Old 09-27-2012, 10:46 AM   #1
fendrick
Member#: 254744
Default Cylinder misfires on all four
The other day I was driving in the rain, Went to go WOT and it threw a code. I recently had the car tuned. I pulled the plugs and checked the coil packs. Plugs were destroyed, car is running very rich. Pulled the plugs installed new ones, Happened again, i smoke tested the car and found no leaks. I datalogged the car from my aem air/fuel and the car was hitting as low as 10 (as low as it can be read) for cycles of 600 rpms. and it would bounce all over the place under WOT. My tuner said that his gauge reads more accurate than mine which is why it runs so rich on my datalog. Let me know if there is anything else that would help diagnose this problem. Want to get this fixed!!!!!
The following mods are:
Motor was just rebuilt 3,000 miles ago. Put down 299 awhp 265 torque
.20 over JE Pistons
Eagle Rods
18g Blouch journal bearing turbo
750cc deaschwerks fuel injectors
255 walbro
TurboXS Front Mount Intercooler
Perrin Short Ram Air Intake
Greddy turboback exhaust
Prosport Equal Length Header
Gimmick Boost Control Solonoid
STI oil pan
STI oil baffle
STI oil pick up
Brand new oem clutch
Defi red racer boost gauge
AEM oil pressure gauge
AEM air/fuel ratio gauge
ATI gauge pod
fendrick is offline   Reply With Quote
Old 09-27-2012, 02:31 PM   #2
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
.20 over JE Pistons
Eagle Rods
255 walbro
STI oil pan
STI oil baffle
STI oil pick up
ATI gauge pod
Your tuner said his gauge reads more accurate than yours? Possibly, but your afr shouldn't be that low. It sounds like it's even going lower than 10 but your afr gauge can't read that low. Take it back to him asap.
When you mentioned all 4-cyl misfire and rain in the same sentence, I immediately thought you sucked up water but this sounds to me like a fueling issue or a major leak. Can you build boost?
wgr73 is offline   Reply With Quote
Old 09-27-2012, 02:43 PM   #3
fendrick
Member#: 254744
I can't find a leak anywhere I had it up on a lift and scoped the whole car out. MAF sensor is fine. I thought it seemed odd that he said with it dropping to 10 that that is fine?
Old 09-28-2012, 07:46 AM   #4
quazimoto
Member#: 70395
And the code is?
Old 09-28-2012, 05:01 PM   #5
fendrick
Member#: 254744
P0301 302 303 304
Old 09-29-2012, 01:08 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
rain can mess up the MAF which will mess up the fueling. does it only happen in the rain?
Old 09-29-2012, 01:22 PM   #7
fendrick
Member#: 254744
Nope i cleared the codes and they come right back
Old 09-29-2012, 01:25 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
did you check the spark plug gap before install? even if they are "pre-gapped" you still need to check them.
and it is also possibly that the car was tuned with a leak....and now you dont have a leak.
Old 09-29-2012, 01:31 PM   #9
fendrick
Member#: 254744
Yes I checked the gap on the plugs and it was perfectly fine
Old 09-29-2012, 02:13 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
You're basically just gonna have to troubleshoot through the fueling and ignition system until u find something then.
I'd start with rechecking the tune, swap injectors, swap maf sensors, swap front 02, check fuel pressure, fuel pump
Old 09-29-2012, 02:22 PM   #11
fendrick
Member#: 254744
Thanks! Ill start there I really appreciate the help!
Old 09-29-2012, 02:46 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
if you've never done the front 02 sensor, then i would start there.
Old 09-29-2012, 03:03 PM   #13
fendrick
Member#: 254744
Sounds good! Thanks!!! Ill keep my post updated
Old 11-06-2012, 07:32 AM   #14
fendrick
Member#: 254744
I got the problem resolved. I changed plugs, swapped coil packs around and resealed the injectors and all is good now!
