 STI
Any updates, Sir??
cpturbo is offline   Reply With Quote
Old 11-16-2012, 12:47 PM   #13
kcpaz
Member#: 194611
1998 Legacy GT
Sorry, been busy with other projects. I have managed to do some work on the cars though.
The white car will be done first, and should be running by the end of the year.
The silver car is being built at the same time, but will have a custom roll car, and some other modifications that will happen before the engine goes in.
I went back and forth on the OEM exhaust manifolds, and decided that it's just not worth the compromises in ground clearance and pre-turbo exhaust length to use the OEM manifolds. Instead, I decided to make a tubular header system that mimics the OEM exhaust in design, but increases flow capabilities, and moves the location of the "up-pipe" to the driver's side for a more direct path to the turbo.
I've also decided that the use of an OEM style turbo is not something that we will plan on. The orientation of the turbine/compressor housings on the stock frame turbos, along with the function of the internal wastegate, and location of the fluid line fittings, make things too complicated. This will also simplify our exhaust options to the use of either T25, T3 and T3 twin scroll... and possibly T4 if someone really wants to run a large turbo.
Old 11-18-2012, 05:12 AM   #14
kcpaz
Member#: 194611
1998 Legacy GT
Some pictures of the exhaust and intercooler system...
Old 11-18-2012, 08:04 PM   #15
cpturbo
Member#: 49175
2004 STI
I like it! So, I am glad that T4 is an option. Is this location amenable to gravity oil drainage? Looks good. Are these parts ready to ship if I order up a kit? I also need an electric power steering kit recommendation.
Old 11-18-2012, 11:52 PM   #16
kcpaz
Member#: 194611
1998 Legacy GT
I'm not 100% sure, but I really doubt that gravity return would work based on the turbo location. The factory return port in the head is definitely too high, so you would have to weld a bung into the oil pan, but that's not something I am planning on doing on any of my cars. A scavange pump is the way to go IMO.
I could help you with some information on the electronic power steering pump if you decide to go that direction, but unless you are building a dedicated race car, I would just use the Subaru mechanical pump. It simplifies things a lot.
Send me an email for more details on the availability question.
Old 11-19-2012, 12:47 PM   #17
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
Damn man your welding skills are impeccable! This is such a cool project!
DeleriousZ is offline   Reply With Quote
Old 11-19-2012, 04:50 PM   #18
ecbmxer
Member#: 228059
2010 WRX
Spark Silver Metallic
This is awesome! If you start producing these conversion kits I bet a bunch of people will be running around in Subie powered Porsches! Aren't Boxers with blown engines pretty easy to find?
ecbmxer is offline   Reply With Quote
Old 11-19-2012, 07:20 PM   #19
Extreme Turbo Systems
Member#: 194655
08 STI
Looks really good. Actually perfect for a water/air setup. you can run the heat exchanger up front which increases the capacity for water and will make it really hard to heat soak.
Extreme Turbo Systems is offline   Reply With Quote
Old 11-21-2012, 01:21 PM   #20
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed.
wtyree is offline   Reply With Quote
Old 01-18-2013, 07:41 PM   #21
johnvan8
Member#: 340778
subscribed
johnvan8 is offline   Reply With Quote
Old 01-21-2013, 10:50 AM   #22
Stangy
Member#: 329676
1999 GC8 R-STI
pumped
Stangy is offline   Reply With Quote
Old 01-21-2013, 11:05 AM   #23
bchasc
Member#: 344087
2005 WRX Wagon
Very impressive...subscribed
bchasc is offline   Reply With Quote
Old 05-13-2013, 08:50 PM   #24
cpturbo
Member#: 49175
2004 STI
How much horsepower can that intercooler handle? Are those cars up and running?
Old 05-15-2013, 01:23 PM   #25
kcpaz
Member#: 194611
1998 Legacy GT
Garrett rates the intercooler at 750hp.
These cars had to take a back seat to some other projects in the shop (BMW related) but the white car was 80% complete when we stopped. They should resume progress in the next month.
